Old 02-29-2012, 07:04 PM   #1
mechanic380
mechanic380 is on a distinguished road
Default Massive oil leak
I am having trouble finding good images of my engine. I am sure you all can help. I have an 04 L series with a 2.2l. Behind the intake manifold, above the oil pan, and below the head gasket there is a massive leak, added 1 qt 1/2 qt came out just cranking. If you know of anything in this area that could cause a massive leak please let me know. I don't want to pull the intake if it is something I can do without that. There is another seam in between the head and oil pan, it appears to be coming from above that on a lip area. again any advice would be appreciated. Crosses fingers in the hopes its not a major repair.
Add to mechanic380's Reputation
Rate the quality of this post and help mechanic380 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mechanic380 is offline   Reply With Quote
Old 02-29-2012, 07:25 PM   #2
mechanic380
Default Re: Massive oil leak
OUCH pulled the intake, really easy, and found a large crack in the block. Lesson learned never buy a vehicle without cranking it, no matter how cheap! Any advice from here? car is not in great shape I would guess its time to scrap it.
Old 02-29-2012, 07:50 PM   #3
mattachuz
mattachuz is on a distinguished road
mattachuz's Avatar
rebuild the engine, these cars are amazing
mi: 199,xxx
trips:
X = dest
O = ON way
home- Clovis, ca
Pismo Beach: xx
Morro Bay: oo
San Francisco: x
Los Angeles: ooo
Anahiem (disneyland): xxx
Tulare: o,(x-atleast 15)
Visalia: x
Add to mattachuz's Reputation
Rate the quality of this post and help mattachuz reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mattachuz is offline   Reply With Quote
Old 02-29-2012, 08:44 PM   #4
midway
midway is a jewel in the roughmidway is a jewel in the roughmidway is a jewel in the rough
2000 L-Series 3.0L Sedan
Time to visit the parts recycling house and get another engine so you will have a not cracked block to rebuild, who knows you might even get a really good engine. If your block is cracked I would not trust it, leaking outside there could be an inside leak somewhere.
Add to midway's Reputation
Rate the quality of this post and help midway reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
midway is offline   Reply With Quote
Massive Oil Burning? cmpcpro S-Series Tech 10 04-02-2010 09:08 PM
Massive oil consumption, trans leak- wits end! Ryan from Ohio S-Series Tech 3 10-05-2007 06:31 PM
Massive oil leak on startup thefishin6 L-Series Tech 7 11-06-2006 01:10 PM
Massive corrosion, massive problem. Luigi Mario S-Series General 10 06-03-2006 11:21 PM
Massive vibration at 100 kph Admiral Beez S-Series General 3 02-15-2006 12:28 PM
