Old 03-30-2003, 01:45 PM   #1
Sattyinsnow
Sattyinsnow is on a distinguished road
Default Winter tires cheap performance tires?
hey all
i was wondering. is a winter tire a cheap performance tire?
their botht he same type fo compound? both soft and made to stick if heated, but the tire design is the same but onyl real thing is the tires are a little diff in the thred area...
whats your oponion?
winter tires cheap alternative to performance tires?
Add to Sattyinsnow's Reputation
Rate the quality of this post and help Sattyinsnow reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Sattyinsnow is offline
Old 03-30-2003, 08:30 PM   #2
wolfman
wolfman's Avatar
Default
Depends on what you mean by "winter" tire. Most SNOW tires I've seen have tread patterns resembling mudder tires found on Jeeps...
Add to wolfman's Reputation
wolfman is offline
Old 03-30-2003, 11:43 PM   #3
eljefino
eljefino's Avatar
1995 SW1
Default
Nope. The huge gaps between tread blocks will let the tread fold over onto itself; tire will slide on that. Sort of like having really tall 80-series tires. Note the deflection of a new pencil eraser vs a well-worn one for an extremely simplified explanation.
Add to eljefino's Reputation
eljefino is offline
Old 03-31-2003, 10:44 AM   #4
WinterRide
WinterRide is on a distinguished road
Default
To add to what has been said, the side walls are usually softer as well. Are winter tires really that much cheaper than a decent performance tire?
Add to WinterRide's Reputation
Rate the quality of this post and help WinterRide reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
WinterRide is offline
Old 03-31-2003, 11:15 AM   #5
Phil
Phil is on a distinguished road
Default
Nope. Not at all. Winter tires have extensive siping in order to obtain traction. Sipes are the very narrow slits in the tread which grab snow and hang onto it (snow grabs snow pretty well). These same sipes increase tread squirm, which generates more heat. It is usually pretty rare when you see snow tires with a greater than "H" speed rating, and those ratings north of "Q" are fairly expensive. A good set of Dunlop SP Sport A2s is much cheaper than the Dunlop SP Winter Sport M2.
Winter tires are great in the winter, but exactly what you DON'T want in a performance tire. Good performance tires have large tread blocks for gripping pavement, but are less than adequate for grabbing snow.
It goes beyond the softness of the tread compound. Tread design and temperature handling are at least as important as compound when it comes to high performance tires.
Add to Phil's Reputation
Rate the quality of this post and help Phil reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Phil is offline
Old 03-31-2003, 03:04 PM   #6
eRic 02sc2
eRic 02sc2's Avatar
Default
no. winter tires are designed for cold, snow, ice. using winter tires in non-winter will chew them up and they will handle badly. if you want something cheap, but good. try the all-season dunlop d60-a2 or sp sport a2. they are about $50 each in the stock 15-inch sizes. take a look on www.tirerack.com for better explainations.
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
eRic 02sc2 is offline
Winter tires on XR mr weather Aura General 11 11-12-2007 12:07 AM
Winter Tires? DAS Vue General 3 12-02-2004 10:31 PM
Winter Tires?? tominsky Vue General 8 01-27-2004 03:32 PM
Winter tires Stoney L-Series General 1 10-23-2003 02:38 PM
Performance Tires - Bigger Wheels thinner tires better? Chris93SL2 Mods and Performance 14 04-16-2003 04:03 PM
