Old 02-22-2019, 03:35 PM   #21
Silverblu02SL2
Default Catalyst just completed... EGR & Evap remaining
I have driven the car 4 to 5 times now on trips ranging from 4 miles to 12 miles long. This morning, during a 4 mile trip, the Catalyst readiness completed.
I have read Evap may take a long time (or never) to complete. What about EGR? Does it take very long?
I was advised to not clean the EGR valve for fear of resetting all readiness monitors. Are there anything I can/ should check in regards to the EGR that is not intrusive, with no worry of resetting the monitors?
Add to Silverblu02SL2's Reputation
Rate the quality of this post and help Silverblu02SL2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 02-22-2019, 03:51 PM   #22
Default Re: Emissions readiness DTC- how long does it take?
Re: EGR, not sure if you decelerated as described during your drives.
FWIW, I almost always shift into Neutral when decelerating /coasting, so would not hit the required steps for EGR diagnostic
Originally Posted by OldNuc
It is . . . the closed throttle coast that will set the EGR complete.
Originally Posted by dssl1
3. Accelerate. Turn off the air conditioner and all the other loads and apply half throttle until 88km/hr (55mph) is reached. During this time the Misfire, Fuel Trim, and Purge Flow diagnostics will be performed.
4. Hold Steady Speed. Hold a steady speed of 88km/hr (55mph) for 3 minutes. During this time the O2 response, air Intrusive, EGR, Purge, Misfire, and Fuel Trim diagnostics will be performed.
5. Decelerate. Let off the accelerator pedal. Do not shift, touch the brake or clutch. It is important to let the vehicle coast along gradually slowing down to 32km/hr (20 mph). During this time the EGR, Purge and Fuel Trim diagnostics will be performed.
6. Accelerate. Accelerate at 3/4 throttle until 88-96 km/hr (55-60mph). This will perform the same diagnostics as in step 3.
7. Hold Steady Speed. Hold a steady speed of 88km/hr (55mph) for five minutes. During this time, in addition to the diagnostics performed in step 4, the catalyst monitor diagnostics will be performed. If the catalyst is marginal or the battery has been disconnected, it may take 5 complete driving cycles to determine the state of the catalyst.
8. Decelerate. This will perform the same diagnostics as in step 5. Again, don't press the clutch or brakes or shift gears
Old 02-24-2019, 04:02 PM   #23
Silverblu02SL2
EGR readiness monitor finally completed today after multiple attempts to decelerate from 55 mph to 20 mph w/o braking. Previous attempts I had to use the brakes Evap is still Incomplete but that's ok since I am allowed one Incomplete.
Old 02-24-2019, 04:38 PM   #24
Plan on EVAP never completing until spring or fall.
Old 02-25-2019, 02:35 AM   #25
colonelhogan44
colonelhogan44 is a glorious beacon of lightcolonelhogan44 is a glorious beacon of lightcolonelhogan44 is a glorious beacon of lightcolonelhogan44 is a glorious beacon of lightcolonelhogan44 is a glorious beacon of light
colonelhogan44's Avatar
Evap will complete just fine if you drive that car for a while. I've never had issues with mine checking off within a few tanks of fuel. I even got it to check off same day once. YMMV, but I've never had issues with my Saturns outside of one that was a hybrid between 2nd and 3rd gen with lots of harness splicing going on.
MechE - I make things!
EGR ADAPTERS AVAILABLE! $30 "reverse" $40 standard
1998 SL2 (gone, never forgotten)
2005 Volvo S40 T5 AWD
1987 Mercedes 300D
1993 Tracker 4x4
1996 Tracker 4x4
Add to colonelhogan44's Reputation
Rate the quality of this post and help colonelhogan44 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
colonelhogan44 is offline   Reply With Quote
Old 02-25-2019, 07:36 AM   #26
Here's the service manual explanation of the evap system.
Old 02-25-2019, 10:24 AM   #27
The tolerances for EVAP are not consistent year to year. The gen-2 is by far wider acceptance tolerances and the Gen-3 is sufficiently tight that there are PCM re-flashes available to correct the inability to never get it reset. Model 2002 is the tightest by the way and that FSM info does not tell you the actual setpoints but it does explain how the way you decide to start the car will actually preclude the possibility of a reset in the general description of operation section.
Old 02-25-2019, 11:51 AM   #28
Silverblu02SL2
Thanks for the pdf's !
Old 02-25-2019, 11:54 AM   #29
Silverblu02SL2
Is that because of decreased volatility of gasoline, not generating enough pressure in the fuel tank in the winter?
Old 02-25-2019, 07:21 PM   #30
No the test is a vacuum test. There are pages of discussion on the EVAP reset issue with the 3rd gen cars. The test permissive parameters are quite tight and too hot or cold and you do not meet the entry test requirements. This is a multi-part test sequence to have that monitor complete. If you are in the habit of inserting the key and twisting directly to crank quit doing that, let it set in the ON position until the fuel pump prime and bulb check completes then crank. People who drive long distances on the interstate usually have no problem with this test but the city - urban dwellers do. Somewhere north of Poughkeepsie on your way to Albany on a reasonably warm winter day should do it, maybe...
Old 02-26-2019, 04:32 PM   #31
colonelhogan44
What year is your 3rd gen Saturn, OldNuc?
I've had a 2002 in the past, and that car had no problems checking this one off within 1 full tank of fuel (as well as every other monitor, usually within the first 15 minutes of driving).
YMMV, as always.
1987 Mercedes 300D
1993 Tracker 4x4
1996 Tracker 4x4
Old 02-26-2019, 09:07 PM   #32
The reason that you got it to work is where you are located. You can use search and pull up all the grief that people have had with this POS system getting it to set complete. The 01-02 models are the tightest of the bunch.
Old 02-27-2019, 01:03 PM   #33
colonelhogan44
What year is your 3rd gen? Your profile has only a 1998. What actual experience do you have with working on these cars? It seems everyone takes your words as gospel theses days, but i often wonder how much of what you post is actually garnered from your own hands-on, practical experince? Reading and repeating the boards is fine and can useful, but I've always been curious as to whether you've actually done much on a Saturn...
1987 Mercedes 300D
1993 Tracker 4x4
1996 Tracker 4x4
Old 02-27-2019, 02:17 PM   #34
I fix lots of them locally. I also happen to have an interest in computers including ECU/TCU design and application. All the info on the EVAP is out there on google as to the basic requirements year by year and the actual implementation is in the FSM. The method is the same 98-02 but the tolerances are different. You find the tolerances at EPA. This does not require much to actually figure out once you look up how it works.
Old 02-27-2019, 02:59 PM   #35
The EVAP monitor is a software setpoint issue and has nothing to do with the vintage of the hardware as the 98-02 are identical. As has been pointed out by another poster in this thread it will not set ready if the environment temperature is too high either, and that little fact is nowhere to be found in the FSM. It can be figured out with a classic physics text book though.
Old 02-27-2019, 06:50 PM   #36
colonelhogan44
I guess the only permanent solution to the EVAP readiness monitor is to move to the mild weathered left coast, then!
1987 Mercedes 300D
1993 Tracker 4x4
1996 Tracker 4x4
Old 02-28-2019, 02:47 AM   #37
Actually one of the local inhabitants who posted earlier in this thread made the initial discovery of a serious temperature sensitivity, it is not in the service manual, its a bug.
Old 04-02-2019, 08:45 PM   #38
Silverblu02SL2
I have driven the car for 200 to 300 miles so far w/o completing the evap emissions readiness. I put in a new T-stat yesterday and took the car for a mile local drive today and the evap readiness finally completed. You can see the Torque app, it's all green in the pic in this post http://www.saturnfans.com/forums/sho...2&postcount=70
Changing the T-stat made the ECT go up to 195 F instead of 158 F with the old T-stat. Is the higher ECT responsible for evap completion?
I thought evap readiness checks the fuel vapor in the tank. ECT is not in the equation. Was this just another coincidence? I've had a few with this car so far.
Old 04-02-2019, 10:10 PM   #39
Apparently, you've inadvertently proven the naysayers wrong when t-stat replacement killed two birds with one stone - completing the evap monitor and returning to correct operating temperatures. I tried searching for parameters but come up empty. My guess is during engine warmup, a certain temperatures needs to be reached as each emissions monitor is evaluated. None are independent of each other so the entire to system must operate in a symbiotic relationship from startup in order to meet programmed emissions minimums.
And congratulations, you're car completed all emissions self tests.
Old 04-02-2019, 11:35 PM   #40
One of the requirements for the EVAP tests(there are several) is normal operating temperature. There is no official documentation of what constitutes normal.
Each emissions monitor test has its own parameters that must be satisfied to either run or pass.
Note that everything passed except EVAP until you changed out the thermostat.
Normal operating temperature is mentioned in post #3.
Readiness Tests CFerrara154 S-Series Tech 5 02-20-2017 09:41 AM
sc1 emissions readiness tyoung2401 S-Series General 3 02-17-2014 03:41 PM
Emissions readiness not completing Jim97sl2 S-Series Tech 11 11-22-2013 06:52 PM
How long for on board computer to reset I/M readiness rlbking1 Introductions & Greetings 2 10-22-2011 10:15 AM
Emissions Readiness Monitors Gabba S-Series Tech 2 01-24-2007 12:03 PM
