Old 04-04-2011, 02:54 PM   #1
paulo
paulo will become famous soon enoughpaulo will become famous soon enough
Default clunking noise in front end
1997 Saturn SL with 205,xxx miles. I have replaced both front wheel bearings and I replaced both front struts and I replaced both outer tie rod ends and had an alignment after those parts were replaced. When I removed the wheel knuckle to press out the old wheel bearings, the lower ball joints seemed okay, but obviously not as tight as a new ball joint. When I drive over a rough road I hear clunking noises coming from the front of the car. Almost as if there was play between two parts. Is there a common part that wears out on these cars with this milage? How would I go about checking these parts for play or looseness? Thanks
Add to paulo's Reputation
Rate the quality of this post and help paulo reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
paulo is offline   Reply With Quote
Old 04-04-2011, 06:23 PM   #2
Frankd1
Frankd1 is on a distinguished road
1998 SL1
Default Re: clunking noise in front end
Did you replace the front strut top mounts as well?
Add to Frankd1's Reputation
Rate the quality of this post and help Frankd1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Frankd1 is offline   Reply With Quote
Old 04-04-2011, 08:12 PM   #3
SRGW
1997 SL1
Post Re: clunking noise in front end
Replace sway bar to control arm end bushings and the clunk will go away. I had the same problem on my 1995 SL1. The new bushings are 2 piece and not too hard to install.
1995 SL1 178,500 and go'in strong!!
CHECK YOUR OIL!!!
Add to SRGW's Reputation
Rate the quality of this post and help SRGW reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SRGW is online now   Reply With Quote
Old 04-04-2011, 08:39 PM   #4
VUEmaniac
VUEmaniac is a jewel in the roughVUEmaniac is a jewel in the roughVUEmaniac is a jewel in the roughVUEmaniac is a jewel in the rough
You've covered some of the bases. There are other areas that can cause a "clunk."
1. Ball joints. Requires you replace the lower control arms. I'd do this first. For $30/side you can get them with the sway bar bushings already installed too.
2. Inner tie rods. You want to get under the car with the front wheels unloaded and see if you've got any "wiggle" in the tie rods. Try up/down and in/out.
3. Steering rack. Sometimes it's just a bad rack. Get the car up on a lift or on jack stands and have someone turn the wheel lock to lock and listen for the clunk.
Best,
Don't blame a clown for acting like a clown. Ask yourself why YOU keep going to the circus.
Add to VUEmaniac's Reputation
Rate the quality of this post and help VUEmaniac reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
VUEmaniac is offline   Reply With Quote
Old 04-05-2011, 08:16 AM   #5
paulo
Thanks for your replies. I did not replace the top strut mounts when I bought the new KYB struts. The lower ball joints are the original ones that came with the car. I will check for play in the steering rack inner and outer tie rod ends.
Would you purchase the lower ball joint part that includes the bushings from Rock Auto Parts and if these parts are replaced, do you need a new alignment done?
Update on rattling/clunking noise front end Dennis6 2008 Vue 42 04-24-2014 04:34 PM
Clunking Noise lbfoto S-Series Tech 1 11-28-2009 04:12 PM
Clunking Noise lbfoto L-Series Tech 2 11-28-2009 03:48 PM
clunking noise in front end spikeo2001 S-Series Tech 4 10-03-2009 09:14 PM
weird clunking noise in front sc2095 S-Series Tech 4 01-25-2004 09:28 PM
