Old 05-30-2019, 10:17 AM   #1
VueGuyz
VueGuyz is on a distinguished road
Default Serpetine replacement on 08 3.5
On my 08 Vue XE 3.5l my belt broke and im having difficulty getting the new one on. Is there a trick or procedure Om not aware of. it just doesnt seem to fit.....its the right belt # K6 1093......Please help...
Add to VueGuyz's Reputation
Rate the quality of this post and help VueGuyz reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
VueGuyz is offline   Reply With Quote
Old 05-30-2019, 11:10 AM   #2
RobertGary1
1996 SC2
Default Re: Serpetine replacement on 08 3.5
Not sure what you mean by difficult but they are a bit difficult to get around each pulley without falling off another pulley.
Are you sure you're routing it correctly?
-Robert
Old 05-30-2019, 05:57 PM   #3
VueGuyz
could fit the loop above the crankshaft pulley...probably have to remove mounts and support engine....i have the diagram from yahoo images for the Vue
Old 05-30-2019, 09:59 PM   #4
bern
bern is a glorious beacon of lightbern is a glorious beacon of lightbern is a glorious beacon of lightbern is a glorious beacon of lightbern is a glorious beacon of light
2004 ION-2 Sedan
Service information Shows Engine Mount bracket needs to be removed
Add to bern's Reputation
Rate the quality of this post and help bern reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 06-02-2019, 09:26 PM   #5
atikovi
No idea what K6 1093 is but if you ordered a belt for a 3.5L engine, it won't fit since 08 has the GM 3.6L engine.
Add to atikovi's Reputation
CV Axle replacement: transmission fluid replacement question MHZ-711 Vue Tech 4 11-19-2017 02:54 PM
03 bcm replacement kidmoon90 Vue Tech 8 08-01-2016 09:04 PM
Radiator drain/replacement and Thermostat Replacement jeanne17 S-Series General 8 05-18-2010 08:48 PM
2003 Vue, 1800.00 dollar throttle body replacement and now a 675 BCM replacement??? Suicidns13 Vue General 8 03-04-2010 05:46 PM
More on VCG replacement. DeCaff2006 S-Series General 11 07-12-2006 05:19 AM
