Go Back   SaturnFans.com Forums > Models > Saturn Relay > Relay Tech
Old 04-23-2008, 12:14 PM   #1
sledgehammer777
sledgehammer777 is on a distinguished road
sledgehammer777's Avatar
2004 ION-2 Sedan
2005 RELAY-2
Default Wheel Bearing Hub Assembly Question
I need to replace the wheel bearing/hub assembly on my 05 Relay. Does anybody know what size socket is required to remove the hub assembly from the axel once the brake rotor is removed?
Also, does anyone know of issues or complaints with this part? My van only has 60K miles on it and this seems early to be needing replaced.
2005 Relay 2
2004 ION 2 Sedan
2000 SL2
1994 SL1 - Still my favorite!!
Add to sledgehammer777's Reputation
Rate the quality of this post and help sledgehammer777 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sledgehammer777 is offline   Reply With Quote
Old 04-23-2008, 11:33 PM   #2
john95SW2
john95SW2 will become famous soon enough
john95SW2's Avatar
2004 VUE 2.2L
Default Re: Wheel Bearing Hub Assembly Question
I'm pretty sure its 32mm....
hub bearings have been an issue since GM first started using them...some last forever, some not so long...
At least they're not necessarily difficult to replace
Add to john95SW2's Reputation
Rate the quality of this post and help john95SW2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
john95SW2 is offline   Reply With Quote
Old 05-15-2008, 09:00 AM   #3
sledgehammer777
2004 ION-2 Sedan
2005 RELAY-2
Just so everyone out there knows...
It is 34mm. There is a socket called a 34mm GM Axel Nut Socket that I found at AutoZone for $15.
The overall process was pretty straight forward.
2005 Relay 2
2004 ION 2 Sedan
2000 SL2
Old 03-08-2010, 11:45 PM   #4
henryr79
henryr79 is on a distinguished road
2007 RELAY-3
I used a 1-5/16 on my '07 Relay.
Add to henryr79's Reputation
Rate the quality of this post and help henryr79 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
henryr79 is offline   Reply With Quote
Stubborn wheel bearing hub assembly 2005 Vue, help! tkearsey Vue General 50 04-26-2019 11:02 PM
Wheel Bearing/Hub Assembly-Front/Rear dildog S-Series Tech 3 05-23-2007 11:58 AM
front wheel bearing/hub assembly Cowboygrad04 Vue Tech 1 06-25-2006 09:19 PM
Front Wheel Hub/Bearing Assembly JD7 Ion General 2 06-21-2005 05:52 AM
Wheel Bearing/Hub assembly SLeepr S-Series General 9 08-24-2004 10:23 PM
