Old 12-13-2007, 12:33 PM   #1
krazykarl885
krazykarl885 is on a distinguished road
Dizzy More SL1 engine issues- different this time
Hi all,
Ive made a little progress on curing my SL1 of its engine issues. However now instead of idling high it idles too LOW? it seems to only idle between 200/500 rpm which is lower then it should. When coming to hard stop it almost wants to stall out. The codes its kicking up are 35 and 49- I found and fixed one of the vacuum leaks- the grommet of the pcv valve was bad. However it seems as though there still may be a vacuum leak that I cant seem to pin down coming from somewhere near the IAC/throttle body. Could the IAC itself be going ? Could this be the egr? The low idle when standing still also makes me wonder the fuel filter? Where is that on these cars? Anyone have any ideas or addtional help? Car is a 93 SL1 w/ sohc, manual trans and 138K
Thanks for all the help so far- I really appreciate all the knowledge and help you folks provide!
Karl
Add to krazykarl885's Reputation
Rate the quality of this post and help krazykarl885 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
krazykarl885 is offline   Reply With Quote
Old 12-13-2007, 01:07 PM   #2
PurdueGuy
PurdueGuy's Avatar
1999 SC1
Default Re: More SL1 engine issues- different this time
what all have you done to try to fix this already? My first suspicion would be the idle air control valve, which may be fixed by a good cleaning.
http://www.saturnseries.net/DIY%20Gu...gh%20clean.htm
Add to PurdueGuy's Reputation
Headlamp issues. Time to replace them anyway! Seņor Ramos S-Series Tech 3 10-28-2009 08:59 PM
few issues with my sl1 aerosmith S-Series General 6 07-01-2009 01:17 AM
2002 Sl1 oil consumption and engine noise issues. Ratpack S-Series Tech 0 06-24-2009 02:11 AM
'93 SL1 Heat and Engine Temp Issues jsylvers S-Series Tech 9 11-26-2008 09:30 PM
96 SL1 Starting-Engine Performance Problems/Issues Myfins1 S-Series General 16 03-03-2006 11:45 AM
