Old 09-20-2009, 10:11 PM   #1
Growser
Growser is on a distinguished road
Growser's Avatar
2000 SL1
Default Horn Replacement OEM or ???
Have to replace the horn on the 97 SC2. I could go OEM or something bigger and better. Anyone do anything unique with your horn?
7 Saturn Car Family with + 900,000 miles.
2002 SL2, 2000 SL1, 1997 SC2, 1997 SC1, 1996 SC1, 1994 SC2, and now a 93 SC2 project car.
Add to Growser's Reputation
Rate the quality of this post and help Growser reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Growser is offline   Reply With Quote
Old 09-20-2009, 10:43 PM   #2
PurdueGuy
PurdueGuy's Avatar
1999 SC2
1999 SC1
Default Re: Horn Replacement OEM or ???
I wired up an aftermarket horn in my wife's SC1 when the OEM quit, since the design with the built-in relay annoyed me. Unfortunately, the horn wasn't any louder than stock, in spite of all sorts of claims on the packaging that it was very loud. I think I need to dig back into it & replace either the relay or horn again, as it has once again faded into non-function.
SaturnSeries.net owner
Add to PurdueGuy's Reputation
Rate the quality of this post and help PurdueGuy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 09-20-2009, 11:01 PM   #3
Think of the fun you could have with one of these. http://www.hornblasters.com/
If you go the relay route you need at least 500 ohms of coil resistance to prevent burning up the flimsy horn buttons and be sure to install an arc suppression diode across the relay coil. Another across the horn power relay contacts is not a bad idea either. You can get the relay cheap here. http://www.allelectronics.com/
Old 09-20-2009, 11:08 PM   #4
Growser
Growser's Avatar
2000 SL1
Would have to find the room under the hood to do something like this, but it would be an attention getter.
Old 09-20-2009, 11:41 PM   #5
Compressor in the trunk and heavy duty power back to it. If I had one I would find room. I have had loud horns before and they are great sport. I would love to have one for the idiot with the cell phone crammed in their ear and their lip flapped up over their eyes.
More linkage. http://www.trainhorn.org/ Has sound files. There are some that get up to 165-170 DbA. That would require some decent ear protection to be donned before initiating a gentle toot.
Old 09-20-2009, 11:52 PM   #6
The larger the diaphragm and the larger the throat diameter the louder and lower tone. This started life as a steam horn.
http://cgi.ebay.com/TRAIN-HORN-LOCOM...d=p3286.c0.m14
Move the battery to the trunk and it will fit. Probably will need a WAI also.
Old 09-21-2009, 02:09 AM   #7
DIYguy
DIYguy's Avatar
1997 SC2
Happy Re: Horn Replacement OEM or ???
Funny, I was just at All Electronics in Van Nuys week before last. Neat place. I bought a new surplus power window motor (looks like from a VW) to motorize the height adjustment on our garden tractor.
To the subject-
Any plug-in replacement will probably sound like the original unfortunately.
I did the relay/airhorn (Fiamm) thing on my 97 SC2 a couple of years ago (search for "meep meep"). It worked but in the end water that got splashed up into the front fender well cavity somehow ended up taking out the compressor.
There are 30 amp capacity cube relays that will work very well for the purpose, All Electronics does carry those, and they are sealed from the elements. Get the pre-wired connectors if you can. Saves a lot of grief.
However, take it from me, mount the compressor somewhere high and dry, and preferably with the air inlet pointed down if yours will allow it. Mine had to be mounted inlet up according to the case markings. Seems kind of dumb but that's how it was.
It sure was nice while it lasted though. I haven't gotten around to redoing it with another brand and am running the pathetic OEM horn at the moment. Meep meep.
DIYguy
Quando Omni Flunkus Moritati
Add to DIYguy's Reputation
Rate the quality of this post and help DIYguy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 09-21-2009, 08:05 AM   #8
MiSaturn
MiSaturn is on a distinguished road
2002 SL
1993 SL2
Fiamm makes a cheap high/low electric horn combo that gets some respect on the road. Used the supplied straight brackets to make a "V" shaped one, and used the existing horn mounting screw at the base of the V to hold them together.
Has also used Hella "Supertone" horn sets, which claim to be the loudest horns available. They certainly are loud, but a little too high pitched for my liking.
Add to MiSaturn's Reputation
Rate the quality of this post and help MiSaturn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
MiSaturn is offline   Reply With Quote
Old 09-21-2009, 12:33 PM   #9
Low Saturn
Low Saturn's Avatar
2007 AURA XR
Mike
-1991 Turbo SL2.
11.809 @ 116.488 mph
www.differentracing.com
-2001 Chevrolet Suburban
-2007 Saturn Aura XR
Old 09-21-2009, 01:09 PM   #10
mattelderca
mattelderca will become famous soon enough
mattelderca's Avatar
1998 SC1
1996 SL
Next time your at a good wrecker look for a big old Caddy. Even some of the newer ones will have em as well. If you find the right one you'll have about 6 or so horns to remove! Get em all as they are different notes. Do a relay addition and use a dedicated, fused, ten gauge from the UHJB positive post.
2000 SL1 freebie, my sons DD
1998 SC1 still running, FOR SALE cheap!
1996 SL, GONE but not forgotten
2005 Generic Silver Minivan (Kia Sedona)
2009 Nissan Sentra 2.0S
Add to mattelderca's Reputation
Rate the quality of this post and help mattelderca reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mattelderca is offline   Reply With Quote
Old 09-21-2009, 04:35 PM   #11
crystal scan
crystal scan is on a distinguished road
2003 ION-2 Sedan
take out the AC compressor
Add to crystal scan's Reputation
Rate the quality of this post and help crystal scan reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
crystal scan is offline   Reply With Quote
Old 11-24-2009, 02:05 PM   #12
Train Horns
Train Horns is on a distinguished road
Is this everything that I would need to install a train horn on my frontier? I have absolutely no mechanical experience. Will I need to get someone to install it for me, or can anyone install it?
Add to Train Horns's Reputation
Rate the quality of this post and help Train Horns reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Train Horns is offline   Reply With Quote
Old 11-24-2009, 02:09 PM   #13
Low Saturn
Low Saturn's Avatar
2007 AURA XR
For real train horns, you'll need the horns, an air tank and compressor. Plus all the lines, valves and wiring. And the most important part, space to mount it all.
Mike
-1991 Turbo SL2.
Old 11-24-2009, 02:51 PM   #14
madpogue
1996 SW2
And a good lawyer, for the first time you use it in public.
Add to madpogue's Reputation
Old 11-28-2009, 01:13 PM   #15
hooked2u
hooked2u is on a distinguished road
1999 SC2
While I had a service warranty with Saturn my horn was replaced 7 times over the 5 year service warranty period. My mechanic replaced the 7th OEM with something from Auto Zone. It lasted 5 years. I've been running without a horn for 6 months. After viewing richpin06's video on horn replacement, I feel comfortable with doing the replacement myself. I think I will opt for a NAPA or Auito Zone replacement.
<<1999 Saturn SC2 4 speed automatic. 262,658 (as of: 2014AUG29), low comp cyl#3, parked, use emergency trans. only; 2001 Saturn SC2 5 gear manual. < 127K mi, purch May 2014. Great MPG!>>
Add to hooked2u's Reputation
Rate the quality of this post and help hooked2u reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
hooked2u is offline   Reply With Quote
Old 11-28-2009, 01:39 PM   #16
If you have a 3 terminal horn you need to use a relay or you will burn out the horn button contacts instantly. If it has already been re-engineered to a 2 terminal horn then the "new' relay may have died. This is the original 98/99 wiring diagram. Watch the polarities.
Old 11-28-2009, 02:45 PM   #17
eRic 02sc2
eRic 02sc2's Avatar
my Saturn has two horns. one is under the fender and the second one is under the hood next to the latch where Saturn originally mounted them before 96. the mounting hole is there so I used a stock 91-95 bracket for it and taped into the factory wiring.
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
Add to eRic 02sc2's Reputation
Rate the quality of this post and help eRic 02sc2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 11-28-2009, 04:08 PM   #18
saturnsctwo
do saturns have dual horns or only one? i see one under the driver's side leadlight pod on my car, & it sounds like only one horn.....
Add to saturnsctwo's Reputation
Rate the quality of this post and help saturnsctwo reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 11-28-2009, 04:20 PM   #19
One, unless its been modified.
Old 11-28-2009, 05:15 PM   #20
saturnsctwo
ya that's why it's not so loud, but ya know me it's staying stock....
all cars should have dual horns though in case one goes out, just a safety thing...
1996 Saturn SL2 horn replacement w0by S-Series Tech 13 06-07-2010 10:16 PM
Horn replacement Brad_bb S-Series Mods 26 05-04-2009 12:34 AM
98 Saturn Horn replacement mariopalumbo S-Series Tech 9 05-08-2007 05:29 PM
1997 sc2 horn replacement dsdSC97 S-Series General 8 04-03-2004 09:10 AM
'96 SL2 horn replacement? alacrity024 S-Series General 10 12-18-2003 01:07 AM
