Old 12-18-2008, 09:37 AM   #1
Driver23
Driver23 is on a distinguished road
Default Changed thermostat twice, still no hear in car
Hey everyone,
when I bought my sl2, the heat wasn't working. I figured the thermostat was stuck open so I changed it. I changed it with a stant aftermarket thermostat and there for a while I was getting heat. The only problem was that the vent ball on the thermostat housing was stuck. This led to an air pocket in the system that didn't allow my thermostat to open at the correct temp. I was constantly losing coolant due to boil over and my car would overheat unless my heat was on. I then replaced that thermostat with a saturn OEM brand and I loosened the vent ball. I'm now certain there is no air in the system as my coolant temp guage stays where it is supposed to be, but now I get no heat ago. I'm now where I started when I first bought the car. What else would cause the fact that I'm not getting heat. I get a 2 second spray of heat if I turn the fan off for a minute then turn it back on but that's about it. A friend told me it could be the heater core, but I can't imagine they would go bad. Anyone have this problem and/or have any suggestions on what may cause this?
Add to Driver23's Reputation
Rate the quality of this post and help Driver23 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Driver23 is offline   Reply With Quote
Old 12-18-2008, 04:16 PM   #2
Driver23
Default Re: Changed thermostat twice, still no hear in car
sorry, posted in wrong section. Reposted in right section, delete this one if necassary, thanks
Old 08-11-2009, 03:35 AM   #3
Diezeltitan08
Diezeltitan08 is on a distinguished road
Diezeltitan08's Avatar
2002 SL1
if your blower is working then try your heater core. simple but thats wat was wring with my 98 sl2
Add to Diezeltitan08's Reputation
Rate the quality of this post and help Diezeltitan08 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Diezeltitan08 is offline   Reply With Quote
Old 08-12-2009, 05:24 PM   #4
crystal scan
crystal scan is on a distinguished road
2003 ION-2 Sedan
Originally Posted by Driver23 View Post
Hey everyone,
aint the skys to new to be needing new therostate or heating cores??????
Add to crystal scan's Reputation
Rate the quality of this post and help crystal scan reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
crystal scan is offline   Reply With Quote
Old 08-12-2009, 07:19 PM   #5
reedred
reedred is on a distinguished road
reedred's Avatar
2009 SKY Red Line
They are. This thread is in the wrong section of the forum. It's also really old, so I would certainly hope the OP has resolved his problems.
Add to reedred's Reputation
Rate the quality of this post and help reedred reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
reedred is offline   Reply With Quote
changed my thermostat and... S3aturnR S-Series Tech 9 12-17-2009 04:09 PM
Changed thermostat and ECTS now won't start RDave S-Series Tech 21 08-24-2009 08:37 PM
Changed thermostat twice-car doesn't get heat Driver23 S-Series Tech 4 12-18-2008 05:55 PM
Thermostat changed but not Water Pump JD13 Vue Tech 6 05-09-2008 09:35 PM
Changed timing chain, can't start car zeke54 S-Series Tech 24 09-27-2005 11:05 PM
