Old 04-17-2014, 06:09 AM   #3561
Pitcher
Pitcher's Avatar
Originally Posted by ClosetGeek View Post
This past weekend I did the following:
- Replaced all four struts and their associated hardware,
- Replaced passenger side half shaft seal on the transmission,
- Performed the 5th gear swap from a 1998 SL1 SOHC 5 speed transmission into my 1994 DOHC 5 speed transmission,
- Cleaned the EGR port,
- Power washed the engine,
- Removed the headliner in preparation for installing a new one,
- Discovered why my rear window defroster no longer works, so more to fix!
- Posted a couple of questions on the forum so that I can finally, hopefully put some other issues to bed
That's what I did and there is plenty more to be done!
Owned 4 other S-Series.
Add to Pitcher's Reputation
Rate the quality of this post and help Pitcher reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 04-17-2014, 01:18 PM   #3562
sallydriver
sallydriver is a name known to allsallydriver is a name known to allsallydriver is a name known to allsallydriver is a name known to allsallydriver is a name known to allsallydriver is a name known to all
sallydriver's Avatar
1993 SW2
Which distro?
Lubuntu at the moment.
1998 Red SL 5spd "The Right Honorable Duke Farnsworth the Functional of Clearfield":165,000 miles
1999 Forest Green SL2 5spd "Sally": 307,100+ miles
1993 White SW2 5spd "Steve": 234,984 miles
Add to sallydriver's Reputation
Rate the quality of this post and help sallydriver reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sallydriver is offline   Reply With Quote
Old 04-17-2014, 01:34 PM   #3563
slapshot 11
slapshot 11 has a spectacular aura aboutslapshot 11 has a spectacular aura aboutslapshot 11 has a spectacular aura about
1999 SL1
Installed ANOTHER front wheel bearing last Thurs because 1 day after I finished the job, someone posted an addendum to the list of instructions warning anyone doing this job to remember when pressing the hub into the bearing, to MAKE SURE the inner race is supported. ONE DAY! The whole job had to be done over again, but it did not take as long. Now the shifter (manual) is notchy and from reading here I need to replace the slave/master clutch actuator assy. It is ordered and might be here today. It cost me $89 delivered with prices up to $120 (plus tax) at the local Carquest and many other pricepoints between. Replaced the right front wheel and hubcap after an unfortunate encounter with a chuckhole one night on the way to play hockey. (BROKE the hubcap, but tire did not go flat)
Add to slapshot 11's Reputation
Rate the quality of this post and help slapshot 11 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
slapshot 11 is offline   Reply With Quote
Old 04-17-2014, 09:34 PM   #3564
bumpdraft
bumpdraft's Avatar
1998 SW2
Potholes:
Replaced the SC2's fried rotors They lasted ~3 years 'til I parked the (pothole damaged) car for a few months.
Add to bumpdraft's Reputation
Old 04-18-2014, 12:13 AM   #3565
batmangsxr600
batmangsxr600 is on a distinguished road
i cursed it at it n then was like no baby i didnt mean it your not the *****ty of a car theres worse
Add to batmangsxr600's Reputation
Rate the quality of this post and help batmangsxr600 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
batmangsxr600 is offline   Reply With Quote
Old 04-18-2014, 06:04 PM   #3566
solidhadriel
solidhadriel is on a distinguished road
Going to get the radiator tested.
I'm losing a quart of coolant every 20 miles. Something is off.
No drips. Fresh head gasket.
1998 Saturn SC1 - 285k Miles | 5-Speed Manual
1999 Saturn SW2 - 172k Miles | Auto | The new DD
2014 Mustang GT - Garage Queen...sort of
Add to solidhadriel's Reputation
Rate the quality of this post and help solidhadriel reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
solidhadriel is offline   Reply With Quote
Old 04-19-2014, 12:17 AM   #3567
TrotFox
TrotFox is on a distinguished road
1992 SC
2006 VUE 2.4L
This week I took her on an impromptu road trip. ~1700 miles in 3 days with a funeral and burial in the middle.
As for the car, she did just fine. Frustratingly I received new front anti-sway bar bushings the day I left so I didn't get to install and test them with this trip. On the up side she managed ~36 MPG with my bat-outa-hell driving style maintaining 5-10 MPH over the speed limit depending on who I was following. used about a quart of oil for the entire drive too, seemingly half of it on a missed shift...
Trot, the steadily rolling, fox...
Red 5spd Fiero Formula
Grey 5spd '06 Vue
Red '15 PriusC-4
Add to TrotFox's Reputation
Rate the quality of this post and help TrotFox reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
TrotFox is offline   Reply With Quote
Old 04-19-2014, 08:22 AM   #3568
slapshot 11
1999 SL1
Some of the things I did to this car were done before I did so much research on Saturnfans.com, so I bought a fixed orifice PCV valve and installed it and now we'll see if that helps the oil consumption any. It seems to be spotty, sometimes it uses a lot, sometimes not, I dnk why yet.
Old 04-19-2014, 08:28 AM   #3569
hooked2u
hooked2u is on a distinguished road
1999 SC2
Another linux user. Great! I have all Debian based distro's on my assortment of Intel, AMD, and ARM PC's. This one runs Linux Mint 15.
<<1999 Saturn SC2 4 speed automatic. 262,658 (as of: 2014AUG29), low comp cyl#3, parked, use emergency trans. only; 2001 Saturn SC2 5 gear manual. < 127K mi, purch May 2014. Great MPG!>>
Add to hooked2u's Reputation
Rate the quality of this post and help hooked2u reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
hooked2u is offline   Reply With Quote
Old 04-19-2014, 03:04 PM   #3570
dummo
dummo is a glorious beacon of lightdummo is a glorious beacon of lightdummo is a glorious beacon of lightdummo is a glorious beacon of lightdummo is a glorious beacon of lightdummo is a glorious beacon of light
dummo's Avatar
1997 SW2
1). flushed tap water through my windshield washer fluid reservoir and filled it with Rain-X (orange color) bug loosening formula.
2). Purchased 3 gallons of distilled water at the supermarket in preparation of doing a coolant system drain and fill.
Question: What do you recommend as the optimal choice for coolant? ...1997 DOHC with 142,300 miles. I have no leaks to speak of but I do have to add a few ounces to the reservoir tank quarterly to get the low coolant warning light to shut up.
1997 SW2 used 12/29/2011 with 124,200 -27 mpg
2004 Ion3 new 11/2003 (totaled) 11/2011 -23 mpg
1994 SL1 new traded
1992 SL2 new traded for above
Add to dummo's Reputation
Rate the quality of this post and help dummo reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 04-19-2014, 03:22 PM   #3571
Pitcher
Pitcher's Avatar
Any G-05 rated Coolant like Zerex would be excellent. Mix at ~60%.
Old 04-19-2014, 04:53 PM   #3572
sallydriver
1993 SW2
I've been meaning to try Mint.
The one I've really got my eye on is Gentoo.
Old 04-20-2014, 09:39 AM   #3573
tunedbysaturnsl
tunedbysaturnsl is on a distinguished road
Started gathering supplies for my a/c system-PAG 100 oil with UV dye, R134a refrigerant, tin can tap, and ordered a a/c dryer. Already have the a/c high- low- side manifold gauge set with hoses and a two-stage vacuum pump.
Oh, also bought some DOT 3 synthetic brake fluid to for a brake system flush.
Waiting on a price quote to have my front and rear brake calipers powder-coated along with the Hein rear hub spacers soon so, I can get moving on my rear disc swap. (Still need pads all around and the S*2 subframe with the rear sway bar.)
Did some poking around looking for a GM Tech II (2) system as well. Found a couple promising leads.
For the Eclipse, I'm in the process of sanding down a set of door hinges so, I can re-paint them black. Then, eventually install them on the car. Going to have to invest in a front wheel hub to mock up/test fit a front Evo Brembo brake caliper to a Japanese Galant knuckle and see if my rims will clear it. (If so, they'll go on shortly after. If not, the front brake calipers with pads, rotors, and Galant knuckles will just go up for sale to the DSM crowd and I'll have to settle for 2-piston front calipers from a GSX model. =( )
1995 Saturn SL1 "Abby"-Powertrain Swap Completed. Running As Of 07/27/2013
1997 Mitusbishi GST "Phoebe"
Looking For:
Saturn Blimp plush
Homecoming Saturn Logo "Lost Form Cast" piece
Add to tunedbysaturnsl's Reputation
Rate the quality of this post and help tunedbysaturnsl reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
tunedbysaturnsl is offline   Reply With Quote
Old 04-21-2014, 10:32 AM   #3574
dummo
dummo's Avatar
1997 SW2
Okay - but - 60% coolant to 40% distilled water? or 40% coolant to 60% distilled water?
If you said 50% I wouldn't have had to ask.
1994 SL1 new traded
Old 04-21-2014, 12:40 PM   #3575
Signmaster
It's the myth of the magical mixture. If you do want the mixture to raise the boiling point to above fan on temp, look at the chart and then subtract the pressure rise temp provided by the cap. Then figure out what mixture you would want to go above fan on temp, as it varies with type and make of antifreeze.
If your system is operating properly, you can use any mixture within what the manufacturer recommends. More water, better coolant and lower boilover and freeze protection. More coolant, less cooling and better boilover and freeze protection.
And really if you lose pressure you're also losing a great deal of your temp rise capabilities as well as cooling. Pressure in the system raises the boiling point more than the coolant does.
Old 04-21-2014, 02:14 PM   #3576
el diablo viejo
el diablo viejo will become famous soon enough
el diablo viejo's Avatar
1994 SW1
2000 SW2
Easy way ( per Old Nuc ): Dump in the whole gallon of coolant, then finish topping off with distilled. Gives you approx. 60% coolant/40% distilled.
97 sl2 a/t 104 K
1989 GMC 3500 454 129 K, 1969 442 455 rat rod
Add to el diablo viejo's Reputation
Rate the quality of this post and help el diablo viejo reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
el diablo viejo is offline   Reply With Quote
Old 04-21-2014, 02:22 PM   #3577
1bignordic
1bignordic has a spectacular aura about1bignordic has a spectacular aura about
1998 SW2
I replaced the engine coolant temperature sensor. Next weekend I'll replace the thermostat and flush the cooling system.
Add to 1bignordic's Reputation
Rate the quality of this post and help 1bignordic reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
1bignordic is offline   Reply With Quote
Old 04-21-2014, 05:40 PM   #3578
Pitcher
Pitcher's Avatar
Yes. 60% Coolant.
Old 04-21-2014, 05:41 PM   #3579
Pitcher
Pitcher's Avatar
Drove Creampuff down VERY MUDDY roads to get to fishing spots.
Oh. My. Is she filthy.
Old 04-21-2014, 06:23 PM   #3580
solidhadriel
Drove the saturn to work today. 100% water and 0% coolant.
Looks like we didn't leak like we normally do. So I'm kind of excited. I may do an oil change when I get home (its been 300 miles since the last oil change LOL) and will probably flush my coolant again this weekend.
Also, I installed a new Radiator, and new radiator hoses on Saturday.
I'm trying to determine if the heads are still leaking after the new gasket or if the filth is still in the system and needs flushing out.
Anyone see the "Judge Judy" episode with the 96 S series today? dave.sl S-Series General 23 02-20-2014 04:56 AM
The S Series would be a great car for the lineup today VTHokie00SL2 S-Series General 46 10-01-2012 08:26 AM
Got the L series recall letter today for rear lights Garciavision L-Series General 27 12-22-2005 02:29 PM
REDLINE Series Announced Today D C Vue Red Line 6 04-10-2003 08:14 PM
Saw the L series DVD system today Jeff P L-Series General 1 11-09-2001 09:03 PM
