Old 08-13-2010, 08:23 PM   #1
sl2solow
sl2solow is on a distinguished road
Default well i got a new problem named click-click- click-click- click-click- click
hello to all, let me get to the point, when i turn my car on i get no noise but if i turn my ac on and my wheel left or right i get this noise from the front of the car, its not that bad but loud enough to here on the out side of the car but not the inside ne1 know whats going on. Thanks sounds like
click-click- click-click- click-click- click-click- click-click-click-click- click-click- click-click- click-click- click-click-click-click- click-click- click-click- click-click- click-click-click-click- click-click- click-click- click-click- click-
and does not change as in louder or lower. stays the same and ac works just fine.should i be weoried or not.
Add to sl2solow's Reputation
Rate the quality of this post and help sl2solow reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sl2solow is offline   Reply With Quote
Old 08-13-2010, 08:54 PM   #2
Default Re: well i got a new problem named click-click- click-click- click-click- click
Does the rate of click change with road speed, or engine speed?
Old 08-13-2010, 08:57 PM   #3
AndreasChen
AndreasChen is on a distinguished road
Sounds like a loose belt or bad tensioner/idler
02 Saturn SC2, noisy, trying to quiet it down...
Add to AndreasChen's Reputation
Rate the quality of this post and help AndreasChen reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
AndreasChen is offline   Reply With Quote
Old 08-13-2010, 10:49 PM   #4
Yes, that is the likely cause but it could also be an exhaust shield. If it is a belt then the click rate will be RPM dependent. If it is something in the drive line than it will be road speed dependent.
Not starting. Single click. Now no click clean93 S-Series Tech 4 12-03-2008 03:02 PM
Click, click, click goes the dash! skid_marque Vue General 11 05-05-2008 10:26 AM
"Click, Click, Beep." What is that? Commando44 S-Series General 15 11-09-2007 04:59 AM
My Vue goes...Click, Click, Click-click GirlWithAVue Vue General 17 02-24-2006 05:54 AM
