Old 11-27-2011, 03:53 PM   #1
Jyounya
Jyounya is on a distinguished road
Default 97 Sat. SC2...Batt. died, now it wont start...alarm goes off
I left my lights on last night, which drained my battery. I tried to push start it this morning and it would not start. I called my neighbor over to jump start it. When we connected the jumper cables to both cars my alarm went off. I could not turn my alarm off with the key fob. it eventually went off after about 30 seconds. When I turn the key to start the car nothing happens...no clicks, starter doesn't turn. We push my saturn down a hill to push start it and it would not start. My battery is 2 months old. Can anyone give me a tip, I have checked the forums here and I am gonna try the 10 minute override where you keep the key turned to the on position for 10 minutes. Please help.
Add to Jyounya's Reputation
Rate the quality of this post and help Jyounya reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Jyounya is offline   Reply With Quote
Old 11-27-2011, 09:39 PM   #2
saturnsctwo
Default Re: 97 Sat. SC2...Batt. died, now it wont start...alarm goes off
the car needs power to fire the plugs. it won't start if the battery's completly dead. charge the battery fully with a charger & it should start...
Old 11-27-2011, 09:53 PM   #3
Jyounya
I appreciate your response, however I am convinced that it isn't a battery issue...I with my neighbors car's battery connected to mine, everything worked. I would turn the ignition and nothing would happen...sort of like power wasn't making it's way to the starter. Once my car was connected to my neighbors the alarm started going off...it would honk 30 times then stop. After it stopped, if I opened the drivers door it would go off again. I am convinced there is some security lock that won't allow the ignition to turn. Any advice?
Old 11-27-2011, 10:33 PM   #4
saturnsctwo
yes your alarm has an anti-start feature. i know if you try to use an improper key the car won't start. your remote control won't deactivate the alarm? because the power was interrupted to the car when the battery ws dead you might have to re-set the key remote so the alarm will recognize it gain. there's threads explaining how to do this. do a search...
Old 11-27-2011, 11:11 PM   #5
Jyounya
Thanks, I found a thread. The battery is close to dead (alarm horn is very faint). I still jumped the 4 and 8 terminals under the dash and the remote was recognized. I will experiment tomorrow and see if any suggestions worked. Thank you for your responses.
97 SL2 died, wont start andyrew S-Series Tech 1 12-28-2010 08:25 PM
Car wont start (possible alarm prob) help plz SimPlyxTriPPiN S-Series Tech 10 02-10-2008 07:33 AM
Car wont start - batt is good..... acr2001 S-Series General 6 08-01-2007 11:24 PM
sc2 alarm went off last night now remote wont work & car wont start kre8ive_kustomz S-Series Tech 1 03-27-2007 08:46 PM
Dead Batt and Alt, got it fixed, now radio and dome light wont turn on. KGinATL S-Series Tech 3 10-11-2002 11:16 PM
