Old 12-07-2007, 11:31 AM   #1
deligh387
deligh387 is on a distinguished road
Sad Low Beam, but no high beam
I have a 2001 L200 and last night as i was driving home I switched to high beams, but there was no light. Low beams work fine however. The High beam light in the cluster is now on when the car is running, regardless of whether the lights are on or not. I tried replacing the DRL Relay, no help, Tried replacing the headlight switch, no help.
Add to deligh387's Reputation
Rate the quality of this post and help deligh387 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
deligh387 is offline   Reply With Quote
Old 12-07-2007, 02:44 PM   #2
BoDuke70
BoDuke70 is on a distinguished road
BoDuke70's Avatar
2004 ION-3 Quad Coupe
Default Re: Low Beam, but no high beam
So...you replaced the stalk on the LH side of the column? Ever have any smoke or a burning plastic smell coming from this area?
A different kind of parts guy...now in a bow tie!
Add to BoDuke70's Reputation
Rate the quality of this post and help BoDuke70 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
BoDuke70 is offline   Reply With Quote
Old 12-07-2007, 03:14 PM   #3
deligh387
yeah, I replaced the stalk, and i had experienced some smoke in the past, but not recently. And the bulbs are not burned out either.
Old 12-08-2007, 12:16 AM   #4
Have you checked to see if there is power to the headlamps/highbeams?
Description from the service manaul.
Headlights
Battery power is applied to the low and high beam elements of the left headlight assembly by the left headlight fuse through CKT 40. Battery power is applied to the low beam element of the right headlight assembly by the right headlight fuse through CKT 140. Battery power is applied to the right high beam element by the right headlight fuse normally closed (DRL relay NOT energized) contacts of the DRL relay and CKT 593.
When the headlight switch is turned to ON, and the high beam switch is OFF, a ground path is provided to CKT 1201 through the headlight switch to CKT 550. CKT 550 is connected to the LIPFB and is grounded at the right body ground splice pack. When the high beam switch is in the ON position, a ground path is provided to CKT 1200 through the headlight switch to CKT 550. CKT 550 is connected to the LIPFB and is grounded at the right body ground splice pack. This same operation is also true when the flash-to-pass feature is used. To operate the flash-to-pass feature, the multifunction lever is pulled toward the driver
Add to ssicarman's Reputation
Old 12-08-2007, 12:35 AM   #5
deligh387
There is no power to the high beams. All fuses are still in tact and relays are good.
Old 12-08-2007, 01:00 PM   #6
BoDuke70
BoDuke70's Avatar
Maybe check that connection at the switch, those pins are not indestructible and perhaps some physical damage during install? Just trying the obvious and easy first...
Old 12-08-2007, 06:30 PM   #7
If you have no power to the high beams then you need to trace the wiring to the fuse block and see if there is a problem in the wiring out of the block to the highbeam headlamp connectors.
Left highbeam power wire is an orange wire. Right highbeam power wire is a blue wire.
High Beam comes on... Cincy Saturn L-Series General 10 01-20-2008 03:11 PM
Headlight question...hi-beam, low-beam, DRL indicator svbb Vue General 6 12-13-2005 09:13 PM
03 L low beam ? DP49657 L-Series General 7 12-01-2003 10:00 PM
low beam bulbs spydrwebb S-Series Mods 13 05-19-2003 03:59 AM
Low Beam Jumper LilRedWag S-Series Tech 7 08-23-2000 06:41 PM
