Old 04-01-2008, 04:32 PM   #1
John Head
John Head is on a distinguished road
Default new throttle body sticks (slightly)
I recently purchased/installed a new large-bore throttle body from Saturn Motor Sports. Installation was smooth, IAC and TPS reinstalled just fine. But I notice that this throttle body sticks on acceleration, especially from a standing start in first gear. Once I'm moving, it's not too bad, and some days it doesn't stick at all.
Is this a normal breaking-in procedure, or is there something I can do to adequately lubricate the valve hinge? I've tried WD-40 and 3-in-1 oil on the flange hinge. It behaves almost as though the throttle flap wedges slightly in the opening, requiring more of an accelerator pedal kick to get it to open.
Other than this, the performance is great.
Add to John Head's Reputation
Rate the quality of this post and help John Head reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
John Head is offline   Reply With Quote
Old 04-01-2008, 08:15 PM   #2
virnin
virnin is on a distinguished road
virnin's Avatar
Default Re: new throttle body sticks (slightly)
It might be closing a little too tightly. There is a screw (left side under the cable pulley) that you can use to adjust the "closed" position. Use very small changes because you don't want to affect the idle speed.
Add to virnin's Reputation
Rate the quality of this post and help virnin reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
virnin is offline   Reply With Quote
Old 04-01-2008, 08:24 PM   #3
SLCraig
That's what it is.. I think its closing too tightly too. I had the same problem on my old Neon R/T when I changed the TB to something bigger. A few minor adjustments with the stop screw fixed the problem completely.
Add to SLCraig's Reputation
Rate the quality of this post and help SLCraig reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 04-01-2008, 10:04 PM   #4
John Head
Great tip, thanks guys. Can this be done with the throttle body still mounted, or should I remove it first?
Old 04-02-2008, 06:19 PM   #5
John Head
Dizzy Re: new throttle body sticks (slightly)
OK, I examined the set screw on the throttle body today, and noticed that it takes a hex or torx bit with a slight difference: There is a nib or pintle in the center of the idle set screw preventing a traditional hex bit from working.
Do I need to buy a special bit for this very slight adjustment? or is there a trick I'm just not getting?
Many thanks.
Old 04-02-2008, 08:05 PM   #6
tarsun
tarsun is on a distinguished road
i have the same TB as you. it did the same thing. i dont know if it loosened up over time or if i just got used to it......
Add to tarsun's Reputation
Rate the quality of this post and help tarsun reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
tarsun is offline   Reply With Quote
Old 04-02-2008, 08:43 PM   #7
Are these the tool bits needed to adjust the throttle stop; http://www.wttool.com/product-exec/p...f_Star_Bit_Set (don't know if yours is inch or metric)? If so, either you'll have to buy the set or possibly remove the throttle body from the engine for better access to break off the center nub or use needle nose pliers, narrow vise grip, whatever, to adjust the throttle stop this one time.
Old 04-02-2008, 11:31 PM   #8
John Head
I checked the link; yeah, those look like the right bits. I'll check further into the safety of making such adjustments (I scoured the archive and found numerous entries from folks cautioning against doing anything to the idle set screw. Certainly, I don't want to do anything that causes major problems; but the accelerator sticks so firmly sometimes when I go out to start the car that I really have to punch the pedal to free the throttle plate. I don't think I should have to do that.)
Old 04-02-2008, 11:35 PM   #9
tarsun
left your foot off the gass slower. dont let the thing "slam" shut
Old 04-02-2008, 11:49 PM   #10
John Head
Well, that's a thought; I'm not aware of how quickly I'm releasing the throttle when I'm shifting. Generally when the car gets going, I don't notice it; it's most evident from a standing start in first gear.
Old 04-02-2008, 11:55 PM   #11
Actually, the re-machined throttle body may be either fully closed when its not supposed to be or does need an adjustment to prevent the normal engine vacuum from sucking the throttle plate fully closed; the reason for the throttle stop screw and initial adjustment from the factory. The bypass air port is for the supplemental air that's controlled by the idle air control valve to adjust the final idle speed. Making another idle speed adjustment just requires covering the bypass port in front of the throttle plate temporarily to block off the bypass air and adjusting the idle stop screw for 500-600 rpm. Unblocking the bypass port will allow the iacv to make the final idle speed adjustment back up to 800-900 rpm automatically. Its been covered in past posts and usually the idle stop screw is never meddled with, as long as everything was the same but a modified throttle bore may require some tweaking, that's all.
Old 04-03-2008, 12:00 AM   #12
John Head
It makes sense, since this is a re-machined larger throttle body. What's the best way to block the supplemental air port to the IAC during the adjustment?
Old 04-03-2008, 12:14 AM   #13
Anything; duct tape, an elbow, thumb, umbrella, doorstop, ( ) etc., just enough to block off the airflow into the hole and interrupting the initial throttle idle speed adjustment. Just be sure that whatever you put over the hole won't get sucked into the intake.
Throttle body MikeNW S-Series Tech 4 08-17-2009 10:53 PM
Replaced Trans. Valve body. problem persists, but slightly different BudToker S-Series Tech 6 08-28-2007 12:19 PM
Who's got a throttle body? THX712517 Ion Mods 3 01-22-2007 11:06 PM
Throttle sticks - not throttle body - help! dannysm213 S-Series Tech 2 12-10-2006 05:20 PM
Throttle sticks Tinaja S-Series Tech 3 10-11-2000 08:20 PM
