Old 09-21-2019, 04:38 PM   #1
2teendaughters
2teendaughters is on a distinguished road
2teendaughters's Avatar
Default Right side head lights dim.
When lights are turned on the right side is very dim. Both high and low beam. When switched between high and low the opposite seems to happen. Getting 12vdc and as near as I can tell the ground is intact. Has the headlight switch taken a dump? or is there another possible check I can look into.
Craig
2000 Sl2 (1st Daughter 2nd Sl2)
2001 Sl2 (Wifes)
2002 Sl2 (2nd Daughter)
2000 Sl2 (RIP Wrecked by 1st Daughter Sold)
2001 Sl2 (1/2 a car bought for Parts Sold)
Add to 2teendaughters's Reputation
Rate the quality of this post and help 2teendaughters reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
2teendaughters is offline   Reply With Quote
Old 09-21-2019, 05:05 PM   #2
Default Re: Right side head lights dim.
Which car?
Old 09-21-2019, 05:17 PM   #3
2teendaughters
Sorry 2001 sl2
Craig
2001 Sl2 (Wifes)
Old 09-21-2019, 05:35 PM   #4
I'm not near service manuals for posting and going on memory but if I'm not mistaken, there are two wiring schematics, one for manually turning on headlights and the daytime running lights using a complicated wiring scheme. The drl circuit may affect manual lighting but not the other way. Drl uses a relay downstream from fuse(s), controlled by the bcm. Check all headlight fuses for looseness, drl relay and wiring in general. I'm not sure if your '01 SL2 uses parking or high beams for daytime running lights and complicates where to check. Some GM drl circuits use a combination of serial and parallel wiring along with adding a resistor in other drl circuits.
If this problem exists only in drl or manual lighting mode, the problem can be narrowed down. There may be wiring diagrams posted in other threads and you can use circuits from 2000 and up.
Old 09-21-2019, 06:43 PM   #5
2teendaughters
Fuses checked and relay replaced. These were my first thoughts. Only the right side is affected. Haven't seen a wire schematic. Wondering if circuit is split Left and Right in the headlight switch? There isn't any indication in the (PDM) power distribution module. Stumped non the less.
Craig
2001 Sl2 (Wifes)
Old 09-21-2019, 07:22 PM   #6
SRGW
SRGW is a name known to allSRGW is a name known to allSRGW is a name known to allSRGW is a name known to allSRGW is a name known to allSRGW is a name known to all
1997 SL1
Post Re: Right side head lights dim.
Does this help
1995 SL1 236,300 2005>2018
1997 SL1 78,100 2014>????
CHECK YOUR OIL!!
Add to SRGW's Reputation
Rate the quality of this post and help SRGW reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 09-21-2019, 08:37 PM   #7
Waiex191
Waiex191's Avatar
I don't have a schematic in front of me but if anything was split it would be the grounding block. By the way, cool avatar and cool you have 3 saturns. Now you just need one for you!
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Add to Waiex191's Reputation
Old 09-21-2019, 11:12 PM   #8
2teendaughters
Originally Posted by SRGW View Post
Does this help
CHECK YOUR OIL!!
Lights are split from side to side. Power and ground. Is that what you see?
Craig
2001 Sl2 (Wifes)
Old 09-22-2019, 12:08 PM   #9
SRGW
1997 SL1
1995 sl1 236,300 2005>2018
1997 sl1 78,100 2014>????
Old 09-23-2019, 04:51 PM   #10
Claybury
Claybury will become famous soon enough
Claybury's Avatar
Sounds like a high resistance connection somewhere. You won't find that by measuring voltage at the source.
Look at the connectors for corrosion or heat damage. Wires for corrosion or burning. Pull the bulbs and look for corrosion at the contacts.
Check the ground connections for corrosion or being loose.If all else fails try new bulbs.
2002 SC2 1.9L
2007 Vue 3.5L
1985 Fiero SE 3.1L
1974 Triumph Spitfire 3.1L V6
2002 Ram duelly diesel 5.9L
1975 Honda PA50 0.05L (Swarm and destroy)
Add to Claybury's Reputation
Rate the quality of this post and help Claybury reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Claybury is offline   Reply With Quote
Old 12-02-2019, 11:39 PM   #11
theunpaidBill
theunpaidBill has a spectacular aura abouttheunpaidBill has a spectacular aura abouttheunpaidBill has a spectacular aura about
theunpaidBill's Avatar
So did you ever find the issue? My 02 SC2 is showing the same symptom.
Add to theunpaidBill's Reputation
Rate the quality of this post and help theunpaidBill reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
theunpaidBill is offline   Reply With Quote
Old 12-06-2019, 02:03 AM   #12
TomM96
On my 2000 SW2 the forward right lamp ground (a foot behind the headlamp fixture on top right upper frame rail) had several badly corroded terminals inside the connector, which is open to weather.
Claybury (above) has very good suggestions...
When the bright is dimmer than the dim, may indicate bad ground limiting adequate power for normal ops.
Add to TomM96's Reputation
Can I patch tail lights into head lights? mgordon1100 S-Series Tech 1 05-01-2010 05:48 PM
WTB drivers side head light bracket for 03 VUE jhutch2115 Classifieds 0 07-27-2006 09:36 PM
wtb 3rd gen head lights sc mad_nigerian Classifieds 0 03-14-2006 01:51 PM
Cargo Cover With Side Head Curtain Air Bags on '04? Black-N-Tan Vue General 12 01-27-2004 08:20 PM
Help, dim head lights Son93SL2 S-Series Tech 10 02-09-2001 11:42 PM
