Old 07-19-2008, 05:39 PM   #1
saturncrzy
saturncrzy will become famous soon enough
1992 SL2
Dizzy oil prob.
So i was useing 10w30 in my sl1 a syntech blend, so i decided to go to 5w30 like the car recamends, so today i went to drive my car and i had alot of rattling noises from the left side of the motor sounds like it is coming from the top... so i check the oil and the dip stick was m=not registering oil. So what should i do? Should i go back to 10w30 or should i take the valve cover off and do a visual check of the lifters and all.
Thanks
Add to saturncrzy's Reputation
Rate the quality of this post and help saturncrzy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
saturncrzy is offline   Reply With Quote
Old 07-19-2008, 06:03 PM   #2
Default Re: oil prob.
I would go back to 10W-30. How many miles did it take to go through the 5w-30 oil?
Old 07-19-2008, 06:32 PM   #3
saturncrzy
1992 SL2
i believe less the 300 miles but i just did an oil change 3 weeks ago.... my biggest concern is the rattling noise when i drove my car... but i will deffinatly go back to 10w30 syntech blend.
Old 07-19-2008, 06:52 PM   #4
If the oil pressure light is not on you should be OK. The rattle is the lifters a bit short on oil. That is better than a quart in 300 miles. I think that qualifies for excessive oil consumption.
Old 07-19-2008, 08:07 PM   #5
2NDSOUT
2NDSOUT's Avatar
1999 SL
Sounds like it is time for an MMO Soak or replacement on the timing chain possibly...
Bryan
94SL2 HCE, "Pearl"
99 SL
94SL2 260K Miles
1/15
97SW2 266K Miles
2/15
Always
94SC1 340,501 Miles
Org. Engine/Auto Trans
2/97-10/08
Gone 3/12
92SL1
05VUE
91SC
Add to 2NDSOUT's Reputation
Old 07-20-2008, 12:41 PM   #6
saturncrzy
1992 SL2
so when i do my oil change today i am going to go back to 10w30 sytech blend, should i take the valve cover off and check all lifters and all?
Old 07-20-2008, 04:04 PM   #7
saturncrzy
1992 SL2
Sad Re: oil prob.
okay as i was changing my oil back to 10w30 sytech blend, i started teh car after i was done and noticed that my belt was about to fly off. so i do an inspection and find out that my tensioner pully is shot... i can see inside it as you can see in the pic so i have to replace the whole thing.
Old 07-20-2008, 04:09 PM   #8
Squareback
Squareback's Avatar
2005 ION-2 Sedan
At least you found your rattle.
FYI--the dipstick only registers the top 2 quarts of oil, so you were at least 2 quarts low, so that will obviously cause the engine to make some noise also. If you're checking your oil as often as you should be it would never get low enough for the engine to make noise.
Certified Saturn Technician
Old 07-20-2008, 05:20 PM   #9
saturncrzy
1992 SL2
hey thanks, i didnt drive that much within those 3 weeks so i didnt check the oil, but i always check my oil every other day. so i take it this tesioner pully is not hard to replace?
Old 07-20-2008, 05:40 PM   #10
Squareback
Squareback's Avatar
2005 ION-2 Sedan
You aren't replacing a tensioner pulley, you're replacing a tensioner assembly. If you go and ask for a tensioner pulley at the parts store, that's what you're going to get, just the pulley. It's pretty easy, 2 10mm bolts is all. Make sure you use a good 6 point 10mm socket and you'll be fine. Easiest to get the bottom bolt through the wheelwell.
Old 07-20-2008, 07:31 PM   #11
saturncrzy
1992 SL2
awsome man thanks i was wondering how i was going to get to that bottom bolt. Yeah thats what i meant was the whole thing not just the pulley. Thanks again squareback
A/C prob raydog S-Series Tech 2 06-28-2008 03:11 PM
96 sl2 stereo prob, no sound, wiring prob? speaker prob? mjollnir79 S-Series Tech 3 09-22-2006 09:15 AM
95 SL1 idle prob and temp prob atilla S-Series Tech 10 06-08-2006 01:49 PM
Is the oil leak/burn prob limited to the older 1.9 ElwayLite General Saturn Discussion 41 03-27-2001 08:36 PM
oil prob part million//lookin for new head Randy Ion General 1 09-29-2000 09:42 PM
