Old 02-03-2010, 08:54 AM   #1
alltrac88
alltrac88 is on a distinguished road
Default 97 sl2 just died
my fiance was driving about 30 and her car's engine just cut off. All the accessories and lights were still on. The battery and alternator are fine and she had enough gas. When we tried to start it up it just cranks and cranks forever. The check engine light has been on for about a year all it says is cylinder 1 random misfire. Ive changed the plugs countless times, and ign coil. Before this happened when you press the gas lightly the whole car shakes but when you floor the gas its smooth. And at idle it shakes too but not as bad. Please help it wont start for nothing.
Add to alltrac88's Reputation
Rate the quality of this post and help alltrac88 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
alltrac88 is offline   Reply With Quote
Old 02-03-2010, 09:56 AM   #2
hoseppi
hoseppi will become famous soon enough
hoseppi's Avatar
2002 SL1
2008 Astra XE
Default Re: 97 sl2 just died
First guess would be the CPS- if its not getting any spark. If it's not getting any fuel it would probably be the fuel pump. We really need more symptoms. Are you getting any spark? Usually you can hear the fuel pump-do you?
Add to hoseppi's Reputation
Rate the quality of this post and help hoseppi reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
hoseppi is offline   Reply With Quote
Old 02-03-2010, 11:49 AM   #3
bumpdraft
bumpdraft's Avatar
1998 SW2
Guess:
Are the plug wires routed correctly?
My dad had symptoms very similar and it was the ignition cables (plug wires).
Add to bumpdraft's Reputation
Old 02-03-2010, 11:53 AM   #4
alltrac88
ok i have never changed the cps before. but its not one of the engine codes that came up. and the timing chain is fine just checked that. and the wires should be routed correctly, theyre all different lengths and they are connected according to their lengths. you know what i mean? and i believe i hear the fuel pump when i turn the key but im not sure
Old 02-03-2010, 11:55 AM   #5
alltrac88
but i dont think it would be the cables if she was driving and it just cut off and didnt start again. We have driven with the cables the way they are for months
Old 02-03-2010, 11:57 AM   #6
alltrac88
how do i tell if i have spark?
Old 02-03-2010, 12:11 PM   #7
hoseppi
hoseppi's Avatar
2002 SL1
2008 Astra XE
Find a spare spark plug(remove one if you don't have a spare) with the correct gap,hook one of your plug wires to it, and lay it on a metal part of the motor. Now have someone crank the engine as you watch the electrode end of the plug. You should see a bright bluish white spark. Since you now have an assistant, have them turn the key to the off position and then back to the on position as you listen to the fuel fill spout(open fuel door and remove cap). You should be able to hear the fuel pump run for 2-3 seconds each time the key is turned to the run position.
Old 02-03-2010, 12:13 PM   #8
alltrac88
thanks im going to try those things
Old 02-03-2010, 12:19 PM   #9
adventureoflink
adventureoflink's Avatar
An easier way to do this would be to remove the wires from the #4 and #1 ignition coils (noting firing order), then try starting the engine. If you see a spark across the towers, then you have spark.
97 SL2
DOB: 3/19/97
Date Obtained: 5/30/07
Status: Alive, 1/2 exhaust
2004 Merc G.Marquis GS
DOB: 2/4/04
Date Obtained: 7/6/12
Status: Alive, no heat
Old 02-03-2010, 12:47 PM   #10
alltrac88
what could be wrong if the fuel pump turns on and i have spark?
Old 02-03-2010, 01:10 PM   #11
alltrac88
alright i tested the fuel pump and it works fine. So i guess all that leaves is spark. Im going to test that a little later. And if i have no spark do i need a cam position sensor or a crank position sensor? And what happens if i have spark too?
Old 02-03-2010, 01:18 PM   #12
adventureoflink
If you have no spark, you need a CRANKSHAFT position sensor, most likely.
If you have spark, further troubleshooting is needed.
97 SL2
DOB: 3/19/97
DOB: 2/4/04
Old 02-03-2010, 01:55 PM   #13
You'll find the crankshaft position sensor behind and above the starter, mounted with one 10mm bolt. Buy it from any auto store stocking it.
To be absolutely sure its the cps, remove all the spark plug wires from the two ignition coils and watch for spark across the coil towers as someone turns the ignition key to the START position. The total lack of spark is from a failed cps. A (distant) similar failure would be the ignition control module; it holds the two ignition coils. More cps' fail than ignition control modules.
Old 02-03-2010, 02:41 PM   #14
Leafy
Leafy is on a distinguished road
Leafy's Avatar
this is a good way to kill your coils and ICM, dont do it this way, ever. let the spark jump between the two posts on the same coil.
1994 SL2 HCE auto 113 hp 113 lbft (wheel) backup car
2002 Chevy Cavalier SS
For Sale: FlyWheel, Shifter assembly, Clutch Hydros, 1st gen 5 spd PCM. PM me for prices.
WPI class of '12 ME
Add to Leafy's Reputation
Rate the quality of this post and help Leafy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Leafy is offline   Reply With Quote
Old 02-03-2010, 05:17 PM   #15
hoseppi
hoseppi's Avatar
2002 SL1
2008 Astra XE
So testing your spark through a sparkplug will blow out your coil and icm...hmmmm- I always thought that was the way the ignition system worked. I do it all the time and I haven't lost one yet.
Old 02-03-2010, 05:25 PM   #16
Leafy
Leafy's Avatar
yes because the plugs ground through the threads and into the cylinder heads and even with the threads touching something metal you wont get a good enough ground. but those coil can still put out enough energy to make a spark there, just not the best thing for them.
WPI class of '12 ME
Old 02-03-2010, 05:51 PM   #17
adventureoflink
Oh yeah, about CAMSHAFT Position Sensors... our Saturns DO NOT have them. Generally, 9 times out of 10, if you get a CAMSHAFT code, it's time for new plugs/wires.
Just thought I'd clear this up for ya.
97 SL2
DOB: 3/19/97
DOB: 2/4/04
Old 02-03-2010, 05:53 PM   #18
Leafy
Leafy's Avatar
and this is because our icm reads the inverse spark on the #4 (or is it #1) piston and sends that to the pcm as if its a camshaft position sensor.
WPI class of '12 ME
Old 02-03-2010, 06:00 PM   #19
MikeNW
MikeNW's Avatar
1997 SL
"Before this happened when you press the gas lightly the whole car shakes but when you floor the gas its smooth"
that is from the original post. So, did we rule out the TPS as a problem?
If the OP fixed the problem, what was it, we'd like to know.
08 Burgman 400
Add to MikeNW's Reputation
Old 02-04-2010, 08:11 AM   #20
alltrac88
alright guys thanks for all the responses. i went to advance auto and bought a spark tester because someone said it could damage the coils if i didnt. And what do you know i have no spark at all. I tested cyl 1 wire from coil 1 and cyl 2 wire from coil 2 just to be sure it wasnt just a coil. So i guess that means I need a crankshaft position sensor.
Another question though: would a faulty cps make the car shake alot when you lightly press the throttle and shake a little at idle and it doesnt shake at all when you fully press it? Or does it need a tps as well?
Need Help, SL2 Died... anarsil53117 S-Series General 5 06-08-2008 11:51 AM
OMG! My car just died on me out of nowhere! Killah_Trakz S-Series General 18 11-18-2005 11:21 AM
New VUE Died Ryster Vue General 18 08-26-2003 04:14 PM
Car Died, Please help SIYAM Miscellaneous Tech 16 05-26-2002 11:15 PM
The Car just DIED ! SlwDeth S-Series Tech 9 01-02-2001 10:38 PM
