Old 10-21-2008, 05:28 PM   #1
Adamgh
Adamgh is on a distinguished road
Default 01 L200 Melting Blower Switch
The blower fan switch on my 01 L200 overheats to the point where it starts to melt the inside of the switch. It makes it impossible to slide back and forth and if it's turned all the way up, it will get stuck! I have replaced the switch twice (about once a year) and it keeps happening. The plug on the back of the switch is a little scorched too. It never overheats to the point where it would start a fire but just enough to damage the switch. The blower motor could be drawing too much current but I can't tell for sure.
Does anybody know if there was a recall on the either the switch or the blower motor?
Add to Adamgh's Reputation
Rate the quality of this post and help Adamgh reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Adamgh is offline   Reply With Quote
Old 10-21-2008, 08:16 PM   #2
Ex-GMtech
Ex-GMtech has a spectacular aura aboutEx-GMtech has a spectacular aura aboutEx-GMtech has a spectacular aura about
2000 L-Series 3.0L Wagon
Default Re: 01 L200 Melting Blower Switch
You have what sounds like a high resistance situation. Check the ground wire for the blower motor for corrosion or loose connection. Check all of the connections for looseness and corrosion. If they look fine, the blower motor istelf may be suspected.
OMG this car is easy to work on!
2000 LW2
2016 Impala
1986 GLHS
Add to Ex-GMtech's Reputation
Rate the quality of this post and help Ex-GMtech reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Ex-GMtech is offline   Reply With Quote
2001 Saturn L200 4 cylinder Blower Not Working Varagon L-Series Tech 23 06-25-2016 05:59 PM
2002 SL1 Heater-A/C blower speed switch flythatway S-Series Tech 1 07-01-2008 05:15 PM
L200 Blower motor removal...any tips? Dach L-Series Tech 1 02-05-2005 09:38 AM
L200 2002 Dimmer gauge / switch mnkdrt L-Series General 2 07-29-2004 01:54 PM
HAVC blower switch sebc S-Series Tech 1 11-14-2003 04:09 AM
