Old 07-26-2008, 09:55 PM   #1
kevo420
kevo420 is on a distinguished road
kevo420's Avatar
2000 SC2
Default Is this brake wear abnormal?
Hi,
first i'll state that this is related to my 05 Vue... However i've never gotten a reply to any post i've put on the Vue forum. I Just bought this thing and i'm taking it back to the dealer for an un-related reason, but i'm prepping to point other things out to him and need an answer to my question.
This is just a general brake question, and i own an S-series so i'm posting here. Sorry if this cheeses someone off but i need a reply.
Ok, so when i test drove this thing the brakes were pulsating... after pointing this out the the salesperson they told me it would be fixed during the safety inspection. When i picked up the car i saw a receipt for front brake rotors and pads and they looked new (this was Friday). I've just gotten to work and i looked at the brake rotors through the rims. It looks like the left side brake pads aren't making full contact across the rotor.
Here are some pics so you can see what i mean
<-- Right side
<-- left side
Does that look weird to anyone? What would cause this?
If it matters i have less than 500 km on these new brakes.
Add to kevo420's Reputation
Rate the quality of this post and help kevo420 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
kevo420 is offline   Reply With Quote
Old 07-26-2008, 10:16 PM   #2
Default Re: Is this brake wear abnormal?
You don't have full contact on either side on the visible (outside) part of the rotors. Something is not installed correctly. I would reccomend driving it as little as possible, if at all. You don't have full braking power at the moment. Get the car back to where the brakes were installed and have them fix it ASAP.
Add to ssicarman's Reputation
Old 07-26-2008, 10:21 PM   #3
kevo420
kevo420's Avatar
2000 SC2
Are you saying that neither the left or right side is making full contact?
s****
Old 07-26-2008, 10:30 PM   #4
s****
Yes.
Actually looking at the pictures again the outer edge of the rotors does not have the best contact either. Especially on the left side photo.
The inner part of the rotor should have contact closer to the middle. On the right side picture take the outer edge rust and put it to the inner edge. This is closer to what the width of the unworn or non contact area should be. should be.
Even at that it could be less. Unless the picture angles are fooling me.
Old 07-26-2008, 10:42 PM   #5
kevo420
kevo420's Avatar
2000 SC2
thanks for your input.
I can't remove anything to inspect since i know it will come back and bite me in the a** when i go to get them to repair the problem.
Can you speculate as to what could cause this?
Brake Pad Wear Sensor - Up or Down ?? SalemCat S-Series Tech 37 06-11-2013 10:48 AM
Brake Pad Wear mariopalumbo S-Series General 15 10-28-2008 05:37 PM
very uneven brake wear Phredawgy S-Series Tech 17 01-12-2008 05:08 PM
brake pad wear Zigmund555 Miscellaneous Tech 4 04-01-2003 01:09 PM
Crank Wear - Abnormal ? sw2worn S-Series Tech 1 07-05-2000 07:48 PM
