Old 12-31-2011, 01:25 PM   #1
Crzesk8dad
Crzesk8dad is on a distinguished road
1999 SL
Default Clutch repaired and replaced, now still have a knocking noise
1999 SL SOHC 255K+ miles, manual transmission.
Had the clutch, throwout bearing replaced, also replaced flywheel with another resurfaced one.
Shifts great, power good, but I have a "knocking" or rubbing noise, that sounds like a rod about to be thrown. The noise gets faster, slower depending on RPMs, noisier on low RPMs, quieter on high RPMs. Noise totally goes away when in neutral or clutch pressed down, so I'm thinking it's not engine related, but transmission?
Thanks for your help on earlier clutch inquiry.
Happy New Year!
Add to Crzesk8dad's Reputation
Rate the quality of this post and help Crzesk8dad reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Crzesk8dad is offline   Reply With Quote
Old 12-31-2011, 02:38 PM   #2
ShawnV
ShawnV is a jewel in the roughShawnV is a jewel in the roughShawnV is a jewel in the roughShawnV is a jewel in the rough
ShawnV's Avatar
Default Re: Clutch repaired and replaced, now still have a knocking noise
I assume it didn't do that before the new clutch? If it gets faster with the engine, but not in neutral then it seems like something didn't go back together correctly with the transmission. I would check the tranny fluid. It could also be that the clutch hydraulics have not adjusted to the new clutch yet.
Add to ShawnV's Reputation
Rate the quality of this post and help ShawnV reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ShawnV is offline   Reply With Quote
Old 12-31-2011, 05:42 PM   #3
Crzesk8dad
1999 SL
Actually, it made the noise prior to the new clutch. Although due for a new clutch (original clutch at 255K), I thought the noise may be coming from the throw out bearing and/or flywheel.
All of that replaced, yet still have the noise, and it's getting noisier.
I will check the tranny fluid (gear oil), you may be on to something. Thanks.
Old 12-31-2011, 06:08 PM   #4
magtec
magtec will become famous soon enough
1995 SW2
diff pin?
Add to magtec's Reputation
Rate the quality of this post and help magtec reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
magtec is offline   Reply With Quote
Old 12-31-2011, 06:37 PM   #5
dbsanfte
dbsanfte is on a distinguished road
1999 SW2
^^^ We have a winner, methinks
Add to dbsanfte's Reputation
Rate the quality of this post and help dbsanfte reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dbsanfte is offline   Reply With Quote
Old 12-31-2011, 07:46 PM   #6
magtec
1995 SW2
completely missed this earlier. these manual transmissions are designed to use ATF, gear oil is probably far too heavy for proper operation and may damage the gearbox (someone correct me if i'm wrong). was it making noise before you put the gear oil in?
Old 01-01-2012, 05:10 PM   #7
LabRat
LabRat is on a distinguished road
Happy New Year!
If the knock occurs as above when the car is in motion, clutch, output or input sides of the transmission could be suspect, including the diff pin. If it only occurs when the the car is not in motion then input side is suspect which would rule out the diff pin. If it's diff pin (or output side) the straight-line knock frequency would only depend on vehicle speed and should be independent of gear chosen and engine rpms.
My guess would be something on input side since it appears rpm related, like say main input shaft bearing? Haven't had one of these transmissions apart and am unfamiliar with FWD manual transmission layouts.
Other possibilities include a loose flywheel (if it was improperly reinstalled for instance) or improperly installed clutch parts etc. Engine is included on "input side", another knock source could have randomly surfaced at this time, although the lack of knock when clutched or in neutral points away from it, stranger things have happened.
Just my $.02 again.
-LR
Add to LabRat's Reputation
Rate the quality of this post and help LabRat reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
LabRat is offline   Reply With Quote
Old 01-02-2012, 12:05 PM   #8
Crzesk8dad
1999 SL
Thanks to all for the ideas. After reading, I did more research on the internet, and the diff pin certainly sounds like a good place to start, if nothing else.
If that is the case, am I better off finding a used or rebuilt manual trans and replacing it?
Old 01-02-2012, 09:12 PM   #9
Crzesk8dad
1999 SL
And one added question:
Do I risk damaging anything else if I let it go, and wait until the transmission and/or diff pin fails?
I carry AAA Premier, so I know I can be towed home or to a garage.
Old 01-04-2012, 03:17 AM   #10
LabRat
It will not be "good" for the engine if it stops suddenly due to catastrophic transmission or differential failure but may not do major, serious damage unless engine is revving high and/or under heavy load. Only you can decide how much damage risk might be acceptable.
If the knock is due to loose flywheel, failure likely will damage engine. Should be fairly easy to check by pulling the flywheel inspection cover to see if the flywheel is wobbly by hand, or moves when the clutch is operated.
-LR
Finally replaced clutch master cyl -- no noise! ryanB3 Vue Tech 0 08-30-2008 01:18 AM
Knocking noise on '93 SC2 triple_el S-Series Tech 4 07-16-2008 01:12 AM
Knocking Noise Social S-Series Tech 5 04-05-2006 07:43 AM
Anyone had racks and chips in their glass repaired rather than replaced? Blue Goose Vue General 9 09-01-2004 12:24 PM
knocking noise when clutch is released? gm7 Ion General 7 01-19-2004 01:26 AM
