Old 12-09-2007, 01:55 AM   #1
antikaren
antikaren is on a distinguished road
Sad 2006 Saturn Vue Leaking Under Center Shifter Console
Hello. Ever since it snowed here, I noticed a leak (it's water) under the bottom left (driver's side) of the center shifter console. I have auto transmission. I have not used the A/C but have used the heater. I've used the heater before but had no problems - this seemed to start up with the snow.
I called Saturn and they told me to take it t the dealer - I can't afford what dealer wants just to take a look at it. My car is not under original warranty as I bought it used last summer. I bought a warranty the dealer sold, but I need to get some kind of idea of what this problem is so I can see if it's covered under that warranty. Thanks very much.
Add to antikaren's Reputation
Rate the quality of this post and help antikaren reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
antikaren is offline   Reply With Quote
Old 12-09-2007, 02:26 AM   #2
MudGod
MudGod is on a distinguished road
Default Re: 2006 Saturn Vue Leaking Under Center Shifter Console
is it still snowing or raining if the answer is yes it has to be a leak comming from out side if the weather is dry and your still getting the water leaking then it almost has to be comming from the car its self its not just a natral sprign in your dash ? just kidding
Add to MudGod's Reputation
Rate the quality of this post and help MudGod reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
MudGod is offline   Reply With Quote
Old 12-09-2007, 02:37 AM   #3
InVue
InVue is on a distinguished road
InVue's Avatar
Originally Posted by antikaren View Post
...I noticed a leak (it's water) under the bottom left (driver's side) of the center shifter console.
I am not sure if I follow you here, when you say "bottom left", do you mean under the car outside or inside?
Either way, if it's water and occurs in snowy condition, due to the volatility of snow, it could mean that the snow enters area where water does not, and then somehow from there it melts and leaks...
Can you take a picture of the actual drops or leak line with a digi?
Add to InVue's Reputation
Rate the quality of this post and help InVue reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
InVue is offline   Reply With Quote
Old 12-09-2007, 03:09 AM   #4
Welcome to the Board.
If the car is under three years and 36k miles then it should still have factory warranty.
Are you sure that it is not melting snow getting things wet?
Is the weather cold enough to freeze your washer fluid? If so then you may have a leaking rear washer line.
Add to ssicarman's Reputation
Old 12-11-2007, 01:52 AM   #5
antikaren
I believe it's coming form under the car where the shifter linkage goes through the bottom of the car. Driving through a lot of snow can result in it accumulating, then melting.
Anyway, the ONLY place there is water is right under the left side of the automatic shifter console. There are some vents at the bottom of this console, but I only have water on the left side of it. This is the plastic console covering the shifter - only water in the vehicle at all is underneath this console on the left side.
Thanks for all the replies. I can try to take a picture, but all it'll show is the bottom of this console with the carpet being wet from underneath the console of the driver's side - none on the passenger side.
I'm going to stop driving the car until I can find out what's wrong....don't want the carpet to get moldy.
Old 07-02-2010, 05:34 AM   #6
como13
como13 is on a distinguished road
Antikaren:
I am having the same problem with my 2006 Saturn Vue, but it only happens when it rains. I am in a warm climate, meaning no snow. I purchased the vehicle used a few years ago and it didn't start happening until earlier this year. I was hoping it was a known issue with the model and a GM certified body shop would take care of it. I will post if I find anything.
Add to como13's Reputation
Rate the quality of this post and help como13 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
como13 is offline   Reply With Quote
Old 07-02-2010, 09:40 AM   #7
mikec
mikec will become famous soon enough
mikec's Avatar
I would vote for a windshield leak, an air conditioner condensation leak or a heater core leak as the primary suspects. Is the water there all the time or only after you drive it?
Add to mikec's Reputation
Rate the quality of this post and help mikec reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mikec is offline   Reply With Quote
Old 07-02-2010, 10:42 AM   #8
1saxman
Another 'People that never had a car before' problem. It's condensate from the AC. The AC compressor activates in the 'floor' register position which is where most people place the selector when they want heat. In the warmer climate, you use AC, water drips out from under the car.
Add to 1saxman's Reputation
Old 07-21-2010, 11:37 AM   #9
LastL4Banger
LastL4Banger is on a distinguished road
2004 L-Series 2.2L Sedan
"The AC compressor activates in the 'floor' register position "
why is that? I hammered my gas mileage on a long trip once when had my windows open and I 'activated my AC compressor'. I understand the defroster doing that but the fan blowing on my feet kicking on the AC makes no sense.
anyway, I too have a similar issue. I just noticed that the carpet on the drivers side is a little damp. Its definitely coming from the shifter console side and not the door. As its not rained lately, I suspect some type of AC leak. Water does drain from the AC drain so its not a clog issue. when I remove the shifter console, is there something in particular I need to look for?
thanks
Add to LastL4Banger's Reputation
Rate the quality of this post and help LastL4Banger reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
LastL4Banger is offline   Reply With Quote
2005 Center Console swap for 2006 model? ScurriVision Vue Red Line 12 04-18-2010 07:52 PM
Pictures: 2006 Center Console in a 2003 VUE the_webers_inc Vue Mods 21 07-13-2008 01:49 PM
Center Console Shifter Trim Piece oachalon Aura General 3 10-19-2007 11:26 PM
Center console ugly embossed VUE logo dulino Vue General 25 06-09-2005 08:03 AM
VUE Center Console SRV-UE Vue General 28 10-03-2004 11:14 PM
