Old 07-27-2007, 01:35 PM   #1
JohnHupp
JohnHupp is on a distinguished road
Question Front exhaust pipe cracked at pipe-to-engine stiffener clamp
This is on a 95 SL2 with about 170,000 Indiana miles. The front exhaust pipe is cracked on either side of the pipe-to-engine stiffener clamp (a strap clamp) which is an couple inches in front of the flex pipe. I understand this is a common problem.
The service manual has a procedure for cutting the pipe an inch in front of the isolator bracket in front of the cat (it's either the original cat or part of a front half or whole system replacement), unbolting from the exhaust manifold, removing the stiffener bracket/clamp, sliding a replacement pipe-with-flex into the cat input, rebolting to manifold with new gasket, and U-clamping in front of the cat. (I'm sure I'd have to replace the rusty stiffener clamp also.) I can get a Walker 52166 pipe + gasket + clamps for $60-70 online, but if I went this route I'd be interested in what you all have to say about getting the pipe off the manifold. Does PB Blaster make getting those nuts off a pretty certain proposition? (I'm down to one car next week, so middle-of-the-job parts runs are out.)
A muffler shop wanted to cut the pipe in front of the stiffener clamp and behind the flex pipe and weld in a new flex pipe (presumably with whatever lengths of additional pipe are needed). They would leave out the stiffener clamp (and I suppose remove the bracket on the engine it attaches to, to prevent banging). Cost: $90-100 with guaranteed results.
Or the shop would slap a weld on the cracks for $30 without removing the stiffener clamp to add a sleeve/collar, but they had no confidence that this would hold up for long.
What would you guys do?
Add to JohnHupp's Reputation
Rate the quality of this post and help JohnHupp reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
JohnHupp is offline   Reply With Quote
Old 07-27-2007, 03:27 PM   #2
SaturnTech
SaturnTech is on a distinguished road
SaturnTech's Avatar
Default Re: Front exhaust pipe cracked at pipe-to-engine stiffener clamp
You'll have no trouble with the manidolf to pipe nuts. I had them off of my '92 last week when I replaced the tranny. I have a 13mm Snap-On swivel head socket that I bought specifically to use on the exhaust. Works every time, even here in Syracuse where they can never lay too much salt on the roads.
Add to SaturnTech's Reputation
Rate the quality of this post and help SaturnTech reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SaturnTech is offline   Reply With Quote
Old 07-28-2007, 11:18 AM   #3
eljefino
eljefino's Avatar
1995 SW1
I'd go to the muffler shop for this one, if things got hairy they've got welding.
Had a car once with an aftermarket one piece cat installed, and they left a piece of the stiffener in place, just hose clamped to the pipe. I feel you should have some solid connection there to reduce the potential for odd noises.... either bangings or harmonics that weren't there previously.
Add to eljefino's Reputation
front exhaust pipe clamp name? hiii98 S-Series Tech 4 09-09-2008 01:13 PM
What size exhaust pipe for the flex pipe? turbobuick33 S-Series Tech 4 03-10-2007 04:46 PM
front exhoust pipe/down pipe, same thing? xupthree60 S-Series General 4 08-01-2006 04:54 PM
Down Pipe/Header Pipe/Flex Pipe/Front Pipe Carriere S-Series General 6 05-12-2006 08:44 PM
Front Exhaust Pipe leak at just be fore the Clamp Support under engine Luke Miscellaneous Tech 7 01-11-2003 12:14 PM
