Old 11-16-2008, 10:20 PM   #1
snowwhite
snowwhite is on a distinguished road
Default front end problem?
2005 Ion 2, 48K. we've been hearing a noise in the front end for a few weeks now when we turn the steering wheel. the steering wheel seems to have play in it and the noise is kind of a clunking noise. the noise seems to get better or go away after the car warms up good. could it be the rack and pinion steering or bushings? we had a mechanic look at it and he heard the noise when he drove it but he couldn't determine the cause. could tie-rod ends be worn out? thanks for any input.
Add to snowwhite's Reputation
Rate the quality of this post and help snowwhite reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
snowwhite is offline   Reply With Quote
Old 11-17-2008, 11:06 AM   #2
FlintIonQC
FlintIonQC is on a distinguished road
2007 ION-3 Quad Coupe
Default Re: front end problem?
There is a TSB for the steering column i-shaft because it has a little play in it. All they will do is turn the i-shaft 180 degrees and see if that fixes the problem. If it is more than a tiny noise, just go to a place like Tuffy's and have them check out the front suspension to see if the tie rods or ball joints are shot.
Add to FlintIonQC's Reputation
Rate the quality of this post and help FlintIonQC reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
FlintIonQC is offline   Reply With Quote
Old 11-17-2008, 11:48 AM   #3
2006 ion2
2007 ION-2 Sedan
while you're at it, have them check out the control arm bushings, they also are a weak spot on earlier ions.
2007 Saturn Ion 2
2003 Chevrolet venture lt
Add to 2006 ion2's Reputation
Front End Problem ElementalSL1 S-Series Tech 4 06-03-2007 11:28 PM
How can I diagnose a front end problem..? topCONsurveyor S-Series General 4 06-11-2006 10:42 PM
Possible Front End Problem Mike H S-Series Tech 1 01-17-2006 08:21 PM
Possible Problem with front end...need opinions!! xmarccox Vue General 7 07-15-2005 04:52 PM
Front end problem SaturnMan98 S-Series Tech 6 09-02-2000 01:49 AM
