Old 07-02-2009, 02:36 AM   #1
Bismarck318
Location: Birthplace of Rust, FKA The Heart of the Rustbelt, AKA The Angry White Planet Ohth
Default LW 300 melting taillights
This is a 2001 model year wagon, the tail light lenses appear to be melting on the inside, since this was purchased used, I'm unsure of the history here.
I understand there was a recall or TSB on this swapping out the bulbs to another type.
Was this common, & what should be in there, I can't recall the #'s offhand, but it appears there is a different bulb in their now than the manual specified.
Add to Bismarck318's Reputation
Rate the quality of this post and help Bismarck318 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 07-02-2009, 11:36 AM   #2
s3nfo
s3nfo's Avatar
2001 L-Series 3.0L Wagon
Default Re: LW 300 melting taillights
Recall was not for the bulbs, recall was for the stamped metal plate in the light assembly getting warped. You should check with the dealer and see if the recall was done.
Jerry N
Groucho Marx
Add to s3nfo's Reputation
Old 07-02-2009, 04:05 PM   #3
KLS1P
KLS1P is on a distinguished road
2004 L-Series 3.0L Sedan
It is common for someone to replace a tail light or brake bulb with whatever is available. Many different wattages are available with the same bulb base style. Always go with the manufacture's bulb number in the owners manual. A parts supplier may make a generic substitution, but the wattage may be too high. A bulb that is too hot may cause the plastic to melt. The recall was for bad connections at the assembly board, if the board connections failed the light assembly woud not work properly, not overheat.
Add to KLS1P's Reputation
Rate the quality of this post and help KLS1P reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
KLS1P is offline   Reply With Quote
Old 07-02-2009, 07:46 PM   #4
Bismarck318
The car was purchased like this used, & I noticed the blemish a few days after he purchased it (Actually my dads car). The dealer report actually mentioned that the bulb replacement was done there, the dealer said the sockets were replaced & a different bulb was used, & said the melt on the tail lamp did not merit replacement. (I'm winging from memory here). I am noticing that the lense is now getting opaque on the inside & bubbling, but the strange thing is he seldom if ever drives the car an night, & puts very low mileage on the car.
I'm going to look in to the real details of this, , what bulbs should be used in the rear assembly (remember this is the Wagon).?? I was going to use LED bulbs as they may had been cooler when it was purchased to prevent further damage, but the dealer assured that the problem was fixed.
As mentioned hotter bulbs could have been subbed, as I remember the 161's were used in Chrysler Dashboards (& for good reason too!!!)... In fact I use 161's in most all the glass wedge applications now, a bit brighter & for some reason they burn cooler & have a longer life.... they are just very hard to find.
Isn't Tail Lenses a safety item?
Old 07-05-2009, 03:35 PM   #5
Garciavision
Garciavision is on a distinguished road
Garciavision's Avatar
I noticed plastic housing melted around brake light bulb when I replced a few months ago. Glad I did recall a few years back. I have heard of possible fire
Add to Garciavision's Reputation
Rate the quality of this post and help Garciavision reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Garciavision is offline   Reply With Quote
Old 07-08-2009, 08:38 PM   #6
Bismarck318
Plastic housing, you are refering to the lense??
Exactly what is happening here, but the record shows the dealer replaced the sockets, & the bulbs, I can't see why this is getting worse?
Saturn refuses to replace the lenses, claiming the problem was corrected with whatever they did.
Old 07-08-2009, 09:00 PM   #7
Garciavision
I refer to the gray plastic housing the metal contacts was melted. I hope the melt was from few years ago before the recall. got stumped when changing bulb a few months back because they are new plug in and not old twist in
Old 07-09-2009, 09:05 PM   #8
Bismarck318
I pulled the bulbs, these is a 3157XX bulb with a right angle socket. These are a plastic based bulb. Is this the correct bulb & socket?
Old 07-13-2009, 12:26 PM   #9
Garciavision
sounds correct. They store can look it up on computer
01 L200 Melting Blower Switch Adamgh L-Series Tech 1 10-21-2008 08:16 PM
No gonna believe it, but my spoiler is melting!!! Speedy Vue General 10 09-12-2007 09:51 AM
Aura foglights melting plactic? thorster Aura General 7 10-26-2006 08:22 PM
LW 300 / L 300 Differences Matt V L-Series General 5 08-26-2006 12:23 AM
My car is melting!! Well, not really! slv01sc2 S-Series Tech 7 08-10-2002 02:47 PM
