Old 03-27-2011, 09:10 AM   #1
jgcox6
jgcox6 is on a distinguished road
Default Spindle Design/Material flaw?
My 95 SC2 has recently gone through 3 control arms, tie rod ends and now just replaced the cv joint on the passenger side. After much research for parts and history of spindle replacements, apparently the passenger side spindle is a weak link on saturn s series. I have found that most junkyards are missing the passenger side spindle.
That brings the question....why is the passenger side spindle the one that goes out so much. When i examined mine...the ball joint to spindle connection is where the spindle gets worn out (gets bigger than the original hole for the ball joint). IS the spindle metal at that point cheap metal? Is it that the engine is heavier on that side and maybe they under engineered the spindle?
Would love to hear your opinions....
Add to jgcox6's Reputation
Rate the quality of this post and help jgcox6 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jgcox6 is offline   Reply With Quote
Old 03-27-2011, 09:35 AM   #2
Default Re: Spindle Design/Material flaw?
Well, have you looked under the hood? You wouldn't expect something on the passenger side to have all it's weight on the driver side would you?
Last time I went to a yard they were all fairly intact, not much taken & they all had their spindles.
Old 03-27-2011, 12:51 PM   #3
Low Saturn
Low Saturn's Avatar
2007 AURA XR
Where did you get this incorrect information? I've owned 25+ S-Series Saturns since 1993, and have worked on countless others. Probably numbering in the hundreds. Never had or seen the issue you describe.
Never seen that either. Between the three yards I frequently visit, which usually have 75-100 S-Series between them, none are missing one side over the other.
Maybe its not being torqued correctly during installation allowing to wobble and wear?
Mike
-1991 Turbo SL2.
11.809 @ 116.488 mph
www.differentracing.com
-2001 Chevrolet Suburban
-2007 Saturn Aura XR
Old 03-27-2011, 09:35 PM   #4
jgcox6
I live in the Memphis, TN, area and trust me the boneyards around here are missing right hand spindles. I am glad to hear that it is not a huge problem elsewhere...strange...but glad. I do have a question about the spindle torque...is it the same torque on all the saturns...55ftlbs?
Old 03-28-2011, 12:59 AM   #5
SaturnFix
SaturnFix will become famous soon enoughSaturnFix will become famous soon enough
SaturnFix's Avatar
It is 55 lbs/ft if you're still using the castle nut that came on your '95. The failed knuckle(s) were most likely caused by using a premium spark plug.
What is your Saturn's oil economy?
Canada Saturn owners REVOLT!!! Improper factory spark plugs! c.c
If you are in the Southern Wisconsin area, check out: facebook.com/SaturnFix
Add to SaturnFix's Reputation
Rate the quality of this post and help SaturnFix reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SaturnFix is offline   Reply With Quote
Center pillar trim design flaw BobbyP Aura General 13 11-27-2007 12:16 AM
2006 VUE Flaw in Design cjbondra Vue Tech 22 07-03-2007 06:28 PM
VUE rear wiper = design flaw timothyhorning Vue General 17 03-05-2007 01:31 AM
Design Flaw? KGB Vue General 6 09-08-2006 01:00 AM
And you think the VUE's roof rails have a design flaw... skijay Vue General 35 09-09-2005 01:32 AM
