Old 05-17-2011, 04:04 PM   #1
SL2Many
SL2Many is on a distinguished road
Default Cracked fitting-end of overflow hose
2001 SL2--I had a drip at the engine end of the hose leading from the overflow tank. When I tightened the clamp the fitting cracked. leaving a 1/4'' piece on the engine. Is this enough to reattach the hose, or how can I fix this? Thanks.
Add to SL2Many's Reputation
Rate the quality of this post and help SL2Many reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SL2Many is offline   Reply With Quote
Old 05-17-2011, 05:06 PM   #2
caveeagle
caveeagle is a glorious beacon of lightcaveeagle is a glorious beacon of lightcaveeagle is a glorious beacon of lightcaveeagle is a glorious beacon of lightcaveeagle is a glorious beacon of light
caveeagle's Avatar
Default Re: Cracked fitting-end of overflow hose
Are you talking about the fitting that is down below the Exhaust manifold next to the thermostat?
In any case, I would typically not trust a 1/4" remainder of a broken fitting. There might have been some corrosion or corruption that contributed to the fitting breakage in the first place. That would make me mistrust the last 1/4" even more. ....And now you have a much smaller attatching surface.
Add to caveeagle's Reputation
Rate the quality of this post and help caveeagle reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
caveeagle is offline   Reply With Quote
Old 05-17-2011, 07:15 PM   #3
^^^^ +1; keep in mind that this is NOT an overflow. It's part of the pressurized system. Needs to withdstand 15 psi. Best to replace the broken part. A pic would help identify it.
Add to madpogue's Reputation
Old 05-17-2011, 09:38 PM   #4
SL2Many
It's the nipple on the intake manifold. I hope that can splice it internally with a thinwall pipe unless someone has a suggestion. I'm trying to avoid replacing the manifold as it's not a DIY job for me; same goes for the repair kits on eBay.
Old 05-17-2011, 09:43 PM   #5
This is what you need to fix it. An internal pipe is at best a very temporary fix. Aluminum heads warp badly when all the coolant blows out and it will happen faster than the gauge will notice.
You need this piece to fix it correctly.
Intake repair
http://www.carsaturn.com/
Cracked PCV hose - would that cause a vacuum leak? acr2001 S-Series General 5 03-13-2014 09:38 PM
cracked hose bdobraj S-Series General 3 12-13-2009 06:14 PM
How should I repair a cracked PCV valve hose. oseberg S-Series Tech 13 11-25-2007 05:28 PM
brass fitting near oil cap on valve cover, where does hose go? mikes 1994 z28 S-Series General 1 08-05-2006 02:06 PM
95SL2 PCV square cornered "S" shape Hose cracked Luke S-Series Tech 15 07-06-2006 09:52 AM
