Old 07-07-2007, 06:13 PM   #1
Gamerjoe504
Gamerjoe504 is on a distinguished road
Default 1998 SL2 Wont start. Starter wont Spin
I have a 1998 SL2, standard tranny, no ABS. I just replaced the ECTS, but not the wire connector. The starter clicks (soliniod engagement I think) but will not spin. I can hear the fuel pump start up. I have tested the battery, and I have also cleaned all of the battery connections. Could this be anything other than the starter?
If it is the starter, where the heck is it? Is it under the battery box? Thanks for any help.
Add to Gamerjoe504's Reputation
Rate the quality of this post and help Gamerjoe504 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Gamerjoe504 is offline   Reply With Quote
Old 07-07-2007, 06:18 PM   #2
oseberg
oseberg is on a distinguished road
Default Re: 1998 SL2 Wont start. Starter wont Spin
Did you test the battery with a volt meter with the headlights on while you try and start the car?
It's probably a bad starter.
Your starter is located under your engine near the interface between the engine and the transmission (pretty close to the center).
Add to oseberg's Reputation
Rate the quality of this post and help oseberg reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
oseberg is offline   Reply With Quote
Old 07-07-2007, 06:29 PM   #3
adhsc2
adhsc2 is on a distinguished road
adhsc2's Avatar
your starter has 3 prongs on it. RED is your power wire, Black is your ground, and the LITTLE one goes to your alternator. crawl under your car and touch the red one and the little one together with a screw driver, if it makes noise like the car is gonna start, it is your solenoid. if it doesnt, its the starter motor. either way, a new starter is in order.
MAKE SURE YOUR CAR IS IN PARK WITH YOUR E-BRAKE ON AND YOUR TIRES STOPPED. just to be safe.
1995 Saturn SC2
Screw engines...I R HAVS A POWER MODULE!
Member of: Saturn Tuners Club - Southeast
Add to adhsc2's Reputation
Rate the quality of this post and help adhsc2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
adhsc2 is offline   Reply With Quote
Old 07-07-2007, 06:33 PM   #4
oseberg
I don't think one of the wires is ground, because ground goes directly to the engine through everywhere the starter touches the engine.
This is a good idea to rule out any connection or wiring issues in your car. But make sure your car is in park or neutral, and the ebrakes are on.
My 98 SL2 wont start. speedy45 S-Series Tech 2 07-03-2008 11:52 AM
1998 sl-2 wont start 1993 S-Series Tech 5 07-10-2007 07:37 PM
1999 SL2 Wont Start/Hard to Start in Hot Weather BlueOgre S-Series Tech 9 06-28-2007 06:36 AM
sc2 alarm went off last night now remote wont work & car wont start kre8ive_kustomz S-Series Tech 1 03-27-2007 08:46 PM
94sc2 with 119k miles wont start -- is it the starter? BobDobbs S-Series Tech 10 08-05-2003 07:14 PM
