Old 01-07-2010, 06:29 PM   #1
jimltz
jimltz is on a distinguished road
Default engine heater for an 09 Aura with the 3.6L
Anyone install an engine heater on their Aura? I'm thinking of a stick on pad type heater on the oil pan so I won't have to cut any hoses. With the all aluminum engine the magentic type heaters probably won't work.
Add to jimltz's Reputation
Rate the quality of this post and help jimltz reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jimltz is offline   Reply With Quote
Old 01-08-2010, 09:58 AM   #2
bc3tech
bc3tech will become famous soon enough
bc3tech's Avatar
2007 AURA XR
Question Re: engine heater for an 09 Aura with the 3.6L
why? I'm in MN where my Aura's seen -40 wind chills for multiple years w/o any startup issues.
+rep always appreciated!
The Procharged Ion - http://kickassion.bc3tech.net
16.317s @ 85.30mph (Nearly stock)
188.28whp / 175.03wtq - SMP Stage 2 - 10psi
Add to bc3tech's Reputation
Rate the quality of this post and help bc3tech reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bc3tech is offline   Reply With Quote
Old 01-08-2010, 11:04 AM   #3
gregh2000
gregh2000 has a spectacular aura aboutgregh2000 has a spectacular aura about
2007 AURA XR
Default Re: engine heater for an 09 Aura with the 3.6L
Same here in MN no problem starting up when parked outside in the super cold. Hasn't been exactly warm here lately.
The only issue I have with the cold is the door sensors freezing. At least the dome light turns off when you start driving even with the door ajar message, lol. I found you can reset that too with the reset key on the wheel.
Add to gregh2000's Reputation
Rate the quality of this post and help gregh2000 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
gregh2000 is offline   Reply With Quote
Old 01-08-2010, 11:30 AM   #4
onefunkar
onefunkar's Avatar
2008 Outlook XR
2007 AURA XR
mine stays out in minnesota also. always starts . its been as cold as 15 below. wind chilled doesnt matter to car just regular temp. actually i have a block heater from the factory but havnt used it.
Add to onefunkar's Reputation
Old 01-08-2010, 12:52 PM   #5
VWCarcrazy
VWCarcrazy is on a distinguished road
2008 AURA XE
Twin Cities, Minnesota (Wisconsin) here too. I have had several cars with factory block heaters over the years and have NEVER used a single one. They are a waste of electricity with modern fuel-injected engines. If you really want one, I would have your dealer install the factory unit. The only advantages it will give you is a slightly shorter heat-up time and a lighter wallet ($$$ for installing the unit and the power to run it). These are not cheap to run, unless you have a source of free electricity. Best luck.
2008 Aura XE 2.4L
Ocean Mist/Titanium
Add to VWCarcrazy's Reputation
Rate the quality of this post and help VWCarcrazy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
VWCarcrazy is offline   Reply With Quote
Engine block heater... from Honda! leogag1 Vue General 21 11-17-2018 12:35 PM
engine heater? myolbug S-Series Tech 21 01-07-2010 11:04 PM
Engine Block Heater Accessory Mark in INdiana Vue General 1 10-03-2005 09:51 PM
Engine block heater for SC2? 92 Coupe S-Series Tech 2 01-06-2005 11:20 PM
engine heater for winter etbardensc2 S-Series General 4 05-18-2004 02:50 PM
