Old 07-16-2011, 11:59 AM   #1
pecze
pecze is on a distinguished road
Default 2003 Saturn Vue Timing Belt & Oil Leak
Question for the forum. Not much of a car guy here.
I have a 2003 Saturn Vue 6cyl that has 125k miles on it.
I took it in for an oil change and they called to tell me I have an oil leak around the timing system.
So, I think I'm going to be relplacing the timing belt and water pump here shortly so that I don't have a cataclysmic failure.
They say they need to replace the cam/crank seals and the valve cover gasket.
Here's my dilemma. I only planned on keeping the car for 2 years tops. It's only used for commuting (20 miles round trip per day).
My FIL says I should have the cam/crank seals replaced since they're right there but doesn't think I need to have the valve cover gasket replaced right now.
Do you guys have any recommendations? Total repairs were quoted at $2400. The car's not worth much more than that.
Add to pecze's Reputation
Rate the quality of this post and help pecze reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
pecze is offline   Reply With Quote
Old 07-16-2011, 12:34 PM   #2
Chazberry
Chazberry's Avatar
1995 SW2
Default Re: 2003 Saturn Vue Timing Belt & Oil Leak
Things tend to snowball with this engine. If you have the original TB and WP in there, you definitely want to do those ASAP. The TB Kit usually comes with the Cam Shaft Seals. I didn't change the seals - that gets into a whole 'nother operation. You have to remove the Intake Manifold to do the Cam Cover Gaskets. From experience I should have changed those when I did my Plugs. If your Plugs are original or over 60k - you want to change those, the Cam Cover Gaskets and the T'stat at the same time.
Add to Chazberry's Reputation
2003 Vue V6 Timing Belt and Other Parts Replacements Gheuett Vue Tech 11 01-17-2015 01:08 PM
Changing Timing Belt on a Saturn Vue 2002 AWD and without the timing belt tool kit Joelsaturnvue Vue Tech 16 03-13-2013 01:02 PM
2003 Vue Timing Belt Questions Gheuett Vue Tech 40 09-01-2010 02:48 PM
L300 timing belt change and oil leak Rick in Hobart L-Series Tech 7 05-30-2009 01:55 PM
Vue timing belt replacement, 2003 V6 claw218 Vue Tech 6 02-03-2007 12:27 PM
