Old 05-28-2016, 02:33 PM   #1
Muayad925
Muayad925 is on a distinguished road
Default Car doesn't start after getting gas!
Hey i have a 2006 saturn ion redline 5 speed manual. Everytime i fill up gas the car doesn't start.. If it does start it dies right away unless i rev it.. The way i bypass this is to pump gas with the car on. What could the problem be? I heard purge valve?
Add to Muayad925's Reputation
Rate the quality of this post and help Muayad925 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Muayad925 is offline   Reply With Quote
Old 05-29-2016, 10:28 AM   #2
lgodave
2003 ION-3 Sedan
Default Re: Car doesn't start after getting gas!
Any codes,lights, or other engine related poor performance that may shed more light on the issue?
So if understood correctly if you successfully get it started once after refueling the issue doesn't repeat? You could drive it across the street, start and stop it for a minute or 12 hours and it'll behave normally? (You don't Rev or "prime" the Engine for Startup? "Just to be safe".)
Fuel Filter ever been changed? At what point do you usually fuel up? 1/2,1/4,E,Low Fuel,Fumes, or Whenever you have a good price or Convenience? Do you regularly use a Top Tier Detergent Standard Gasoline or other Name Brand (Many have joined the Top Tier Standard)? No-Name? Combination of both? Have you used any Fuel System Cleaner and/or HEET to help clear the tank of unwanted contaminants?
Any rusted/leaking fuel line repairs in the near future? (Behind the Driver's Side Rear Tire is a known bad spot for fuel line rusting.)
Add to lgodave's Reputation
Rate the quality of this post and help lgodave reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 05-29-2016, 11:35 AM   #3
billysvue
You do stop filling up after the auto shutoff stops the pump?
'17 Suby Forester
I'm a secondhand vegetarian.
Cows eat grass, I eat cows.
Add to billysvue's Reputation
Old 05-29-2016, 12:25 PM   #4
Muayad925
Only after getting gas it does this, after i turn it off, i can start it right back up just fine. I dont get poor engine performance. Im not sure if the fuel filters been changed ive had the car for only half a year.. I usually fill up when its close to E with only name brand premium gas like chevron, shell, arco. And no i never used any cleaners.. And i live in california i don't think rust would be a problem
Old 05-29-2016, 12:26 PM   #5
Muayad925
Yes i usallu only put 20 in so i dont even reach that point
Old 05-31-2016, 12:41 AM   #6
lgodave
2003 ION-3 Sedan
So what happens if you performed a "fake" fuel stop? Going through the motions of filling your tank... without the filling part? So Both "cold" (first in the morning or later at night once its cooled down) or "hot". Basically checking to see if the Fuel Cap Seal is a problem to fix...
Old 07-06-2016, 07:36 PM   #7
OneTimeRide
OneTimeRide is on a distinguished road
Replace the Emission Canister Purge Solenoid Valve it costs about $25.00
i had the same problem and this fixed it for me, i hope this helps,
Add to OneTimeRide's Reputation
Rate the quality of this post and help OneTimeRide reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
OneTimeRide is offline   Reply With Quote
Old 07-28-2016, 10:40 AM   #8
daver
daver has a spectacular aura aboutdaver has a spectacular aura about
daver's Avatar
2005 ION Red Line
1999 SC2
Gas cap seal issue is common as the car ages, and your symptoms definitely match. Might just need to replace the cap. 20 bucks or so.
Add to daver's Reputation
Rate the quality of this post and help daver reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
daver is offline   Reply With Quote
03 Saturn doesn't start periodically, but eventually does start Caveman1953 L-Series Tech 5 11-25-2011 10:15 PM
Should start but doesn't squiggle S-Series Tech 7 04-14-2011 01:44 AM
03 VUE doesn't start Janka Vue Tech 4 12-23-2008 11:55 AM
Car doesn't start Static S-Series General 14 04-05-2007 12:54 PM
doesn't want to start cindiw20 S-Series General 1 03-06-2004 01:02 PM
