Old 11-14-2002, 06:47 PM   #1
erik85
erik85 is on a distinguished road
Default What can I do about this tire wear?
I have 2.5" sprint lowering springs with 18" rims and 215/35/18 tires. Now they dont rub but on the front two tires on the inside of the tires wears faster than any other parts. Should I just get 17"s or is there something I can do or is there a reason its wearing like this??
thanks
Add to erik85's Reputation
Rate the quality of this post and help erik85 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
erik85 is offline
Old 11-14-2002, 10:05 PM   #2
Default
Sounds like the wheel alignment is not matched to what you've done to the car. Solution (?), wheel alignment.
Add to ssicarman's Reputation
ssicarman is offline
Old 11-14-2002, 10:08 PM   #3
socketz
socketz is on a distinguished road
socketz's Avatar
Default
Wheel alignment is a MUST after lowering the car.
Sometimes, you may also find you need a camber kit.
I had a lowered 96 SL1 with 17s and never suffered from this....
Add to socketz's Reputation
Rate the quality of this post and help socketz reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
socketz is offline
Old 11-15-2002, 12:34 AM   #4
redman
redman is on a distinguished road
Default
Just inc you don't know camber in the relationship between the tire and the road on the x axis. this means that standing in front of the car & looking at the front of the wheels if you drew a line straight up and down that the camber. If your wheels point in at the top that is negative camber( which sound like your problem).
Now a little bit of negative camber helps you turn corners by keeping your wheels flat on the ground. To much and rour wheels start to run on only the inside of the tire when you are driving straight.
Take your car to an alingment shop and see if they can hellp you. More than likely you will have to buy an aftermarket camber ajuster with such a severe drop. (2.5") thats really low
Add to redman's Reputation
Rate the quality of this post and help redman reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
redman is offline
Tire wear Thundercat Vue Tech 3 01-20-2009 01:40 PM
Tire wear problem cougar_claw21 Ion General 7 09-22-2006 03:09 AM
Tire wear... acr2001 S-Series General 14 02-07-2006 10:16 AM
Tire wear Diago L-Series General 2 03-20-2003 10:15 AM
Tire wear Emanuel L-Series Tech 6 05-02-2002 01:14 PM
