Old 12-03-2008, 01:22 PM   #1
clean93
clean93 is on a distinguished road
1993 SL2
2002 L-Series 3.0L Wagon
Default Not starting. Single click. Now no click
93 SATURN SL2, AUTOMATIC, 140K ORIG. STARTER. Car has been taking longer and longer to start and now stopped for gas got back in to start and just got a single click, tried several times kept getting single click (starter solenoid), had battery tested ( good ). Installed battery back now no click at all. All lights work, horn blows, chime works when doors open and keys in. Someone just verify with me that I should be taking starter to get checked based on these symptoms.
Add to clean93's Reputation
Rate the quality of this post and help clean93 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
clean93 is offline   Reply With Quote
Old 12-03-2008, 02:16 PM   #2
Default Re: Not starting. Single click. Now no click
I would suspect that the starter is bad and is ready for replacement. Understand that the process of removal and replacement tends to jar then back into operation just long enough to leave you stranded. Don't be surprised if it tests OK. Its probably the starter.
Old 12-03-2008, 02:51 PM   #3
jeremu
jeremu is on a distinguished road
jeremu's Avatar
1993 SW1
It also could be your battery cable, or even your battery.
I know this sounds kinda obvious, but clean your battery posts and the cables.
If that doesn't work replace your battery cable or at least test it.
You might want to blow my advice off, but it took me $200 and 2 days to find out that my $10 battery cable was bad.
NOTE:
If you test your battery cable test the load not just the Volts. My Volts were +12V, but on the load it went way down.
Add to jeremu's Reputation
Rate the quality of this post and help jeremu reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jeremu is offline   Reply With Quote
Old 12-03-2008, 02:59 PM   #4
2NDSOUT
2NDSOUT's Avatar
1999 SL
I'll second OldNuc on this. But have the Battery tested as well.
The starter needs replaced. Buy a new NSA starter, they are the equivalent size of the original Valeo starter. They go for about $150.
Bryan
94SL2 HCE, "Pearl"
99 SL
94SL2 260K Miles
1/15
97SW2 266K Miles
2/15
Always
94SC1 340,501 Miles
Org. Engine/Auto Trans
2/97-10/08
Gone 3/12
92SL1
05VUE
91SC
Add to 2NDSOUT's Reputation
Old 12-03-2008, 03:02 PM   #5
Battery test. Turn on headlights shining on a wall where you can see them. Turn key to crank. If the lights go out the cable(s) are bad, and if not its the starter.
Click, click, click goes the dash! skid_marque Vue General 11 05-05-2008 10:26 AM
Click noise when starting Nathan137 S-Series General 6 01-10-2007 08:51 PM
Nifty feature of 2.4-single click start NathanD Ion General 16 10-25-2006 09:26 AM
My Vue goes...Click, Click, Click-click GirlWithAVue Vue General 17 02-24-2006 05:54 AM
