Old 02-23-2011, 11:46 PM   #1
Tom S2
Tom S2 will become famous soon enoughTom S2 will become famous soon enough
Tom S2's Avatar
2008 Astra XR
Default Engine lack of power with DTCs P0011, P0014, P000A, P000B, P0012, P0015 or engine rat
Got this from the February 2011 GM Tech Links http://www.sandyblogs.com/techlink/2011/02/
Model Year
2008-2011
Vehicle Line / Condition
Astra, Aveo, Cruze, Wave - Engine lack of power with DTCs P0011, P0014, P000A, P000B, P0012, P0015 or engine rattle noise
Do This
Remove the oil filters from the camshaft position actuator solenoid valves
Don't Do This
Don't replace the camshaft position actuator solenoid valves
Reference Information / Bulletin Number
10-06-04-016
Astra XR-3-5 HP - Hamster Powered!
Dealer added options, & Infinity speakers.
Add to Tom S2's Reputation
Rate the quality of this post and help Tom S2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Tom S2 is offline   Reply With Quote
Old 02-24-2011, 01:33 AM   #2
MGGDTW
MGGDTW is on a distinguished road
MGGDTW's Avatar
2008 Astra XR
Default Re: Engine lack of power with DTCs P0011, P0014, P000A, P000B, P0012, P0015 or engine
Model Year
2008-2011
Do This
Don't Do This
10-06-04-016
Interesting... I have the engine rattle noise but am not experiencing any power-loss issues. So I'm not too worried just yet. Should I?
I'm at 19k miles.
Add to MGGDTW's Reputation
Rate the quality of this post and help MGGDTW reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
MGGDTW is offline   Reply With Quote
Old 03-10-2011, 02:02 PM   #3
ReGZ_93
ReGZ_93 is on a distinguished road
2008 Astra XE
I just had mu Astra in today, and the dealer performed this repair under warranty. I originally had a check engine light come on last Sunday, and it went off yesterday, but the codes were still stored.
The car is running much better now. There is no dead spot (hesitation to rev) between 2200 and 4000 rpm, like I had before. The engine revs freely all the way to red line now.
Add to ReGZ_93's Reputation
Rate the quality of this post and help ReGZ_93 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ReGZ_93 is offline   Reply With Quote
Old 03-12-2011, 06:12 AM   #4
ilvtofu
ilvtofu is on a distinguished road
ilvtofu's Avatar
2009 Astra XR
Has anyone noticed hesitation while idling? as if the alternator was going/car stalling, my car occasionally (maybe once every 2 months) does this. haven't really noticed any issues though, it drops for a split second then comes back up.
Eibach 15mm 5x110 hubcentric spacers with bolts PM is key!
Twilight Blue XR 3 Door
Add to ilvtofu's Reputation
Rate the quality of this post and help ilvtofu reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ilvtofu is offline   Reply With Quote
Old 03-14-2011, 03:47 AM   #5
darek_dade
darek_dade is on a distinguished road
I get it from time to time too...
09 Astra XR (manual, 3-door)
Add to darek_dade's Reputation
Rate the quality of this post and help darek_dade reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
darek_dade is offline   Reply With Quote
Old 03-14-2011, 06:48 AM   #6
emg77
emg77 has a spectacular aura aboutemg77 has a spectacular aura aboutemg77 has a spectacular aura about
emg77's Avatar
2008 Astra XR
Yes, me too. I remember this coming up in a thread, and there are quite a few people that experience the little near stall and recovery every couple of months.
Drives: 2014 Volt, 2017 Acadia
Past Cars: 08 Astra, 15 Acadia, 12 Enclave, 09 Traverse, 05 Vue, 04 Grand Prix, 00 Alero, 97 LeSabre, 72 Cutlass S
Add to emg77's Reputation
Rate the quality of this post and help emg77 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
emg77 is offline   Reply With Quote
Old 03-14-2011, 11:30 AM   #7
tackepj
tackepj will become famous soon enough
tackepj's Avatar
2008 Astra XE
Yes, and more often than I used to. Approach a traffic light, clutch in, and there's a brief stumble that feels as if it's about to stall (but it never does). Can this be related?
Former: 2005 L300, 2007 VUE Green Line
Current: 2008 Astra XE
Add to tackepj's Reputation
Rate the quality of this post and help tackepj reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
tackepj is offline   Reply With Quote
Old 03-17-2011, 10:40 PM   #8
ReGZ_93
2008 Astra XE
My car was doing that before I took it into the dealer. It would feel like it was about to stumble and had hesitant acceleration after clutching out.
Now that they made the fix, my car feels better than new.
Old 06-02-2011, 11:37 PM   #9
goob
goob is on a distinguished road
My check engine came on today, Onstar says the code is P0011.
I had the same code last March and at that time my dealer replaced the camshaft positioner sensor. The techlink mentioned in the first post says not to replace this, but "Remove the oil filters from the camshaft position actuator solenoid valves". What exactly does this mean? Do they put new oil filters in?
08 Salsa Red Astra XR 5dr 5spd
Spt Pkg, Prem. Aud. and Sunroof
Add to goob's Reputation
Rate the quality of this post and help goob reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
goob is offline   Reply With Quote
Old 06-03-2011, 12:06 AM   #10
goob
Forgot to mention, car sounds like a diesel at idle and I notice there acceleration is a bit sluggish.
Old 08-26-2011, 07:28 AM   #11
iufan87
iufan87 is on a distinguished road
Have the p0014 code. Can anyone help with a pic or description of the location of the camshaft position actuator solenoid oil filters. Is the removal of these oil filters a simple procedure? thanks
Add to iufan87's Reputation
Rate the quality of this post and help iufan87 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
iufan87 is offline   Reply With Quote
Old 08-29-2011, 06:21 PM   #12
danger d
danger d is on a distinguished road
2008 Astra XR
I have a check engine light since 2 days and the car lacks of power between 2000 and 4500 rpm.How do we clean those camshaft position actuator solenoid valves filters?
2008 Red Astra XR3 5-speeds Sport Handling Package Premium Audio Package 17's
Add to danger d's Reputation
Rate the quality of this post and help danger d reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
danger d is offline   Reply With Quote
Old 09-01-2011, 09:49 PM   #13
danger d
2008 Astra XR
Default
They just did that repair and they charged me 62$.its not covered by the powertrain warranty.i will call gm canada to know why its not covered by the 160000 km warranty.its a really easy repair to do.Only remove the two cam actuator and remove the 2 orange screen/filters.torque the bolt to 53 inch/pound or 8 newton-meter.20minutes and you are done.
Old 09-02-2011, 07:00 AM   #14
Lunchbox1984
Lunchbox1984 is on a distinguished road
Lunchbox1984's Avatar
2008 Astra XR
2003 L-Series 2.2L Sedan
Bro, they shouldnt have charged you on that repair, if your car is still under warranty, that should have been covered, i just had both of mine replaced and it was covered. So, yea i would call up and tell them what happen. good luck.
Bertha [2008 F250 S.D.] 4dr|6.4ltr Diesel 350HP|4x2|6ft bed.
RED [2008 Sat. Astra XR] 2dr|1.8ltr Ecotec 140hp (will be missed)
Oggly [1984 Isuzu Trooper II] 2dr|2.0Ltr G200 89HP|White|4sp manual
Add to Lunchbox1984's Reputation
Rate the quality of this post and help Lunchbox1984 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Lunchbox1984 is offline   Reply With Quote
Old 09-02-2011, 07:14 AM   #15
danger d
2008 Astra XR
Default
Did they covered it under the powertrain warranty or the bumper to bumper 3years60000 km?
Old 09-27-2011, 04:18 PM   #16
wandern
wandern is on a distinguished road
Powertrain. I had my filters removed under warranty with 99,600 miles on the odometer.
Add to wandern's Reputation
Rate the quality of this post and help wandern reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
wandern is offline   Reply With Quote
Old 10-11-2011, 03:02 PM   #17
AdAstra
AdAstra will become famous soon enough
2008 Astra XR
Will they do this repair without the check engine light/codes? My engine is very rattly and has very uneven power output/acceleration... but the check engine light has never come on.
2008 Astra XR 3-Door, Black Sapphire, 4-Speed Auto
Add to AdAstra's Reputation
Rate the quality of this post and help AdAstra reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
AdAstra is offline   Reply With Quote
Old 10-12-2011, 08:38 AM   #18
Gerry Proctor
Gerry Proctor has a spectacular aura aboutGerry Proctor has a spectacular aura about
2008 Astra XR
2008 SKY Red Line
Sure, but without a CEL, you'll have to pay for the repair. They can't repair a vehicle that isn't broken and get reimbursed for a warranty claim. If you have the fault, it will set the CEL.
Add to Gerry Proctor's Reputation
Rate the quality of this post and help Gerry Proctor reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Gerry Proctor is offline   Reply With Quote
Old 10-12-2011, 09:00 AM   #19
wandern
The code may be set even though you've never seen the CEL light come on. You'll have to either bring it in (taking a chance on paying diagnostic charges in case there are not any codes set) or buy/borrow an OBDC II code reader and see for yourself if there are any codes set.
Old 12-29-2011, 09:16 PM   #20
kikastra
kikastra has a spectacular aura aboutkikastra has a spectacular aura aboutkikastra has a spectacular aura about
kikastra's Avatar
2009 Astra XR
My CEL had come on and off, for about a month leading up to last week. I also noticed that the car would stumble sometimes on acceleration, and the near stall, upon press the clutch near a dead stop. So last Friday the light had been on for a week, and I got OnStar to give me the code, which was P000A. Brought it in to the local GM dealer yesterday, and the tech did whatever as per the TSB (replaced cam shaft actuator filters or something, I don't have the work order handy). It was done under warranty, I still have the bumper to bumper, but I assume it would be covered under power-train warranty. It runs a lot smoother now, doesn't hesitate when accelerating through 2500 rpms, and doesn't stutter when I disengage the clutch. Fuel mileage "seems" to be a little better as well, but I'll need to give it more time to find that out for sure.
On a side note, the guy tried to sell me on throttle body cleaning. He tried to tell me that there were also codes stored related to that, and that it was required after 30,000kms, and mine had not been done yet. First of all my car only has 26,0000kms on it. $69 plus tax. I said thanks, but no thanks. He tried to tell me that the CEL might come back on as a result of my refusal. Sheesh. Everything at the dealer was a positive experience until they pulled that little stunt. Anything to make a buck I guess, but it really leaves a sour taste in my mouth. This was City Buick in Toronto, BTW.
2009 Saturn Astra XR3 5-Speed - 77,000KM
Add to kikastra's Reputation
Rate the quality of this post and help kikastra reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
kikastra is offline   Reply With Quote
Check engine light on code p000a HECTOR VAZQUEZ Astra General 7 02-13-2009 01:14 PM
97 SW2 Lack of power when hot klaus S-Series Tech 7 09-09-2006 04:31 PM
lack of power problem and sputtering gypsy35 S-Series General 20 09-21-2005 10:56 PM
Lack of power radioouman S-Series Tech 3 01-09-2003 07:56 AM
lack of power saturn_guy S-Series Tech 2 05-11-2000 11:15 PM
