Old 07-04-2008, 09:10 PM   #1
AAM
AAM is on a distinguished road
1996 SL1
Dizzy Cylinder Misfire again and again and again and again !
Car : '96 SL 1 Automatic
Problem: on going Misfire Cyl. # 4 (year 2.5)
Fixes:
New Ignition Module < all of these got rid of code for 4 months, code now back
New Coil Packs (both)
New cat.con. (original lasted 12 yrs !)
Plugs and wires 1.5 years old.
Should I replace o2 sensor ? Any Ideas? Has moderate oil leak (oil pan gasket or chain cover....around that area), is oil leak causing problem. At this point I just feed it 1 qt of oil in between changes,seems to work fine.
Getting new SKy next summer or fall, can I hold off on major repairs for problem without this car exploding ?
Thanks
Alex
Add to AAM's Reputation
Rate the quality of this post and help AAM reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
AAM is offline   Reply With Quote
Old 07-04-2008, 09:43 PM   #2
Keej
Keej is on a distinguished road
1999 SL1
Default Re: Cylinder Misfire again and again and again and again !
Did you try spraying brake clean around the top of the engine-intake gasket, pcv, throttle body etc?
Add to Keej's Reputation
Rate the quality of this post and help Keej reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Keej is offline   Reply With Quote
Old 07-04-2008, 09:49 PM   #3
Let's see; ignition module, coils, plugs, wires, catcon, and the problem remains in cylinder #4. Have you considered the possibility of a fouled #4 injector? Its the last remaining part you haven't tested for including compression and an intake manifold gasket leak.
Cylinder 3 Misfire and more, Please Help! RedRed S-Series Tech 7 09-24-2007 11:14 PM
Cylinder 3 Misfire 96GSL1 S-Series Tech 6 06-13-2007 08:45 PM
Cylinder 4 misfire Jamiem S-Series General 1 05-15-2006 12:08 PM
Misfire cylinder#3 solo1279 S-Series Tech 6 11-08-2005 08:50 PM
3.5L cylinder 5 misfire bluesl2 Vue Tech 2 08-11-2005 11:14 PM
