Old 01-04-2010, 09:27 PM   #1
slimgoodie_5
slimgoodie_5 is on a distinguished road
1992 SL1
Default No heat..thermostat question
Ok i posted a similar question before but i now have another one. i flushed my radiator and replaced the thermostat in my 92 SL1. it seemed like the heat was working but it only lasted for a day or so. the hose that is coming from the thermostat takes a long time to get warm/hot unlike the hose that is coming from the top of the radiator. when a squeeze the hose from the thermostat my engine tends to idle up a lil bit. does that seem like something is wrong with the thermostat? the heat is barely working it just blows out warm air. any suggestions? i was told to put some cardboard over the radiator but with the SL1 i dont see a way to secure it. please help me with this since my wife drives this car more than i do and the next two weeks its suppose to be a cold one.
Add to slimgoodie_5's Reputation
Rate the quality of this post and help slimgoodie_5 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
slimgoodie_5 is offline   Reply With Quote
Old 01-04-2010, 10:23 PM   #2
doublemm
doublemm is on a distinguished road
Default Re: No heat..thermostat question
Check your coolant level. Esp if everything was working fine before you flushed it.
If you are just a quart or 2 low on coolant, you wont get much heat from the heater core.
Add to doublemm's Reputation
Rate the quality of this post and help doublemm reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
doublemm is offline   Reply With Quote
Old 01-04-2010, 10:54 PM   #3
original007
original007 is on a distinguished road
check the coolant temp in the bottle with a thermometer or if it does not seem hot,your finger. If it is hot you need to flush the heater core.If it does not get hot you have a thermostat issue.By flush I mean remove the hoses from the heater core and give it some pressurized water.Good Luck
Add to original007's Reputation
Rate the quality of this post and help original007 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
original007 is offline   Reply With Quote
Old 01-05-2010, 08:17 AM   #4
slimgoodie_5
1992 SL1
ok the coolant levels are fine, the temp stays at the half way make and the coolant in the reservoir overflow tank is warm/hot. so i guess i will need to get it flushed again? well this time i might take it to a shop to get it done? i did it with the pressured water but i guess it wasnt strong enough.
Old 01-05-2010, 11:14 AM   #5
First, I would check to make sure the flap that controls how much hot air is directed into the air ducts is working properly. Sounds like your coolant is getting plenty warm
You'll need to get up under the dash - when you move the heat lever back and forth, it moves a flap that lets more/less hot air into the ducts. I'm not familiar with 1st gen cars, but if you use the search feature, you may find some pictures/directions
you shouldn't need a lot of pressure to flush the cooling system, especially the heater core - too much pressure can actually damage it.
Flushing the heater core is different from flushing the cooling system. You remove the hoses to the core itself and backflush it. The normal cooling system flush does not remove all the water from the core.
no heat but thermostat at 1/4 mark Stingray S-Series Tech 4 02-15-2009 08:47 PM
Lack of heat...Thermostat? hd071502 Vue Tech 14 02-24-2008 09:59 AM
Does not heat up enough for thermostat to open jnk111 S-Series Tech 17 11-24-2007 08:44 AM
No Heat W/ Replaced Thermostat jinxx123 S-Series Tech 6 04-18-2006 04:30 PM
Question about heat and thermostat Spazie S-Series General 8 03-01-2005 05:35 AM
