Old 06-18-2008, 05:49 AM   #1
alces
alces is on a distinguished road
Default Wheel bearings on SL2
I have replaced the wheel bearing on my 1996 SL2 several times now at intervals of about 5,000 miles. This seems awfully frequent. Could it be that something besides the bearing themselves could be causing this to happen? (I take the hub off myself, but take it to a shop to have the old bearing pressed out and the new one pressed in.)
Thanks,
Lance
Add to alces's Reputation
Rate the quality of this post and help alces reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
alces is offline   Reply With Quote
Old 06-18-2008, 07:36 AM   #2
Gerry Proctor
2008 Astra XR
2008 SKY Red Line
Default Re: Wheel bearings on SL2
Probably a question of how the bearing is being pressed in. If the arbor they're using is pressing on the inner race, then they are destroying the assembly. Other possibility is that you're using those gang-banger little wheels that stick out of the fender
Old 06-18-2008, 10:26 AM   #3
MikeNW
MikeNW's Avatar
1997 SL
Are you using Saturn parts?
Maybe you should disassemble the assembly, and take to a Saturn repair shop for pressing in the new bearing. Might be guaranteed for a while at least.
08 Burgman 400
Add to MikeNW's Reputation
Old 06-18-2008, 08:55 PM   #4
Are you having the shop press the hub into the bearing/knuckle assmebly?
If you are doing it yourself are you supporting the inner bearing races as you press the hub into the bearing? If not then this is your problem.
Add to ssicarman's Reputation
Old 06-18-2008, 09:12 PM   #5
Low Saturn
Low Saturn's Avatar
2007 AURA XR
Someone is doing something wrong. The bearings should last roughly 100,000 miles.
Saturn wont press bearing for you either. They'll sell you an entire knuckle assembly.
Mike
-1991 Turbo SL2.
11.809 @ 116.488 mph
www.differentracing.com
-2001 Chevrolet Suburban
-2007 Saturn Aura XR
Old 06-20-2008, 02:52 PM   #6
Luke
Luke's Avatar
Fm > Low Saturn
Or 536,473 miles
Add to Luke's Reputation
Luke is offline   Reply With Quote
Wheel Bearings duffbeer Ion General 9 07-08-2009 09:56 AM
Wheel Bearings afav868 Vue General 12 11-04-2004 11:06 PM
Front wheel bearings for 97 SL2 SilverBullit S-Series Tech 16 02-21-2004 01:48 PM
Wheel Bearings Gushie L-Series General 6 12-27-2003 11:07 PM
Wheel Bearings PeteBlueVue Vue General 5 07-02-2003 03:06 AM
