Old 06-28-2008, 01:09 PM   #1
raydog
raydog is on a distinguished road
2000 SL2
Happy A/C prob
My 2000 SL2 compressor clutch is engaged when fan is on reguardless of a/c on/off switch being off-turning fan completely off stops comp clutch. from turning. Doesnt sound normal?? ray
Add to raydog's Reputation
Rate the quality of this post and help raydog reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
raydog is offline   Reply With Quote
Old 06-28-2008, 02:27 PM   #2
Default Re: A/C prob
If you have a separate a/c switch and its OFF the clutch shouldn't be engaged. It may be turning but unless you're sure by the cold air coming out the vents when its off, the compressor is just barely turning, not making any real attempt to compress refrigerant. What you may be seeing is the clutch dragging and appearing to run the compressor. This is fine and of no importance but if cold air still comes out the vents with the a/c switch OFF then something is wrong.
Old 06-28-2008, 03:11 PM   #3
What position is the mode selector in? If it is in the defrost area then the AC will run and thus turn the cooling fan on. This should not happen in the floor to vent position.
Add to ssicarman's Reputation
Anyone else have this prob Ajw0079 Vue Red Line 6 09-30-2008 10:18 AM
96 sl2 stereo prob, no sound, wiring prob? speaker prob? mjollnir79 S-Series Tech 3 09-22-2006 09:15 AM
95 SL1 idle prob and temp prob atilla S-Series Tech 10 06-08-2006 01:49 PM
Transmission Prob? Miyu S-Series General 1 01-01-2005 05:16 PM
Another horn prob ezera1979 Ion General 3 10-03-2004 07:49 PM
