Old 01-20-2011, 10:56 PM   #1
mfedenko
mfedenko has a spectacular aura aboutmfedenko has a spectacular aura about
mfedenko's Avatar
Default Left side, front & rear turn lites remain on
After shutting engine off.
This is on dear old Mom`s `08 XE with 10k miles on it. First "problem" with the car so far. A restart cleared the condition.
Not sure if this is related but she mentioned having some difficulty turning the ignition key to the "start" position also. These 2 things happened simultaeneously.
Does this sound familiar? I normally hang with the S Series crowd and know very little about the Astra line.
TIA
Add to mfedenko's Reputation
Rate the quality of this post and help mfedenko reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mfedenko is offline   Reply With Quote
Old 01-20-2011, 11:35 PM   #2
gazingwa
gazingwa is on a distinguished road
2008 Astra XR
Default Re: Left side, front & rear turn lites remain on
You must have hit the left turn signal switch, if you do that after you shut off, I think the door even has to be open, it will turn which ever signal you select on It is for safety on the side of the road.
Add to gazingwa's Reputation
Rate the quality of this post and help gazingwa reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
gazingwa is offline   Reply With Quote
Old 01-21-2011, 12:27 PM   #3
L200Pilot
L200Pilot is on a distinguished road
L200Pilot's Avatar
2008 Astra XR
2002 L-Series 2.2L Sedan
And the steering wheel lock is somewhat picky about letting you turn the key. Make sure the steering wheel isn't agaisnt one of the stops when she's turning the key.
The family:
1993 SL2: 051,000 mi (!)
1996 SL2: 260,000 mi (sold)
2001 SL2: 98,000 mi
2002 L200: 215,000 mi
2006 VUE: 50,000 mi (sold)
2007 Ranger: 40,000 mi
2008 Astra: 161,000 mi
Add to L200Pilot's Reputation
Rate the quality of this post and help L200Pilot reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
L200Pilot is offline   Reply With Quote
Old 01-21-2011, 01:45 PM   #4
emg77
emg77 has a spectacular aura aboutemg77 has a spectacular aura aboutemg77 has a spectacular aura about
emg77's Avatar
2008 Astra XR
Yep, and the car will beep after you hit the turn signal. Also, if you hit the brights as you exit, the headlights come on and stay on for 15 seconds or so after you exit the car.
Drives: 2014 Volt, 2017 Acadia
Past Cars: 08 Astra, 15 Acadia, 12 Enclave, 09 Traverse, 05 Vue, 04 Grand Prix, 00 Alero, 97 LeSabre, 72 Cutlass S
Add to emg77's Reputation
Rate the quality of this post and help emg77 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
emg77 is offline   Reply With Quote
Old 01-21-2011, 02:05 PM   #5
mfedenko
mfedenko's Avatar
Thanks for the suggestions. I can see how the turn signal could have been snagged while dear old Dad (83yo) was exiting the car.
Can this be a case of an "un-documented feature"?
I`ll try to recreate the condition come Sunday and will post my findings
BTW, they absolutely love the car!
Old 01-21-2011, 03:24 PM   #6
Swordfish
Swordfish is on a distinguished road
Swordfish's Avatar
2009 Astra XE
There are actually a few undocumented features on the Astra... There is a post somewhere on the forumthat lists them, check it out!
Add to Swordfish's Reputation
Rate the quality of this post and help Swordfish reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Swordfish is offline   Reply With Quote
Old 01-21-2011, 09:57 PM   #7
Astra La Vista!
Astra La Vista! has a spectacular aura aboutAstra La Vista! has a spectacular aura about
Astra La Vista!'s Avatar
2008 Astra XR
"Undocumented", because it's more of a European thing. With the ignition off (and I believe the key out of the ignition), flipping the signal arm either left or right triggers the signal lights on that side of the car to come on and stay on. Useful when parked along the side of a dark road at night. I can see how just a single "solid-on" light would be less distracting than using your hazard lights under the same circumstances, since the latter was originally designed to signal an emergency.
Flipping the high beams after you've shut off the car (and removed the key) turns on all the exterior lights for about 30 seconds. Useful when parking outdoors at night and need a little extra illumination when walking up the driveway towards the house.
"That's a Hruck Bugbear, manufactured in Eastern Europe in the eighties and imported to the States. People mock it as a poor man's Yugo. I consider it the pinnacle of Cold War Balkan engineering."
Add to Astra La Vista!'s Reputation
Rate the quality of this post and help Astra La Vista! reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Astra La Vista! is offline   Reply With Quote
Old 01-21-2011, 10:13 PM   #8
NJastra
NJastra is on a distinguished road
NJastra's Avatar
2008 Astra XR
If there's a problem turning the key in the ignition, just turn the steering wheel slightly to the left or slightly to the right while turning the key. That should do the trick.
-Jon-
3 dr XR, Twilight Blue, 5 speed manual, 18" 5-star rims, Leather trim package, Heated seats, VXMMI (Advanced Audio)
2017 Regal GS, 20", fully loaded
1987 Z28 - modded
Add to NJastra's Reputation
Rate the quality of this post and help NJastra reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
NJastra is offline   Reply With Quote
Old 01-21-2011, 10:19 PM   #9
mfedenko
mfedenko's Avatar
Thanks for pointing that out. I imagine that the full on, turn signal light would shut itself off after a few seconds?
Old 01-21-2011, 11:16 PM   #10
Swordfish
Swordfish's Avatar
2009 Astra XE
No, the side indicator, when activated for safe parking, is on until it is manually turned off... either by hitting the stalk again, or by turning the car on. From what I gathered though, it can be left on overnight with no issues concerning battery life, which is what I think you were getting at!
Marc-Antoine
2009 Astra XE 5-door, Twilight Blue.
"I have four rules in the Astra. No food, no drink, no smoking, and no vomit. Got it? Now... let me just put my coffee in the cup holder..."
Old 01-24-2011, 08:58 AM   #11
tackepj
tackepj will become famous soon enough
tackepj's Avatar
2008 Astra XE
Yeah, I remember a buddy's VW Rabbit had the same feature, either very common or a requirement of Euro cars. I used it once when I was parked on a dark street while moving cars around the driveway. I gave up after I was politely told twice by passersby that I had left my headlights on.
Former: 2005 L300, 2007 VUE Green Line
Current: 2008 Astra XE
Add to tackepj's Reputation
Rate the quality of this post and help tackepj reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
tackepj is offline   Reply With Quote
Old 01-24-2011, 01:18 PM   #12
mfedenko
mfedenko's Avatar
Mission accompished! Thanks for your help guys, everything is all good now and my folks (and I)can rest easily.
My left turn light (rear only) won't work SC Saturn Owner Ion General 14 11-17-2008 09:28 PM
Turn signal bulb, left front ems1 Vue Tech 3 10-03-2006 09:24 AM
SL2 griding noise from front end on Left turn snowman07 S-Series General 6 09-21-2006 08:36 PM
Front left turn signal won't blinking tran56 Ion Tech 8 06-06-2006 05:28 AM
screeching from front left side nathy0004 S-Series Tech 1 05-31-2003 12:13 PM
