Old 03-03-2008, 06:33 PM   #1
hit_n_run
hit_n_run is on a distinguished road
Default Failing clutch?
99 SL2 108K 5-speed.
I'm pretty sure I'm feeling the clutch slip. I've never had a clutch fail before so I'll admit I'm not totally sure what to look for.
First, second, fourth, and fifth gears all seem to be slipping. Third gear slips but not quite as bad.
In addition to that, I pulled over at a gas station after a 50 mile drive home from work. I popped the hood to check the oil and I saw smoke/steam coming from between the battery and the head. I could also smell something. It was almost like burned rubber but A LOT worse.
Any comments?
hit_n_run is offline   Reply With Quote
Old 03-03-2008, 08:21 PM   #2
Signmaster
Default Re: Failing clutch?
When a clutch is slipping, it's just like when you haven't let the pedal out all the way when you're taking off from a start. The revs will rise out of proportion to the acceleration of the car.
And that sounds like the smell of burnt clutch too.
Old 03-04-2008, 08:22 AM   #3
hit_n_run
GREEATTTT........
Now I have yet another project to tackle (which I have NO time for).
Failing alternator? sps SOHC S-Series Tech 72 07-14-2008 11:18 PM
99 SL1 - Is my clutch failing or in need of TLC Goliath S-Series Tech 15 03-29-2007 10:13 AM
Failing alternator? sps SOHC S-Series Tech 6 04-22-2005 10:32 AM
Symptoms of a failing clutch master/slave cylinder? lexington01 S-Series Tech 12 03-17-2005 09:55 AM
Failing alternator? VTHokie00SL2 S-Series Tech 15 03-11-2003 04:38 PM
