Old 10-11-2000, 02:43 PM   #1
Tinaja
Tinaja is on a distinguished road
Default Throttle sticks
BF's father has a 94 SL2 with a sticky throttle. The throttle kit from the dealer costs $300. Any advice/info on another way to fix it without it costing that much?
Add to Tinaja's Reputation
Rate the quality of this post and help Tinaja reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Tinaja is offline
Old 10-11-2000, 03:37 PM   #2
LilRedWag
LilRedWag is on a distinguished road
Default
troubleshoot. what are the parts in the throttle kit(?) - check against your parts/car. what are the moving/rotating parts, are they worn. are fasteners/retainers loose. spray and clean, apply appropriate new grease as required.
good luck.
Add to LilRedWag's Reputation
Rate the quality of this post and help LilRedWag reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
LilRedWag is offline
Old 10-11-2000, 04:51 PM   #3
verbose
Guest
Posts: n/a
Default
If, perhaps, there is a "sticking" feeling when you gently press on the accelerator pedal, you may be abe to correct this by turning the idle adjustment screw. (It's under the throttlebody and may have a black plastic cap on it. Once you've located the screw and removed the air duct assembly to get at it, just turn the screw clockwise a little bit to eliminate the problem. Cost? No money, just a little time. If you hesitate to tackle this yourself, any friendly mechanically-minded person can do it for you.
Add to verbose's Reputation
Rate the quality of this post and help verbose reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 10-11-2000, 08:20 PM   #4
sattech
sattech is on a distinguished road
Default
Changing the base idle settings may cause a ses light problem. To fix a sticking throttle recomended procedure is to remove the throttle body and clean. The throttle body is held on with two 10mm bolts. Use carb cleaner to clean the throttle plate and bore. If damaged upon removal. a throttle body gasket may be necessary.
Add to sattech's Reputation
Rate the quality of this post and help sattech reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sattech is offline
new throttle body sticks (slightly) John Head S-Series Tech 12 04-03-2008 12:14 AM
E-brake sticks dubsl2 S-Series Tech 1 04-22-2007 02:16 PM
Throttle sticks - not throttle body - help! dannysm213 S-Series Tech 2 12-10-2006 05:20 PM
caliper sticks? aaajessy L-Series General 4 10-09-2006 02:56 PM
Speedometer Sticks jacromer S-Series General 2 04-06-2006 12:13 AM
