Go Back   SaturnFans.com Forums > Categories > General Saturn Discussion
Old 05-23-2012, 04:32 PM   #1
tomcook
tomcook is on a distinguished road
Default S series vs others
1999 SW 2
typical oil burner - 150,000 miles, a qt every 250 - 300 miles.
If my wife wasn't so embarrassed about the big white cloud AND oil was $1.00 a qt, I'd just keep driving. I LOVE the car.
I've tried ring soak, additives, different oil, I'm convinced the only solution is another engine and I'm not up to tackling that.
Did Saturn make any engines with the holes in the rings? If so, which models?
I'm sure I'll get 25 different opinions from 10 different people, but what about the other models? Better/worse than the SW's??
Thanks again for a great forum.
When the men pounding on the door yelled, "Alcohol Tobacco Firearms" I, of course, thought it was a delivery.
Add to tomcook's Reputation
Rate the quality of this post and help tomcook reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
tomcook is offline   Reply With Quote
Old 05-23-2012, 07:14 PM   #2
RedGeminiPA
RedGeminiPA will become famous soon enough
RedGeminiPA's Avatar
2004 VUE 3.5L
Default Re: S series vs others
Originally Posted by tomcook View Post
1999 SW 2
Saturn only built two versions of the 1.9L with slight changes over the years. I'm not 100% sure which years were actually the best, but I'd guess anything in the last years ('00-'02-ish). You'd just have to look for a 1.9L Twin Cam 16-valve. The only other 1.9L was an 8-valve engine.
The model determined which engine they had:
SL, SL1, SW, SW1, SC, SC1 had the 8-valve engine
SL2, SW2, SC2 had the 16-valve engine
I'd think a rebuild by someone who knows the Saturn 1.9L would be your best bet. Personally, I don't know I'd trust the expense of swapping out engines. You could probably have a good rebuild done for not much more money.
There was a year when they supposedly changed some internals to combat the oil consumption/rings, but I believe that was around the year of yours, maybe 2000.
Avid Apple, car and vacuum enthusiast. Don't hate! ;)
Current:
'04 FWD 3.5L
Previous:
'05 AWD Red Line
'02 L200
http://www.facebook.com/SaturnFansNorthEast
Add to RedGeminiPA's Reputation
Rate the quality of this post and help RedGeminiPA reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
RedGeminiPA is offline   Reply With Quote
Old 05-23-2012, 09:08 PM   #3
adventureoflink
adventureoflink's Avatar
and even still it wasn't enough. a majority of those third gen engines went right back to burning oil.
unless your Saturn was rebuilt (the right way ), no S-series ever had drain holes in the pistons.
97 SL2
DOB: 3/19/97
Date Obtained: 5/30/07
Status: Alive, 1/2 exhaust
2004 Merc G.Marquis GS
DOB: 2/4/04
Date Obtained: 7/6/12
Status: Alive, no heat
Old 05-23-2012, 09:37 PM   #4
tomcook
What about series other than the S.
Any better than others?
We may buy a used car rather than have a re-manufactured engine installed and don't have any knowledge of the other models.
Old 05-24-2012, 09:36 AM   #5
RedGeminiPA
2004 VUE 3.5L
The 1.9L was S-Series-only.
The L-Series used the 2.2L EcoTec, but be cautious of any before '04. There were prone to timing chain snaps due to poor lubrication. They had the Opel-built 3.0L V6 as well. They're generally good, but difficult to work on.
The Vue: Similar to the L-Series, but the Honda 3.5L and Honda 5-speed auto was used in '04-'07. Generally bullet proof, but still has their own quirks. AVOID ANY 4-CYLINDER AUTOMATIC BEFORE '05! They were equipped with the horrid VTi CVT transmission that is prone to failure.
Ion: 2.2L and 2.4L EcoTec, but the Red Line had either Supercharged or Turbo available.
Your best bet could be to scout prospective forums for possible failure rates of various components.
Current:
'04 FWD 3.5L
Previous:
'05 AWD Red Line
'02 L200
Old 05-25-2012, 01:16 AM   #6
davidsky
davidsky will become famous soon enoughdavidsky will become famous soon enough
2005 ION-1 Sedan
At 85K my ION doesn't even use oil, the engine isn't even remotely dirty.
Newer than 99 it's hard to find wagon-y goodness like an SW
Member of the Crank Window Club
Add to davidsky's Reputation
Rate the quality of this post and help davidsky reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
davidsky is offline   Reply With Quote
Old 05-26-2012, 04:07 PM   #7
tomcook
Yeah, I know.
And my better half has already told me "No smaller than the SW."
Hate to consider it, but another make and model may be in my future.
Old 05-27-2012, 11:07 AM   #8
RedGeminiPA
2004 VUE 3.5L
Yeah, I know.
You may be able to find a nice LW. If I were in the market, I'd consider owning one. Granted, you might have to travel a little, but it could be worth it.
Current:
'04 FWD 3.5L
Previous:
'05 AWD Red Line
'02 L200
Old 05-27-2012, 07:46 PM   #9
tomcook
When I search "problem" in the L serIes forum on this site I find a near duplicate of the S series. "BURNING WAY TOO MUCH OIL!" With the usual PVC, MMO soak, etc.
Sounds like "frying pan to the fire."
Old 05-28-2012, 09:20 AM   #10
s3nfo
s3nfo's Avatar
2001 L-Series 3.0L Wagon
Hunn, don't know where you got that, the L series do have problems of their own, but being oil burners is not one of them!
Jerry N
Groucho Marx
Add to s3nfo's Reputation
Old 05-28-2012, 11:36 PM   #11
RedGeminiPA
2004 VUE 3.5L
Considering they only had 2.2L EcoTecs or 3.0L Opel V6s, and I've never heard of any oil consumption problems, I'm stumped as to exactly what you've found.
If you search for "problem," you're going to find a boat-load of related threads on any car forum talking about "problems." That doesn't mean they're loaded with problems. Usually, one forum thread sums up most of the issues to a problem, but most don't take the time to really search the threads for a problem. It's easier for someone to start a new thread, which leads to probably hundreds of repeat threads about the same problem.
Your best bet would be to start a thread under L-Series - General asking for input from owners if you're considering the purchase of an L-Series. The same thing is asked by prospects in the Vue forum, and they usually always find enough responses on what to look for so they can make an informed purchase. So far, they've all ended up buying a Vue after some input from other owners, at least from what I've seen.
Better yet... just look for a nice '04-'07 Vue with a V6. They're powered by the bullet proof Honda 3.5L VTEC engine and Honda-built 5-speed automatic. You'll typically find far more praise than negative from this little guy.
Keep in mind - most threads in many parts of these forums are from owners trying to solve a problem. It's far from an indication that every Saturn X or Y model will experience this same problem. You can't base that as a rule of thumb meaning they're nothing but problems. Every car manufacture has issues, and forums like this for other brands will also be loaded with people asking for help with problems. It doesn't mean every brand is junk. It just means we live in a world of computer-controlled vehicles that have become very sophisticated and complicated beasts.
Current:
'04 FWD 3.5L
Previous:
'05 AWD Red Line
'02 L200
Will sun visors from a 2003 L-Series fit a 2000 L-series model? sparhawk L-Series General 2 11-20-2011 03:33 AM
L Series Owner with a S series question! (part swaps) mattachuz S-Series Tech 17 08-19-2011 12:24 PM
L series pull up reverse shifter removal for manual l series hellsaturn5537 L-Series Tech 8 10-07-2009 09:40 AM
New S-Series Forum - post S-series tech issues there? coolgreany General Saturn Discussion 0 05-13-2003 11:28 PM
fs 16X7" series 193 6 spoke (s-series) customsleeper Classifieds 21 02-22-2003 09:44 AM
