Old 05-22-2009, 03:39 PM   #1
jonnycube
jonnycube is on a distinguished road
Default I broke my Saturn.
Today I attempted Wolfman's easy gas gauge fix. Suffice it to say I failed, but that's not what I'm concerned with now.
My happy, healthy Saturn won't start. I have lots of electricity - dash lights, headlights, all of it. When I turn the key nothing happens. No sounds - nothing. I cannot hear the fuel pump come on when I turn the key.
Aside from probing the three wires related to the fuel gauge, the only other thing I did was probe the trunk light (Don't ask. I'm curious.) In the midst of my probing, the bulb went dead. I'm sure I did something terrible to it. On the one hand, I don't see how this could possibly be related to my car starting, but on the other hand, it's the only thing I did. I checked out the fuel pump fuse, but it's just a big block. I can't tell if it's bad or not.
Prompt advice would be greatly appreciated - I'm sort of stranded. Thanks!
Add to jonnycube's Reputation
Rate the quality of this post and help jonnycube reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jonnycube is offline   Reply With Quote
Old 05-22-2009, 04:08 PM   #2
Default Re: I broke my Saturn.
In the underhood fuse box, check the IP BAT fuse, its one of the big green ones.
Does the check engine light come on when you first turn on the key?
Does the chime work?
Does the dome light work?
Put the year and model that is having the problem in the post so everyone knows which one is broke.
Old 05-22-2009, 04:25 PM   #3
jonnycube
This is a 97 SL2. (Sorry I didn't state this earlier.)
The IP BAT fuse is fine.
The chime works when I turn the key. Lights that come on and stay on: SES, battery, oil, parking brake. Seat belt light flashes on and off. Air bag light comes on when I turn the key, but goes off soon.
The dome light is out too (in addition to the trunk light that I fried). It was working before.
Old 05-22-2009, 04:32 PM   #4
jonnycube
I also probed my key while it was in the ignition, as well as the clutch pedal. Could this have done something to the ignition switch or the clutch pedal switch? I thought a little 12 volt circuit tester was fairly harmless.
Old 05-22-2009, 07:24 PM   #5
jonnycube
The trunk release lever has also stopped working.
I found this on about.com:
"When you try to start the car, the lights should either dim (a lot) or turn off completely. If they do, your ignition switch should be ok. If not, the switch will need replacement."
My lights neither dim nor go out when I turn the key. Should I go out and buy an ignition switch?
The car is a manual. Should I be able to kick start it?
Old 05-22-2009, 09:16 PM   #6
jonnycube
Since I haven't heard from anyone, I've been trying to troubleshoot this problem as best I can. Here's an update.
I push-started the car (In reverse!) and it's running. From what I've been able to figure out, I must have somehow fried some of the electrical components. I have no idea how probing a few things would do this. The probe light never even lit up - that is the reason I was trying lots of different places.
These have stopped working:
Trunk light
Dome light
Power locks
Power mirror (passenger's side)
And, I'm guessing, the ignition switch.
Everything else works: Headlights, AC, radio, rear defroster, dash lights.
When I got the car running after push starting, I saw a dash light I've never seen: "Service", with a little wrench by it. Would this light up because I took out the fuse for the air bag (when I was trying to get to the ignition switch), or is it more likely the result of me screwing up all the electrical components?
Old 05-22-2009, 09:23 PM   #7
Put the air bag fuse back in. As soon as I get a chance now that I know the year and whats broke I will look at a drawing. Don't poke around any more
Old 05-22-2009, 09:43 PM   #8
OK, check the BODY fuse in the I/P panel. Its on the right side of the center console.
Old 05-22-2009, 10:10 PM   #9
jonnycube
OldNuc, seriously, I want to send you a present or something. I know it's not a big deal to you, but I'm thrilled. My car is back to normal. Thank you.
I've been learning a lot about cars - now I need to learn something about electricity. And soon I'm going to have a lot of questions about why the "easy" fuel gauge fix went wrong. But not tonight. I've been at this for hours.
Thanks again.
Old 05-22-2009, 10:43 PM   #10
Your more than welcome. Got a link to the fuel gauge fix?
Old 05-22-2009, 11:38 PM   #11
rc1488
rc1488's Avatar
Its in the how-to library. Wolfman wrote it
Add to rc1488's Reputation
Old 05-23-2009, 12:00 AM   #12
OK, I can see how that little trick could get out of hand real quick.
Old 05-23-2009, 12:03 AM   #13
rc1488
rc1488's Avatar
haha yes. Especially when you go probing other things at the same time haha
My first 1992 Saturn SL1, valve spring broke amrjohal S-Series General 1 03-16-2008 10:42 PM
My first Saturn 1992 SL1-valve spring broke ! amrjohal S-Series Tech 1 03-15-2008 06:43 PM
SATURN OF NORWOOD claiming I broke my car gohepcat Ion General 12 12-08-2005 10:36 PM
help. i broke my saturn... mcginnt S-Series General 10 03-15-2005 01:45 AM
Saturn 2001 SL2 Door part broke, what is it? Axledental DJ S-Series General 1 12-24-2004 05:03 PM
