Old 08-13-2010, 07:23 PM   #1
Gheuett
Gheuett has a spectacular aura aboutGheuett has a spectacular aura about
Gheuett's Avatar
2003 ION-2 Sedan
Default 2003 Vue Timing Belt Questions
Welcome back my friends to the show that never ends..
Hi All,
I'm now working on part two of my 100K maintenance though it is a bit late (141K)! A few weeks back we did the plugs and thermostat etc thanks to a lot of help from many of you on this forum. Now I am working on the water pump timing belt portion.
I have worked my way down to the adjusting the crankshaft to 60 degrees BTDC. I think I have it pretty straight on the mark.
My question has to do with the alignment marks on the cams. I have posted pictures so hopefully you can see.
1 is the Crankshaft lined up
2 & 3 are the cams on the front side of the vehicle
4 & 5 are the cams on the back side.
The marks on the front cams seem to be a tooth back of the marking notch. The marks on the back cams seem to line up pretty well with the marking notches. From what you can see is that normal and am I at the point where I can lock them down and begin taking the belt off?
By the way - the belt is not too horrible a shape for 141K miles. The serpentine belt was in really amazing shape. It has had a lot of highway miles so I'm assuming that helped.
I can shoot additional pictures if these don't provide enough detail.
Thanks!!
Gib
Add to Gheuett's Reputation
Rate the quality of this post and help Gheuett reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Gheuett is offline   Reply With Quote
Old 08-14-2010, 12:50 AM   #2
Chazberry
Chazberry's Avatar
1995 SW2
Default Re: 2003 Vue Timing Belt Questions
Looks close enough to me. Get some white-out or something and mark the old belt where it matches the marks on all the sprockets and after you remove the old belt, see how those marks compare to the marks on the new belt.
Mine still looked new at 93K. I bet they can go 150k no problem - but who wants to take a chance?
Add to Chazberry's Reputation
Old 08-14-2010, 01:12 AM   #3
bern
bern is a glorious beacon of lightbern is a glorious beacon of lightbern is a glorious beacon of lightbern is a glorious beacon of lightbern is a glorious beacon of light
2004 ION-2 Sedan
thier is a tool set to hold the cams from turning when the belt is removed. aftermarket belts still have alignment marks on then. the tensioner pulley fail, it should be replaced. also mark the 2 idle pulley tension location.
Add to bern's Reputation
Old 08-14-2010, 01:58 AM   #4
Chazberry
Chazberry's Avatar
1995 SW2
Cam Lock J-Tool
Old 08-14-2010, 09:43 AM   #5
ernesto rex
ernesto rex is on a distinguished road
ernesto rex's Avatar
2000 L-Series 3.0L Sedan
Gheuett,
Your marks are lined up exactly like mine where on my 2000 LS2 before pulling the belt off. I most definitely agree with Chazberry on using a white paint pen to mark the heck out of your old timing belt before removing it. It helps with the confidence factor when putting the new one on.
Chazberry,
I love your cam lock tool and will use it on my 03 Vue timing belt job next month. I used the zip tie method on my LS2 and had some minor movement of the no. 4 camshaft when the old belt came off.
ernesto
2000 LS2
2003 VUE 3.0 FWD
2002 MINI Cooper R50
1978 GMC PU 7.4L
Add to ernesto rex's Reputation
Rate the quality of this post and help ernesto rex reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ernesto rex is offline   Reply With Quote
Old 08-14-2010, 10:05 AM   #6
Chazberry
Chazberry's Avatar
1995 SW2
Originally Posted by ernesto rex View Post
Chazberry,
Thanks Ernesto - necessity is the mother of invention!
Later for all those over-priced J-tools!
Old 08-14-2010, 02:13 PM   #7
Gheuett
Gheuett's Avatar
2003 ION-2 Sedan
Thanks Everyone!
Glad to know I've got it in the right place. I'm definitely going with Chaz's bolt method. That seems like the safest way to protect the cams but put plenty of pressure on them. The new belt has good markings so I'll do the white out thing and compare.
I did get the kit with the replacement pulleys. By the way - for future reference, everyone on-line (RockAuto et al) was out of the belt kit and they had long waits on getting it. NAPA had it here but they wanted $309. The cheapest price on the internet was $185. They matched it when I brought in a printout from that site.
I was shocked.
Before I go further with the removal of the belt, I'm going to slap on the new water pump.
Appreciate everyone's help!!
Gib
Old 08-14-2010, 11:42 PM   #8
Chazberry
Chazberry's Avatar
1995 SW2
I guess a lot of L81s coming up on 100k at the same time! I couldn't believe it when you said 6 wks delivery! Kudos to NAPA! They must make some profit at $309 if they were willing to discount it that much!
Old 08-15-2010, 09:02 AM   #9
Gheuett
Gheuett's Avatar
2003 ION-2 Sedan
In addition, Napa was the the only local shop that could find me the E-20 Torx socket that worked great on the crankshaft. I checked a lot of places including the hardware stores that usually had the odd tools.
They definitely won me over for sure.
Old 08-15-2010, 02:06 PM   #10
Chazberry
Chazberry's Avatar
1995 SW2
Too bad - I could have told you some standard socket fit on there well-enough.
Old 08-15-2010, 03:30 PM   #11
Gheuett
Gheuett's Avatar
2003 ION-2 Sedan
I remember seeing some alternatives but one person mentioned almost stripping the bolt so I figured I'd be safe and go with a Torx socket.
Thanks though!
Gib
Old 08-16-2010, 04:07 PM   #12
Gheuett
Gheuett's Avatar
2003 ION-2 Sedan
OK - back to the drawing board.
Got the old belt off, matched up the white out lines with the new belt and installed it with the lines matching the old. On the new belt, yellow lines matched on cam 1/2 and single white lines matched on 3/4. Double yellow lines on the bottom of the loop lined up with the crankshaft marks at 60 Deg BTDC.
I installed the new tensioner unit and using an allen wrench to move the tensioner and a 13 mm wrench to tighten the bolt, adjusted to the 1/8" mark they recommended. I tightened the pulley bolt to 15 ft lbs per the instructions.
It went awry on the crankshaft test. as I cranked, the tensioner pulley seemed to be slipping and did not appear to hold it's setting at all. Needless to say, when I got back around to my marks lining up on the cams, the belt marks were 5 notches ahead of where they were supposed to be. What concerns me is even with additional tightening along the way, it wasn't holding at all. The new tensioner unit was all assembled and is just bolt on so I don't think there is anything else to do to it.
I know I will have to pull the belt off and start over but I want to make sure I correct my error before doing all that again.
Appreciate any ideas.
Thanks!
Gib
Old 08-16-2010, 08:26 PM   #13
Chazberry
Chazberry's Avatar
1995 SW2
Gib - the marks on the TB are not going to stay with the marks on the sprockets. But after spinning the crank 720 degrees, the marks on the sprockets should be back in line with the cover notches. The tensioner setting dances all around as the crank turns because the cams will exert varying amounts of tension on the belt (I hope this is what you mean by "slipping"). The instructions I found said, "after making the initial tensioner adjustment, turn the crank 1-3/4 and re-adjust" and then you're good.
I don't think this will be necessary if previous makes sense to you.
Old 08-16-2010, 09:19 PM   #14
300maximilien
300maximilien is on a distinguished road
300maximilien's Avatar
2002 VUE 3.0L
IS there a How-to around here with instructions and pics on this? It's amazing how similar the Vue sounds to my 300M TB/WP service
2002 Saturn Vue V-6 81,000 miles
2002 Chrysler 300M Special 115,000 miles
1978 Dodge Li'l Red Express 78,000 miles
1997 Dodge Neon 2dr Sport 130,000 miles
Add to 300maximilien's Reputation
Rate the quality of this post and help 300maximilien reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
300maximilien is offline   Reply With Quote
Old 08-16-2010, 09:50 PM   #15
Chazberry
Chazberry's Avatar
1995 SW2
There's a great collection of good pics, unfortunately they're spread over a vast assortment of separate threads (e.g. http://www.saturnfans.com/forums/sho...d.php?t=157341). There's instructions for the L300 Timing Belt in the How-to Library (same L81), but I didn't any pics. Hopefully, someone, someday will compile all the best pics and assemble them into a first class step-by-step for the Library.
Old 08-17-2010, 08:35 AM   #16
Gheuett
Gheuett's Avatar
2003 ION-2 Sedan
Agree - there are great pieces of info scattered about. I found it useful to create a word document and copy and paste info together. Though it is scattered info, it is at least in one document. I would be happy to e-mail it to anyone if you like. It's just a bunch of different posts pulled together but it might be useful.
Chaz, you explained it perfectly. I think I had the image of the tensioner functioning much like an idler pulley on a serpentine belt. Once you set those, they are more static and don't have the kind of movement that I was seeing as I turned the crankshaft. When I turned the crankshaft to 60 deg. BTDC the cam marks did line up with the notches. The marks on the belt spooked me.
By the way - in your honor, I believe on this forum we should hereby refer to your cam locking system as "Chazlocs." Those bolts worked great and the cams didn't move a bit.
Many thanks again!!
Gib
Old 08-17-2010, 09:27 AM   #17
Routs
Routs is on a distinguished road
Routs's Avatar
In the interest of pure laziness, what is the size of the nut and bolt set that you guys used?
Add to Routs's Reputation
Rate the quality of this post and help Routs reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Routs is offline   Reply With Quote
Old 08-17-2010, 09:30 AM   #18
Chazberry
Chazberry's Avatar
1995 SW2
Glad to hear your concerns are eased. And thanks for that nomination - I'm very honored!
Old 08-17-2010, 09:33 AM   #19
Chazberry
Chazberry's Avatar
1995 SW2
5/16 seemed to be good - probably not critical though.
Old 08-17-2010, 11:10 PM   #20
300maximilien
2002 VUE 3.0L
I belong to a 300M Forum and there as well as a few other Forums I belong to have a How-To topic where members post detailed how-tos on some of the most basic and critical maintenance. When I first joined this site I *thought* the Vue Tech Topic would be this......maybe this is something that could be added here?
2003 Vue V6 Timing Belt and Other Parts Replacements Gheuett Vue Tech 11 01-17-2015 01:08 PM
timing belt needs done I have questions. rlhdghhmh S-Series Tech 9 08-21-2009 02:45 PM
Vue timing belt replacement, 2003 V6 claw218 Vue Tech 6 02-03-2007 12:27 PM
Timing belt questions for my SL2 95K miles 1995 jimtmcdaniels S-Series General 3 06-11-2005 02:08 PM
2000 LW2 timing belt questions... ronp L-Series Tech 11 12-06-2004 05:02 AM
