Old 04-04-2009, 09:49 PM   #1
pr0cess0r
pr0cess0r is on a distinguished road
Default sl1 99 no high beam need your help.
hello i need you help to fix my high beam they dont work.
the DRL are working that mean bulb are good.
any idee where to start ??
any pin i can jump to see if its a bad relay ??
Add to pr0cess0r's Reputation
Rate the quality of this post and help pr0cess0r reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
pr0cess0r is offline   Reply With Quote
Old 04-04-2009, 10:01 PM   #2
cocacolacowboy
cocacolacowboy is on a distinguished road
Default Re: sl1 99 no high beam need your help.
drls don't mean good bulbs
Add to cocacolacowboy's Reputation
Rate the quality of this post and help cocacolacowboy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
cocacolacowboy is offline   Reply With Quote
Old 04-04-2009, 10:06 PM   #3
pr0cess0r
ok i whas thinking that DRL use high in series meaning that they are good no?
any sugestion then ?
Old 04-04-2009, 10:17 PM   #4
MechCb
MechCb is on a distinguished road
MechCb's Avatar
Have you pulled the bulbs to check the filament in the bulbs? You should have two filaments per bulb. Both should be intact. If not, that's your problem. If they are intact, maybe it's a switch issue....
I drive a Saturn
Add to MechCb's Reputation
Rate the quality of this post and help MechCb reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
MechCb is offline   Reply With Quote
Old 04-04-2009, 10:19 PM   #5
akulahawk
akulahawk is on a distinguished road
IIRC, the DRL circuit uses the highbeam lamps themselves... so if they light up, the bulbs themselves are good. I would also imagine that a good chunk of the wiring is also good. I'd be thinking about the high/low switch and the high beam fuse (if any), and the wiring from them. At least that's what I'd be looking for at first.
I'm assuming that the 99 SL1 uses 2 separate bulbs for high and low beam. If they're one bulb units, it would depend upon which filament the DRL system uses.
_____________________
Owner learning about my
1997 SL2 with the MTX...
Add to akulahawk's Reputation
Rate the quality of this post and help akulahawk reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
akulahawk is offline   Reply With Quote
Old 04-04-2009, 10:21 PM   #6
pr0cess0r
there is one or 2 filament ?
Old 04-04-2009, 10:26 PM   #7
akulahawk
A better question is:
Does your car have separate bulbs for high and low beams? The answer may make some troubleshooting easier by possibly removing the bulbs from the equation.
When the DRL's come on and then you turn on the headlights, do different light bulbs light up and others turn off?
Old 04-04-2009, 10:28 PM   #8
MechCb
MechCb's Avatar
Yea, you have two bulbs-one for your DTL's/High beams and one for your regular headlights. The one for your regular headlights is a single filament, and the other one is a double filament. So since your DTL's are working, that means you're getting power to the bulb. Since you're getting power to the bulb, that means that either
A: your high beam filaments are out
or
B: your switch isn't getting power to your high beam filament for some reason. It's not the fuse though, otherwise you wouldn't have your DTLs.
I looked at my fusebox for something else these last few days and everytime I saw it, I only saw a fuse for the right and left side headlights. I didn't see anything for the highbeams-but it never hurts to look and see if I just overlooked it since I wasn't specifically looking for it. I have the same year/model saturn as you though.
I drive a Saturn
Old 04-04-2009, 10:31 PM   #9
pr0cess0r
there is 2 set of light high and low im prety sure they have one filament.
when i start the car woth no hand brake high beam turn on has DRL when i turn the light on the low beam turn on and drl off when i put it on high no more light but the high beam on dash light
Old 04-04-2009, 10:35 PM   #10
pr0cess0r
or
you are right about the fuse ! and they are good thx.
too bad i dont have my tester with me i will buy new buld tomorow and try this!
Old 04-04-2009, 10:42 PM   #11
MechCb
MechCb's Avatar
If the dash light is coming on, that means the switch is doing what it needs to do. So my money is on you needing new DRL/Highbeam bulbs. All you gotta do is pull the bulb and look at it. If the filament(I'm not sure which one is your highbeam filament) is wiggling, hanging, or anything else other than straight accross, it's busted. If it is straight accross, flick the bulb with your finger once and see if it shakes. If it does, then it's broken. Flicking the bulb will not brake it-it provides the same amount of shock to the bulb as if you were to hit a pot-hole.
I drive a Saturn
Old 04-04-2009, 10:45 PM   #12
pr0cess0r
thx for the help i look at this and give you feedback
Old 04-04-2009, 10:47 PM   #13
akulahawk
Good switch, good fuses, only thing left is to replace the bulbs. Even those should be inexpensive...
Old 04-05-2009, 12:32 AM   #14
ahimsa1
ahimsa1 is on a distinguished road
1997 SW1
I got a set of high-beam bulbs on Ebay for $9.50 including shipping - a lot less than my local auto parts stores had them for, so if you don't mind waiting a few days that might be a good way to go. I searched by the part number, which is 9055.
97 SW1 Auto 174k
Add to ahimsa1's Reputation
Rate the quality of this post and help ahimsa1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ahimsa1 is offline   Reply With Quote
Old 04-05-2009, 02:27 AM   #15
Step one is to check for power to the high beam bulbs. If you have power then check to see if you have ground.
No power then you need to find out why.
No ground same thing, find out why.
If you have power and ground then it is the bulbs. Not common for both high beam bulbs to go bad at the same time but it can happen.
Add to ssicarman's Reputation
Old 04-05-2009, 10:56 PM   #16
pr0cess0r
i will have to look at mitchell on demand for wiring diagram i made a test with a test light neg to engine for gnd and positive to light socket both pin have power is it normal?? its not supposed to have one wire diretly to gnd and the other to 12v
Old 04-06-2009, 12:14 AM   #17
Should only have ground when lights are turned on. Lights off then no ground unless you have the key on and then the DRL circuit will ground the light through the other side. The positive side is always hot. Check the wiring diagram.
Old 04-06-2009, 01:00 AM   #18
or
There is no such thing as DTLs. The 9005 high-beam/DRL bulb is single-filament, not double. If the DRLs are working, the bulbs are good.
Likewise, there is no separate voltage regulator. The thermostat is in the lower rad hose block housing. There's no flywheel magneto. There's no fan belt. There's no upper control arm. There's no flower vase in the door pillar.
Back on topic: when you switch to the high-beams, do the low-beams go off?
Add to madpogue's Reputation
Old 04-06-2009, 04:51 PM   #19
bprimerano
bprimerano is on a distinguished road
Looking at the wiring diagram, I would guess the problem is a bad connection from the underhood junction box to the Hi/Lo switch. The pink wire.
Add to bprimerano's Reputation
Rate the quality of this post and help bprimerano reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bprimerano is offline   Reply With Quote
Old 04-06-2009, 06:29 PM   #20
pr0cess0r
low go off and high light in the dash .
i have remove the fuse box and found that the is some corosion insite the distribution plate if i can name ti like this.
its the plate with pins on both side and that have all the jumper wires inside.
maybe water entered this plate and coroded some of those jumper wire since my splash guard is very very bad.
high beam will not work Project84 S-Series General 35 02-20-2019 01:58 PM
High Beam comes on... Cincy Saturn L-Series General 10 01-20-2008 03:11 PM
Low Beam, but no high beam deligh387 L-Series General 6 12-08-2007 06:30 PM
What to do high beam lights? SL2-Guy S-Series Tech 4 09-01-2007 11:17 AM
High Beam DRL Redlinemsa L-Series General 3 08-27-2007 06:26 PM
