Old 03-25-2011, 02:36 PM   #1
Luke
Luke's Avatar
Default Front wheel bearings: Ball or Needle bearings ??
If I may ask, for confirmation, the wheel bearings for the front assemblies, are those bearings roller ball bearings or needle bearings (like one would see in a u-joint) ??
Thank you all.
Add to Luke's Reputation
Luke is offline   Reply With Quote
Old 03-25-2011, 02:42 PM   #2
MikeNW
MikeNW's Avatar
1997 SL
Default Re: Front wheel bearings: Ball or Needle bearings ??
I think they are ball bearings. Next, how do they assemble them...
08 Burgman 400
Add to MikeNW's Reputation
Old 03-25-2011, 03:01 PM   #3
dcc81187
dcc81187 is on a distinguished road
1996 SC1
They are ball bearings and you will need a press to assemble them.
Add to dcc81187's Reputation
Rate the quality of this post and help dcc81187 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dcc81187 is offline   Reply With Quote
Old 03-25-2011, 06:50 PM   #4
It is a zero clearance double row ball bearing.
Old 03-25-2011, 09:18 PM   #5
SaturnFix
SaturnFix will become famous soon enoughSaturnFix will become famous soon enough
SaturnFix's Avatar
They ought to have used roller bearings. I guess they figured it was such a light car...
Wow! 646,147 miles on the odometer?
What is your Saturn's oil economy?
Canada Saturn owners REVOLT!!! Improper factory spark plugs! c.c
If you are in the Southern Wisconsin area, check out: facebook.com/SaturnFix
Add to SaturnFix's Reputation
Rate the quality of this post and help SaturnFix reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SaturnFix is offline   Reply With Quote
Old 03-25-2011, 09:30 PM   #6
For a while there was an aftermarket high performance replacement wheel bearing that used rollers, epic FAIL.
There is about 750lb on the ground at each front wheel.
Old 03-25-2011, 09:31 PM   #7
SaturnFix
SaturnFix's Avatar
Chinese?
Old 03-25-2011, 10:20 PM   #8
Chazberry
Chazberry's Avatar
1995 SW2
My sentiments exactly!
Add to Chazberry's Reputation
Old 03-25-2011, 10:29 PM   #9
Chinese?
I forget where the aftermarket part was made. It was one of those things that looked real good on paper but did not work in practice. I have all the numbers and the manufacturer written down somewhere. One of the problems with the double roller bearing was establishing the proper bearing preload.
Old 03-26-2011, 08:00 AM   #10
Tommie
Tommie is a jewel in the roughTommie is a jewel in the roughTommie is a jewel in the rough
1996 SL1
2002 SL1
From my understanding of varying loads, ball bearings are best?
Roller bearings are stronger in one direction but isn't in side loading they are weak?
Add to Tommie's Reputation
Rate the quality of this post and help Tommie reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Tommie is offline   Reply With Quote
Old 03-26-2011, 09:04 AM   #11
The roller bearing aftermarket assembly used a tapered roller at an angle to the wheel axis. The problem was the difficulty of controlling the preload on the assembly. As I understand it there was a high failure rate in actual use and a short service life. The original idea was to come up with a wheel bearing that would out last the OEM service life.
Old 03-26-2011, 03:46 PM   #12
Luke
Luke's Avatar
Fm > Old Nuc
Thank you very much -- we simply never stop learning, from long term members on this sight.
Old 03-26-2011, 08:25 PM   #13
SaturnFix
SaturnFix's Avatar
Consider race cars, agricultural, construction, etc. Wheel bearings are one of the most stressed components, after brake pads. I'm talking constant abuse on a paved oval track. Maximum lateral G's. Back-to-back pairs of tapered roller bearings for wheel bearings. They provide the race-proven radial and axial durability needed to last. They probably just aren't quiet enough for a lightweight Saturn.
Front wheel bearings MikeNW S-Series Tech 12 09-15-2010 06:49 PM
Front Wheel Bearings going? 01SuperCoupe S-Series Tech 3 02-21-2009 02:02 AM
front wheel bearings vtsl2 S-Series Tech 13 01-03-2009 07:30 AM
Front wheel bearings for 97 SL2 SilverBullit S-Series Tech 16 02-21-2004 01:48 PM
wheel bearings front kkbucs S-Series Tech 1 11-18-2001 01:51 AM
