Old 09-02-2019, 11:20 AM   #1
colonelhogan44
colonelhogan44 is a glorious beacon of lightcolonelhogan44 is a glorious beacon of lightcolonelhogan44 is a glorious beacon of lightcolonelhogan44 is a glorious beacon of lightcolonelhogan44 is a glorious beacon of light
colonelhogan44's Avatar
Default Super clean 1st gen (not affiliated)
Single cam, but super clean, and towed, so less than 150k "real" miles. I haven't seen a nice 1st gen like this for sale in 10 years.
https://www.facebook.com/marketplace...4914526463357/
MechE - I make things!
EGR ADAPTERS AVAILABLE! $30 "reverse" $40 standard
1998 SL2 (gone, never forgotten)
2005 Volvo S40 T5 AWD
1987 Mercedes 300D
1993 Tracker 4x4
1996 Tracker 4x4
Add to colonelhogan44's Reputation
Rate the quality of this post and help colonelhogan44 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 09-02-2019, 12:17 PM   #2
onlinebiker
Default Re: Super clean 1st gen (not affiliated)
Towed an automatic? Isn't that hard on a transmission?
And - if it was on a dolly - it would not register the miles..
Edit to add...
And if the trip odometer reads 0000 - safe bet the odometet is broken - and not actual miles. Very common on 1st gens.
92 SC2
93 SC2
96 SC2
97 SL2
97 SC2
99 SC2
01 SC2 x 2 yellow
02 SC2
02 SL2
parts
2 94 SC2 parted out
2 96 SC2
onlinebiker is online now   Reply With Quote
Old 09-02-2019, 02:51 PM   #3
Looks immaculate from those photos. Dust on the engine suggests a dry area, maybe clean underneath. One concern is emissions - did it pass or will this be a major issue? Second is when will clutch replacement occur? Great price even if money is spent to keep it running.
Old 09-02-2019, 04:52 PM   #4
Zeebins
Zeebins's Avatar
Edit to add...
The car in the listing is a manual. From what I know, as long as the key is turned to run and the transmission is in neutral, you can safely flat tow these cars. Manual or automatic. The key needs to be in run though for the odometer to count the miles. I'm pretty sure the trans fluid will flow regardless, but it won't be cooled so you're not supposed to go more than 65 or something.
97 SL2, auto, 118K miles
Powered by Plastic
Add to Zeebins's Reputation
Old 09-02-2019, 05:23 PM   #5
onlinebiker
You are correct. It is manual.
The listing first lists it as an automatic - then twice as a manual. The interior picture confirms manual.
I just read as far as "automatic transmission" and quit.
92 SC2
93 SC2
96 SC2
97 SL2
97 SC2
99 SC2
01 SC2 x 2 yellow
02 SC2
02 SL2
parts
2 94 SC2 parted out
2 96 SC2
Old 09-03-2019, 01:15 PM   #6
colonelhogan44
It's in central CA, so it should be 110% rust free.
Current tags in CA means it passed emissions at worst two years ago.
1987 Mercedes 300D
1993 Tracker 4x4
1996 Tracker 4x4
Old 10-25-2019, 04:35 AM   #7
S-forever
S-forever is on a distinguished road
1991 SL2
The Saturn TAAT automatic transmission is one of the few that can be flat towed without supplemental lubrication. I've towed many of them thousands of miles with no problems, mostly on freeways. I've towed my current daily driver(97 SL2 auto) 2000 miles and several shorter trips with the engine off, key in so that the transmission goes to neutral and steering follows. No complications, and the transmission is still original at 341K miles. The manual can be towed easily too. I designed a towbar especially for the S-series just so I could do this. It bolts to the sway bar between the subframe mounts.
Add to S-forever's Reputation
Rate the quality of this post and help S-forever reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
S-forever is offline   Reply With Quote
super bad gas mileage 05/96 General Saturn Discussion 0 07-14-2011 12:16 AM
Prestone Super Flush vs. Super Radiator Cleaner The Critic S-Series Tech 8 12-07-2006 10:39 PM
HKS Super AFR... Rob1998SL2 Classifieds 0 08-07-2005 07:54 PM
HKS Super AFR sc2095 Mods and Performance 5 04-13-2004 08:17 PM
Super Afc grumpy Mods and Performance 1 09-13-2001 11:08 AM
