Old 08-21-2009, 01:09 PM   #1
blooddrench
blooddrench is on a distinguished road
Default Swapping auto to Manual, Need help!
Hello,
I'm creating this post to ask for the help of the saturn minds here. I have a 2002 Saturn SL2 with 99k whose auto trans just went bad. to the tune of warn gears and slam shifting. 2300 at the dealership to fix. This wont even be considered being I've never taken my car in to be worked on. I found these.....
MANUAL TRANSMISSION Saturn S Series 98 99 00 01 02:eBay Motors (item 120451066027 end time Aug-21-09 10:07:41 PDT)
**edit** should I buy a mp2 already with a welded diff pin? or get the phantom grip? Where can i get a phantom grip and do i have to have the diff pin welded still?
This is the manual trans, I would like a mp2 because of the lower gear ratios. Would I be better off going to the pick-n-pull and pulling a trans? I hate going thru the work and taking off trans that is faulty to begin with.
Also, should i do the TSB about the pinion gear and shaft?
differentracing.com/tech_articles/TSB/99-t-12.html
and finally I would like a 6 puck clutch and an aluminum flywheel. I found this package.. What do you recommend?
F1 STAGE 3 CLUTCH KIT& ALUM FLYWHEEL 00-02 SATURN 1.9L:eBay Motors (item 400061816869 end time Sep-12-09 16:48:34 PDT)
I also read on a post that TSR made a conversion kit for all the other parts required but they are no longer online to my knowledge. And ooh yes I have most certainly read the Different Racing tutorial. Does anyone sell the parts in a kit, as in the linkage for the pedal/shifter/assorted pieces/etc? I also need to get a catalytic converter Because i already have 2 1/4 from the cat back, and i bought the OBX header last fall and thats been sitting in my closet.
I am also aware i need to weld the differential pin for best performance and would love some pointers there.
Also will the Automatic ECU be an issue? I know that the park/neutral safety switch needs to be addressed.
I appreciate any and all help. Thanks in advance.
Add to blooddrench's Reputation
Rate the quality of this post and help blooddrench reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
blooddrench is offline   Reply With Quote
Old 08-21-2009, 01:42 PM   #2
Low Saturn
Low Saturn's Avatar
2007 AURA XR
Default Re: Swapping auto to Manual, Need help!
1991-2002 will work.
Unlikely you will find one with the diff pin welded in place already. And dont bother with the Phantom Grip.
You'll save a bunch of money this way. With manual tranny's, if its doesnt have a hole in it, it's usually OK.
There are two designs. 1991-1998 and the updated 1999-2002 design. With the first design, diff pin failures a mostly caused by abuse or sudden loss of traction on both front wheels then suddenly gaining traction of one wheel. With the newer "better" design, the diff pins can come out whenever they feel like seeing the light of day.
Unless you plan on a high horse power turbo or nitrous build motor, get a stock flywheel and aftermarket stock replacement clutch/pressure plate. The six puck clutch an aluminum flywheel are a waste of money for your application.
Cool. I'm happy we're able to help you.
Nope
See my website for tranny disassembly.
http://www.differentracing.com/tech_...sassembly.html
I wouldn't recommend it. Performance will slightly suffer plus you run the risk of over revving the engine and BOOM.
Mike
-1991 Turbo SL2.
11.809 @ 116.488 mph
-2001 Chevrolet Suburban
-2007 Saturn Aura XR
Old 08-21-2009, 01:52 PM   #3
Wasn't the mount point for the ignition module different in '91? 'Course, the likelihood of the OP finding a good tranny from a '91 in a yard is slim
Not to mention the SES light will be on perpetually.
As for the neutral switch, it doesn't go thru the PCM. That's just a simple set of contacts on the switch on the automatic tranny. On that connector, it's either two purple wires, or purple and yellow. Just jumper those two leads, either with a short piece of wire with two male terminals, or a 30A maxifuse that happens to fit the connector, or cut and solder and heat-shrink insulate.
Add to madpogue's Reputation
Old 08-21-2009, 01:52 PM   #4
blooddrench
alright then, i'll hit a pick n pull this week probably, If i snag a manual ECU, does it have to be for the specific manual tranny? also do i need to get a new wiring harness? Thanks for the help
Old 08-21-2009, 02:03 PM   #5
The PCM doesn't talk to the manual tranny, but it needs to be for a DOHC engine. And as mentioned above, you should get the BCM from the same car.
Old 08-21-2009, 02:20 PM   #6
Low Saturn
Low Saturn's Avatar
2007 AURA XR
The ignition modules mount in the same spot for all years. In 1996 they were turned 180 degrees. But there is a provision for the front mount used only in 1991's that can get ing the way of the 1996+ ICM's because the electrical connector is on the bottom rather than the top. Even though only 1991's used this mount, I think the provision for it is on tranny's up until 1993. It can be cut off though. I've put a 1992 manual into a 1999. I just cut off the mount.
For stuff like this, even though old stuff will work, you always want to find the newest one with the least amount of miles on it. Especially if junkyards there are like the ones here where year or mileage doesnt effect the price.
Mike
-1991 Turbo SL2.
Old 08-21-2009, 02:23 PM   #7
Low Saturn
Low Saturn's Avatar
2007 AURA XR
You should get a PCM from a 2002 SL2, SW2 or SC2 with the same options as your car. No need for the wiring harness, but like madpogue said, grab the BCM too. Its under the top dash pad, towards the center of the car, attached to the frame cross member.
Mike
-1991 Turbo SL2.
Old 08-21-2009, 05:45 PM   #8
blooddrench
Alright, I am getting the all the parts shipped to me not including the trans, clutch and flywheel. I for sure want an aluminum flywheel. I've seen fidanza and F1 Racing. Is there anything wrong with f1 racing or are they subpar quality? they dont look as beefy as the fidanza flywheel. does anyone have feedback on these? And what does the community recommend for a moderately modified saturn clutch? I saw exedy oem clutch and F1 has a few options.
Old 08-21-2009, 07:11 PM   #9
PurdueGuy
PurdueGuy's Avatar
1999 SC1
Actually, I can tell that that isn't true from experience.
Light bulbs burn out eventually. lol
SaturnSeries.net owner
Add to PurdueGuy's Reputation
Old 08-22-2009, 12:33 PM   #10
Low Saturn
Low Saturn's Avatar
2007 AURA XR
Waste of $$$$
Good for high HP builds. Terrible for a daily driver. Too fast of a rev down time. You'll be happier with a stock flywheel. Plus a Saturn stock flywheel isnt that heavy.
Stock replacement. LUK or Valeo
Mike
-1991 Turbo SL2.
Old 08-22-2009, 12:39 PM   #11
Waste of money or not I like it. Don't entirely care for the gearing of a 6spd with only 5 gears (as the MP3 are) but I'm getting used to it. I started out with a MP2, after me & a friend killed the MP7 my '93 came with and recently changed the engine and put the MP3 in.
Old 08-22-2009, 05:58 PM   #12
blooddrench
You ended up liking the mp2 better than the mp3?
Old 08-22-2009, 06:09 PM   #13
The MP3 is growing on me but the only real time I notice a difference is cruising in 5th gear (the MP2 5th results in the engine turning ~500 rpm less at any given speed) or mountain climbing. Acceleration on a flat may be technically increased but it feels slower as I have to shift much more often. I liked hitting ~65mph in 2nd gear, can't do that anymore
Old 08-22-2009, 06:11 PM   #14
wishihadacamaro
wishihadacamaro is on a distinguished road
This may be slightly off topic, but has anyone tried a SOHC motor with an MP3 trans?
Add to wishihadacamaro's Reputation
Rate the quality of this post and help wishihadacamaro reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
wishihadacamaro is offline   Reply With Quote
Old 08-22-2009, 06:18 PM   #15
blooddrench
Which trans would give you more power from a dead stop? the mp3 or mp2? I dont care about doing over 100
Old 08-22-2009, 06:56 PM   #16
PurdueGuy
PurdueGuy's Avatar
1999 SC1
From a dead stop up to what speed? Neither gives you more power, but the mp3 is better for acceleration in general.
Old 08-22-2009, 07:49 PM   #17
blooddrench
I was trying to choose the trans which has lower gears, as in 2nd gear doesnt take me up to 55+ like the auto. I want it to be geared for acceleration, not top speed.
Old 08-22-2009, 08:35 PM   #18
PurdueGuy
PurdueGuy's Avatar
1999 SC1
Then you want the MP3.
Old 08-22-2009, 08:51 PM   #19
blooddrench
Does anyone around have an mp3 with the differential pin already welded? It's a task I am not looking forward to finding someone to do. I dont have the resources available to do the welding myself.
Old 08-23-2009, 06:59 AM   #20
I'm positive my winter antics would have blown the diff pin in my transmission if it was truly an issue: Stuck in driveway? Back/slide into snow bank, punch it, swings the front around (it'd be fun, but I'm usually pissed about not making it on the first try). Stuck mostly in a ditch facing downhill but have to back uphill to get out? Punch it and hope for the best. Bored with nothing better to do then test the traction of studded 195/75R14's? Punch it and see if the tires spin.
Just don't be stupid with burnouts and avoid the 3rd gen manual transmission's, going by Low Saturn's post about the redesign.
shifting problems after swapping auto transmission woodsculptor S-Series Tech 3 06-27-2009 11:47 AM
swapping gauge cluster from a auto into a stick.... DJboozeAlot S-Series Tech 9 08-16-2007 12:13 PM
Question--Swapping out Auto Trans--'95 SL2 Triumph57 S-Series Tech 1 02-07-2006 03:15 PM
Swapping auto trans for a manual Spiker S-Series Tech 15 06-15-2004 12:44 AM
Swapping steering wheel / auto shifter CodisSL2 Mods and Performance 2 02-27-2003 01:19 AM
