Old 01-30-2007, 08:25 PM   #1
claw218
claw218 is on a distinguished road
Default Vue timing belt replacement, 2003 V6
I am wondering if the timing belt replacement can be completed sucessfully without any of the special tools that are referenced in instructions (like the ones on alldatadiy's web site). The instructions reference camshaft locks & a wedge tool for the crankshaft. The wedge looks easy enough to fabricate if you really had to.
Add to claw218's Reputation
Rate the quality of this post and help claw218 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
claw218 is offline   Reply With Quote
Old 01-31-2007, 04:30 AM   #2
Bigdaddy94sc2
Bigdaddy94sc2 is on a distinguished road
Bigdaddy94sc2's Avatar
2006 ION-2 Sedan
Default Re: Vue timing belt replacement, 2003 V6
Honestly, I dont think so. I hate to admit it, but the crank tool, the wedge, the cam locks, and the lack of timing marks on the new belts make it a royal PITA without the tools. Just my .02 though.
GM, Saturn, and ASE certified Technician. Always glad to try to help, just ask!!! Now own an 06 ION.2 as of 7/2/06 with 2988 and counting (7/28/06) 13131 as of (1/8/07) 24901 as of (7/30/07)
Add to Bigdaddy94sc2's Reputation
Rate the quality of this post and help Bigdaddy94sc2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Bigdaddy94sc2 is offline   Reply With Quote
Old 01-31-2007, 09:58 AM   #3
jdmessner
jdmessner is on a distinguished road
jdmessner's Avatar
Changing a timing belt is NOT a maintenance proceedure recommended for a backyard mechanic.
Without the proper tools, you run the risk of accidently advancing the crank or cam shaft that will result in the least, throwing off the engine timing or more seriously, causing a cylinder to advance and strike an open valve damaging both the cylinder head and the valve.
Replacement of the timingbelt is not mandatory, but failure to do so will eventually lead to belt failure and possible engine damage.
Yes, having the timing belt changed professionally is expensive, but that cost is signifigantly less than that of a new engine which you could need should you make a mistake.
Recommendation: Take it to a PROFESSIONAL.
Add to jdmessner's Reputation
Rate the quality of this post and help jdmessner reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jdmessner is offline   Reply With Quote
Old 02-03-2007, 12:48 AM   #4
burlyvue2
burlyvue2 has a spectacular aura aboutburlyvue2 has a spectacular aura aboutburlyvue2 has a spectacular aura about
2004 VUE 3.5L
2000 L-Series 3.0L Wagon
claw218,
Do yourself and your vehicle a HUGE benefit and get it done by a pro. If they screw it up it is their problem and will be remedied. If you make a mistake it's all yours. I agree with jdmessner. Get it done by a Pro.
Add to burlyvue2's Reputation
Rate the quality of this post and help burlyvue2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
burlyvue2 is offline   Reply With Quote
Old 02-03-2007, 01:20 AM   #5
ksion15
ksion15 is on a distinguished road
2003 ION-1 Sedan
2005 RELAY-3
don't you hate that. they give us marks for 6 years, and you get used to having them, then, they take them away. i've done about 6 now without the marks, and am getting used to it, but why do that?
Add to ksion15's Reputation
Rate the quality of this post and help ksion15 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ksion15 is offline   Reply With Quote
Old 02-03-2007, 01:43 AM   #6
Bigdaddy94sc2
2006 ION-2 Sedan
Only thing I can come up with was to save like .20 per unit, but it now takes longer and they charge more for the part.... I am confused... But yeah, I am getting used to it, but it is definitely different and takes some getting used to.
Old 02-03-2007, 12:27 PM   #7
IMkenNY
IMkenNY is on a distinguished road
I had no problem replacing mine without any of the specialty tools, the cam sprockets stayed in position very nicely. The only confusing part I ran across is the double set of timing marks on the cam sprockets (I recall it was A & B depending what bank it was) Just make note of the mark used before taking the old belt off.
When I did mine I had the timing marks on the belt, I wonder if the aftermarket belts are marked?
Do yourself a favor and replace the water pump as well. There is a brand new one selling on ebay and as long as no one reads this thread it will sell bellow dealer cost
Add to IMkenNY's Reputation
Rate the quality of this post and help IMkenNY reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
IMkenNY is offline   Reply With Quote
timing belt replacement marathoner Vue Tech 29 09-28-2011 10:17 PM
Timing belt replacement. VueGuy168 Vue Tech 15 03-03-2009 10:17 AM
Timing Belt Replacement jsdailey Vue General 9 11-17-2007 02:57 PM
VUE V-6 Timing belt replacement interval Chevy Guy Vue General 10 06-29-2005 09:50 AM
Timing belt replacement-help- t3junkie S-Series Tech 5 03-08-2001 03:43 AM
