Old 09-06-2019, 04:12 PM   #1
MikeNW
MikeNW's Avatar
1997 SL
Default valve cover vents
(1997 SL)
Why are there two vent hoses from the valve cover?
1 into the air intake
1 is the PCV into the manifold.
They come from the same place?
So, can I put them into a T, into my catch jar?
08 Burgman 400
Old 09-06-2019, 05:22 PM   #2
onlinebiker
Default Re: valve cover vents
Catch jar?
Currently owned
93 SC2
96 SC2
97 SL2
99 SC2
01 SC2 x 2 yellow
02 SC2
02 SL2
parts
2 94 SC2 parted out
2 96 SC2
Old 09-06-2019, 05:24 PM   #3
454cid
Originally Posted by MikeNW View Post
(1997 SL)
One is an IN and the other is an OUT. One brings in filtered air to the crank case, and the other gets air/vapors sucked out through it.
1999 Chevy K3500
Old 09-06-2019, 05:29 PM   #4
454cid
Originally Posted by onlinebiker View Post
Catch jar?
He may be using a jar. They're typically called a "catch can". They're a popular modification that has dubious benefits, in most cases, from what I have read. Our cars may benefit, but I don't see my throttle body getting oiled up even with my PCV system being overwhelmed by blow by.
1999 Chevy K3500
Old 09-09-2019, 11:36 AM   #5
Yep.
You only want the catch can / jar at the OUT (PCV) end of things
This has been on my to-do list for many years
Old 09-09-2019, 12:07 PM   #6
onlinebiker
Eliminating a source of vacuum on the crankcase isgoing ton cause far more problems than it will ever solve. Leaky gaskets and seals for one. Gasoline dilution of the oil another.
Currently owned
93 SC2
96 SC2
97 SL2
99 SC2
01 SC2 x 2 yellow
02 SC2
02 SL2
parts
2 94 SC2 parted out
2 96 SC2
Old 09-10-2019, 01:34 PM   #7
MikeNW
MikeNW's Avatar
1997 SL
The "jar" is a canning jar (jelly jar), suitable for high temps, I've had it there for about 5 years now with no problems.
The hose and jar circuit is air-tight, so no loss of vacuum.
It catches a few ounces of oil per oil change.
Yes, it is on the PCV circuit only. Thank you for explaining the original Q.
08 Burgman 400
Old 09-10-2019, 06:22 PM   #8
Claybury
Claybury's Avatar
You might want to check the PCV valve too. Iíve found aftermarket direct fit valves cause excessive oil consumption. Original olive green valves donít.
2002 SC2 1.9L
2007 Vue 3.5L
1985 Fiero SE 3.1L
1974 Triumph Spitfire 3.1L V6
2002 Ram duelly diesel 5.9L
What problems can be diagnosed / fixed under the valve cover / timing cover? Dalamar S-Series Tech 1 09-15-2011 09:42 AM
Valve cover (cam / camshaft cover) hard to remove JohnHupp S-Series Tech 4 08-07-2010 11:11 AM
Replacing composite/polymer valve cover with aluminum cover DOHC idaw8184 S-Series Tech 0 08-04-2008 01:31 PM
How do take off the side vents+cover alfkorda Ion General 3 09-09-2004 09:42 PM
FS: Valve Cover Gasket for BLACK Plastic Cam Cover, S Series jmettee Classifieds 0 11-02-2003 11:48 PM
