Old 04-09-2012, 09:47 PM   #1
kjtyo4
kjtyo4 is on a distinguished road
2000 SL
Default Wheel bearings
I am fusterated. Is there any reason why my saturn sl would go through front bearings. I had them just replaced with Canyon that to help we no problems
2 weeks later they are both bad confirmed by me and my mechanic. Same thing happend last year when replacing 2 weeks then whent bad. The car never been hit good aliment all new frontend parts.
Could motor mounts cause this? the worn but not broke.
I don't know I do thank Canyon for the help and learing.
kenny.
Add to kjtyo4's Reputation
Rate the quality of this post and help kjtyo4 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
kjtyo4 is offline   Reply With Quote
Old 04-09-2012, 11:54 PM   #2
youngt
youngt is on a distinguished road
Default Re: Wheel bearings
kenny.
when you replaced the bearings did you replace the hub as well?
Add to youngt's Reputation
Rate the quality of this post and help youngt reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
youngt is offline   Reply With Quote
Old 04-10-2012, 12:19 AM   #3
kjtyo4
2000 SL
Yes I replaced the hub Came in a kit Made by Moog the bearings are national.
Moog is making national bearings know I guess.
Everything has been replace but the struts themselves.
kenny
Old 04-10-2012, 06:23 PM   #4
rbar
rbar is on a distinguished road
Did you do the work yourself?
The bearings have to be pressed in. If they are hammered in, they are destroyed in the process.
I'd say installer error.
RBar
kenny
Add to rbar's Reputation
Rate the quality of this post and help rbar reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
rbar is offline   Reply With Quote
Old 04-10-2012, 07:41 PM   #5
td1238
Also, when they are pressed in, if at all possible, it is best to apply all pressing forces to the part being pressed in. If at all possible, do not transfer forces through the balls. If pressing the outer race into the knuckle, then use a diameter of pipe (or an outer race from an old bearing) that matches the size of the outer race of the new bearing. If pressing the inner races onto the hub, then use a diameter of pipe that matches the size of the inner race, so that forces are applied directly to the inner race. Don't press on the inner race to drive into place the outer race.
I have hammered into place new bearings myself, which have given me many miles of good use, but I used a non-hardened steel dowel, and applied blows 180 degrees apart to the race being driven into place. This is by far not a preferred method, but it can work if force is applied to the sides of the races. If you hammer one race and send the force through the ball bearings to the other race, the balls will surely become dented, and the bearing will be destroyed. If a press is available, that is the preferred method, and should be used whenever available.
I do not see the need for a new hub, but new parts are generally always a plus. It can be a real pain to get the outer half of the inner race off of the old hub. I used a torch and a chisel with 180 degree blows.
Add to td1238's Reputation
Old 04-11-2012, 01:01 AM   #6
kjtyo4
2000 SL
Thats the way it was done. A member on here named canyon helped me do it it was done right. outer race to push in the bearing into hub inner race to put spindle in he use a wheel bearing tool the pulled the spindle in while the force was on the inner race on the opposite side. so he pulled the spindle through.
I didn't see any problems and went in smoothly were all tight and smooth turning no play before I put them on the car. I took it to the shop for front end aliment after car drove perfectly strait strait steering wheel.
so I don't know. I would never beet on a wheel bearing.
kenny.
Old 04-11-2012, 09:55 AM   #7
blue92
blue92 will become famous soon enoughblue92 will become famous soon enough
1992 SL1
Look at the box your National bearings came in. The reason they fail is printed on the box.
Made in China.
92 SL1 original owner
94 SL2 Homecoming
98 SC2 White Hot
02 SC2
Add to blue92's Reputation
Rate the quality of this post and help blue92 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
blue92 is offline   Reply With Quote
Old 04-11-2012, 01:12 PM   #8
kjtyo4
2000 SL
They never us to be made in china. Is there still any wheel bearing that is good made in the good old USA totally made no foreign parts?
kenny.
Old 04-11-2012, 01:32 PM   #9
SOME Timken bearings are US made. No idea if they have a US-made one for our cars. You have to check the particular part number and contact them, or find one in a box. There were actually both US and Asian (China? Taiwan?) made bearings for my wife's truck.
Add to madpogue's Reputation
Old 04-11-2012, 02:13 PM   #10
Midnight13
Midnight13 is on a distinguished road
Midnight13's Avatar
1998 SL
First off, I sympathize with you living in NY at all,lol! I know the roads in WNY EAT suspension!
I know with the Vue's bearings are always being done,endlinks are always being done, and brakes are always being done(3 times now in a year and a half just for me!) The parts for these vehicles are just so poorly made it's ridiculous!! i'm just glad they're so cheap. It's still frustrating having to make more repairs on the vehicle i'm paying for over the 14 yr old SL!
Did you replace these bearings yourself last year as well? If you want to rule out installer error, your only option is to take them and have them done. At least if they go in 2 weeks again, you can have them take care of it under warranty!!!
Good Luck!
"Not for human consumption!" - Peas in the Pod
http://www.facebook.com/#!/pages/Peas-in-a-Pod/160649663950771
Add to Midnight13's Reputation
Rate the quality of this post and help Midnight13 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Midnight13 is offline   Reply With Quote
Old 04-11-2012, 04:39 PM   #11
kjtyo4
2000 SL
not me Another garage did last year. I had help this year to show me how to do them so I could in the future A member on here canyon help me and he did a good job.
kenny.
Front wheel bearings: Ball or Needle bearings ?? Luke S-Series Tech 12 03-26-2011 08:25 PM
Wheel Bearings? 02 Dawg Vue Tech 4 08-22-2009 12:03 PM
Wheel bearings thewave46 S-Series General 12 03-15-2009 03:58 PM
Bad wheel bearings? feigerou S-Series Tech 12 07-17-2008 02:56 PM
Wheel bearings on SL2 alces S-Series Tech 5 06-20-2008 02:52 PM
